This is not a project for any sort of beginer or not anything I would recomend for anyone who cannot do it all themselves. I spent waaaaay too many hours to justify having an actual shop try it. I also probably wouldn't ever do this again for fear that I wouldn't be able to reproduce the same results. Yeah, it turned out that good. That said, as I post pictures, understand this project is already DONE. So it WORKS and looks as though the factory installed every piece. So sit back, enjoy and maybe dream that you might one day yourself embark on such a task. Hopefully this will help those few people who dare to be as stupid as I.
The first thing I started with was a handful of measurements and compound curve demensions. Then my son and I zipped on down to a local bone yard and started checking out roofs on various cars. I wanted to keep it in the "Porsche family" or at least in the P-VW-Audi family, so we started there. Turns out, the 944 has an almost spot on match to the first main raidus required for the job. Hmm, $100 and a sawzall later and we had the top of a 944 sitting back at the house. Here is the basic starting piece I had. This is where the fun and frustrations began.
My first cut was for the front, measured from the windshield frame back to where I figured the back should end correctly. I studied 100 916 photos and had them plastered everywhere during this whole process.
Here is a little more cut off, there is A LOT that was removed and yes, I wanted a sunroof and yes, the drain tubes are hooked up and yes, it all works and is completely unseen as if done by the factory. So yes, you can have your cake and eat it too on this one. This conversion completely changes the car. I also have the Engman inner long kit installed and holy crap, it's a stiff one!
This is one crappy photo, sorry about that. But after cutting off much of the sides that would meet up with the doors and rear quarter windows, I was able to start laying the steel section on top of a 914 top to start getting ideas of where to go from here. One thing I noticed right away was I was going to have to create something to add about 1 inch to each side and make it have a compound raidus. Nothing like keeping it simple huh?
Keep the pic's coming Dan! It looks like you have done a wonderful job.
Now you go drive?
Here is a better shot showing more of the material removed. I must of drilled out 1000 spot welds, ground down and cut off gobs of metal trying to leave as much alone as possible to retain strength. You can also see some 944 interior parts laying around. I went through I think about 5 versions before finally settling on the final one. Oh yeah, the finished top with sunroof in and all interior parts wieghs 6lbs more than the glass top, I figure with welding and skim coating(body work) max of 10lbs added to the car.
Here are the final first version removed pieces from the 944 roof section. I wound up having to build and box in top out longitudes for both sides to acomplish my goal, stiff as a 916, but still with an open roof. It was too cool watching the Yard Dude cut the roof off the 944, he pretty much sawzall'd right through everything, glass, sunroof cables etc. 944's are plentiful at bone yards right now. Last post for the night, more to come later this week.
More! More!
You have WAY too much time on your hands...
And why a sunroof???
I love it! I've thought about running bars just under the edges of the top. But yours accomplishes the same thing, even stronger, and is a much cleaner finished product.
I would make the sunroof piece completely removable, so it's still *almost* a targa with just a smaller top. And make a new holder/clips to still stow it in the trunk. (Is this one removable or tip up?)
Now all you need to do is make a door frame around the top and put a modern one-piece window in that can roll up and seal in the frame. It would make a perfectly water/air tight seal like a new car.
Nice work Dan! I love seeing unique projects!
Nice work, I can't wait to see the rest.
If you weren't 1,000 miles away, I'd bring you some sawhorses so you wouldn't have to work all bent over on those rubbermaid containers anymore. It makes my back hurt just looking at it.
more pics!
I think that's a nice addition, sunroof or not. My question about the addition of the roof is would it put added pressure on the windshield frame? I wouldn't mind doing the job on my car. Has anyone had any experience with the long term effects. It would be a shame if the windshield or windshield frame became damaged due to flex.. Just wondering If you have to do any structural work in that area first ????
I hated driving with my top on, but once I got a good rear targa seal and set up my rear glass using "two" panes its rather nice in the cab.
Is the 914 windshield hoop any weaker or stronger than other cars? It seems that most cars have minimal structure on the sides of the windshield.
Nice work.
Same as the last shot I posted, just from the other side. Yes, I have 4 saw horses and 8 pairs of jackstands. You can see on the bottom one of my first versions was leaving that nice finished edge on from the 944. It seemed perfect, the way it sloped back in just like the 916, smooth factory finished edge even. Eventually, I found it just too much for me to make look "perfect". So it got cut off down the road. I'll show you what I did in its place.
One of the local guys (Jeff H.) let me cut the rear targa roll bar and front winshield frame sections off of a soon to be scrapped 914. I learned very quickly I wouldn't have been able to do this without those pieces. You simply have to have them to help design and build the needed compound curves for the roof section. Here is another tossed out idea I had of cutting part of the windshield frame up to use and weld to the top to creat an exact 914 "curve". I never got to welding it on, I wound up building this part from scratch. Yuck.
Here is another good shot of the two tops sitting close together. You can see how the main roof arc is almost a spot on match but still not quite wide enough.
Here are those saw horses with the donor 914 top parts ready to be used as jigs and even welded onto the 944 roof section, well, parts of the donor parts anyway.
Why the suspense with the pictures? I'm American, I need it now!
OOPS! Your still adding.
First trial of my side extensions. I didn't get any shots of the actual making or tooling of them, here they are lightly tac'd into place and set on the rear targa bar to check the fit and curve. These were the hardest parts because they have a radious that has to follow the top of the door window along with the curve that has to follow the top down to the sides AND still have a finished edge with NO body filler. Like I said before, yuck.
More welding, more checking, pretty rough, but starting to come together, sort of. At this point, I was still thinking I was going to just toss the whole thing in the trash. Figured it was fun trying, but the back section just wasn't turning out like I hoped. This photo is still a LOOOOOOOONG way from fitting to any car.
Bottom view, note the two flat surfaces. This is what I would mounting the window seal chanels to. They also get formed into a "box" that gets welded to the targa bar and windshield frame. Mucho strenth added because of that for sure.
Last picture for tonight, getting tired. I wish I would have taken better pictures of this one. I wound up cutting the very top front of the donor windshield and grafting it onto the 944 roof section to get an exact curve match to my 914 frame. After carefully cutting and cutting I wound up leaving a 2 layer piece together which had a lot of strength to it. This ensured my welding the arc to the front of the 944 roof section would match spot on to my 914 winshield frame. Lots and lots of welding after this, folding down the "boxes" and welding them to the 944 roof section. At this point, I could set the top on my 914 and it looked just like the fiberglass top. Sat on there exactly the same. Next photos I start welding on my car! Doh!
Still thinking to myself; "I can still turn back, just put it all back together" My ultra exact red lines indicate what I had to remove from the rear targa bar to have the sunroof fit correctly.
I can still just put everything back.....
Notice I cut off the back because I just wasn't happy with the ends or corners. I welded up metal, ground, welded, cut off, re welded, new metal, ugh, finally cut it all off and decided I just couldn't manufature that back finished piece. Having the back open for the attatchment made it perfect for welding the top to what was left of the roll bar and my added support bar.
I can still put everything back and just walk away.....
Nice sawhorses! I think you ran out and bought them so as to avoid any more embarrassment.
No turning back now, rear targa bar cut, first welds done to secure the top to the car. Holy crap, what have I done?
FYI for anyone contemplating this. Make certain the car you get the top from is an EARLY 944 or any 924 (pre 83) Later 944's and the 924S have a MOTORIZED sunroof that is operated by a motor in the rear of the car with cables running up to the roof. This would be EXTREMELY hard if not impossible to utilize the late style roof. Early roofs are a simple and manual 2 latch twist and lift setup. Carry on
My special bar to reinforce what I cut off of the targa bar.
Fast forwarding since this is not a "how to" thread, just an "I did it so maybe you can to". Almost ready for paint in this photo, just a little more flat boarding and touch up.
Also, if you heli-arc the factory chanels together, you can buy the nice new universal style window seals so they will be all one piece for around $2 a foot. Pretty cheap, seal up perfect, look totaly stock blah, blah. There you go folks. I'll post some more painted pictures later on maybe. It can be done. Completely changes the car, tight and quiet now. I dare say almost like a normal car?
Actually one more for tonight. I wound up cutting off the last inch or so of the fiberglass top and using it as a "cap" grafting it on to the steel top section after all the welding was done. This was the only way I could see to get really good welds under that back top section as well as keep the back looking totally stock. Not exactly like the 916(no drop down supports on them), but still has the perfect factory edge and overbite like it should. With the car top primered, you couldn't even tell the top wasn't anything but stock. Maybe someone will take this to the next level and do a better job? Maybe just keep adding to this thread? That'd be cool.
Some people have entirely too much time on their hands......
VERY nice job!
That looks great! Give yourself a big pat on the back. Using the targa as a cap was something, looks nice.. Well done, I'm sure you have some more tweaking but I'm glad to see someone jump in and just go for it..... Keep us posted
very nice!
Dan looks good, I would want a little rain gutter above window (hate the rain running in with window down a bit.)
Nice.
Are you going to paint it body color or leave it looking semi-like a stock top?
Nice work Dan. I wish I could fabricate stuff like that. I need to learn to weld first I guess. I can't wait to see your car in person.
WOW. That looks awesome. I bet 911 window metal might work at the top too, but I can tell you were using what was available. Great job using the scrap pieces to mock fitment. Keep up the good work!
That is awesome.
How did you finish the inside of the roof (headliner)?
Nice work Dan.
Love it, I pulled up some 944 pics and began to wonder if you could keep the 914 rear window and reshape the sail panels to fit the 944 tail gate glass. Then you could do an engine under glass look like Ferrari.
Nick
WOW! This is simply amazing! Well done!
One of these days when I get back to the restoration on my 72 I'm gonna have to find a way to include this. I gotta learn to weld!
Thanks for showing us your work. It is a very well done piece.
Wow dan!!!!
that is a great job....
congrats on the move!!
I thought Root had been quiet for ages...now we know why!
Great read just like your classic six coversion thread!! Must be nice to post some pioneering 914 body work
Like I mentioned before, the whole car needs to be painted as a whole, but here is more of the "finished" product.
The setting sun was messing with my picture taking and I still have to put the window seals back on.
Looks great (I Dont Need No Stinking Targa Seal) Dan !!
nice job Dan....looks totally factory original...I like the all steel sunroof approach
and you worked in a picture of the new crib! Nice job Dan!
Wow Dan
That looks really amazing. The next time I see you drive by and you see a crazy guy driving a '98 BMW 528 and honking it is just me
That's definately going on my all-out-crazy-I-have-money-now 914 I'm going to build one day.
Ok, so there i am on the freeway when I see Dan Root headed home. I get an up close and personal look at his work on this top. The photo's don't do it justice. Great work Dan! very sweet!
Yep, nice day for a ride. I didn't see the front, just the back, sides and top. I think we wer going to have to raid your casa for a picnic and check out Dan's car BBQ.
Nice work Dan.
Dan that looks really great. Job well done. I see a new Rootworks future feature.
CLINTOPON
Awesome stuff.
How did you finish it on the inside?
Wow, it came out real nice.
Very nice Dan...........let me know if I can help with the seal for the top of the window to the roof.
I found one more picture from last weekend. Decent shot of the windshield to roof transition.
Dan,
Fantastic! You did a beautiful job. Anything less would have been a major disappointment given the car you did the surgery on. That is one great looking teener, and you have done it justice.
I wish that I had the cajones to try it on mine. I am tired of hearing the top squeak, and I think that I could live with a really large sunroof instead, especially given the structural stiffness added.
Hats off to great work,
Ken
Dan,
A great job I must say. Thanks for sharing.
Bob
Al,
You going for the solid roof on your 916 now? Looks somewhat more doable.
Bob
Very nice job.
Do you have any more pics on the area that you had to trim on the roll bar, I thought you said?
Also, any pics on the inside of the roof in how it was finished out?
Would you consider making any tops for anyone else who may be interested in a hard top since you did a good job of it?
Do you realize that the last post before yours was 2007!
I've owned the car Twice since then & it is now in the NE
Hey TC,
Is this the source for my 2.5 engine?
Vysoc
