Finally got the six chassis painted.
More pics pleeze...
Nice color I have always liked white cars!
Looking forward to pic,
here u go. sorry my files were too big.
Lookin' good! What color is that??
I like your color choice.
I have an orange crate too..... not a teener though
Parked to the left of my 74 914
It's getting the 73 RS treatment(if my other fender ever gets here)
Now that it's getting warmer (ok, So Cal is always warmer) you know what I mean.
I got motivated today and started on the wiring. NOS six harness and NOS fuse-box, both courtesy of Mr. Sager.
Under Dash
Headlight Bucket
Headlight Bucket
Tunnel
Rear Trunk
rear trunk
Lower Engine Compartment
Upper Engine Compartment
Man that is looking great.. hopefully someday i will be able to do that to mine
keep us posted..
I glued the new vinyl to the roll bar this weekend using 3M spray adhesive. Step 1; mask and scuff with a Scotch Bright Pad.
After glue and trimming
next
last one for now
I'm sure you know that the area that would be below the side engine lid grills needs to be painted black.
Thanks for reminding me.
other side
Can you give me any details of how you fitted the vinyl. It looks so professional. I'm just about to tackle mine. Did you trim the edges with scissors and how did you punch the holes?
wow,
I wish i had done that clean a job on my sail trim vinyl!
Everything is looking damn near perfect
Do you have a choice for an engine?
I said DAMN that looks good....I wanna paint booth too!!
beautiful pictures -thanks for the 'how-to' on the vinyl
Be very interested in seeing more progress pics
Got the hardware back from the plating co (thanks Bruce).
The front dust shields are modified to fit with Brembo 4-piston front calipers from a 968. I cut the tin, then sent to plater.
more plated hardware using yellow zink.
some more hardware
and the nuts-n-bolts
I also painted the black area of the engine lid.
My neighbor told me I should pick-up the pace. If not, I won't be driving before 2010
Got the NOS genuine 6 wiper motor installed. While I had the wiper transmission out, I disassembled it, cleaned and lubricated all parts and replaced the bushings,
I had some extra time so I installed the New bracket for the CD along with a Bosch rebuilt CDI box.
I got the engine seal in there too. that was a PITA!
The rear deck hinges and new plastic rollers are in. I was thinkin' about using the updated brass rollers, but these look cooler (to me). The shoulder bolts should be body color, but I thought it would be a shame to paint them after the nice yellow zink plating job.
The NOS front windshield seal went in easier than I thought it would, maybe because the aluminum channels are new?
I used Windex as a lubricant, maybe that was why it went in easy? Either way, it's in and looks great.
Last items I did this weekend was installing the muffler heat shield and the genuine 6 transmission mounts. The freshly plated hardware looks cool, maybe a bit too brite, but cool.
I love this build, you have great attention to detail.
This car is turning out amazing, keep up the good work!
DAMN.............. this is great
I like it just the way it is....
Clean the rest of the crap out of the garage and just leave it on display...
Finish up the garage wiring....and for crying out loud...marble would look alot better than concrete...
Love the car.
Rich
Your bolts are so much prettier than mine...
You are doing an awesome job on that car!
This is an awesome build, love the car.
I wish someone would sell a complete plated hardware, nut and bolt kit for 914s.
That would be a big seller for sure.
How long will zinc plated hardware retain its color in a well cared for (but driven)
car? Does the zinc corrode over time?
John
Got my butt out to the garage today and installed the lower control arms and cross member. I think they're the originals, they had no rust, but I took them to bare metal and painted them with mat epoxy. The steering rack cleaned-up nicely. I will install a new set of Turbo Tie Rods too.
The struts are NOS Bilsteins. Of course I installed new ball-joints. Calipers are rear 968 which were modified to fit the 3.5" struts.
The freshly plated yellow zinks looks a little too nice... NOT
Inside Gas Tank area where steering rack connects.
9146FAN
Wow, This is the first time I saw your post. Beautiful workmanship and attention to detail. I am really impressed and congratulations on your project. I love the color.
Tom
Also painted the orig coil and put the new stickers on.
Got the back glass (w/ defroster) and New lower seal installed today.
New brake fluid resivoir with supplyy lines and a clear plastic over-flow hose (from Pet Smart).
A new piece of felt and a new rubber seal for the bulkhead.
New front rotors with freshly powder-coated front hubs. New bearings and seals. I had to go with 18mm clamp-nuts and thrust washers due to the late-style Bilstein struts.
Fuchs were restored by Harvey. I asked for this finish which is slightly brighter on the lip. The rim is more frosted, and the center simi-gloss black. If I remember, Harvey said this was on original style used on 15" in mid '70's. These are 7x16.
I really like the look and just set one on the hub to see what it looks like.
Looks great to me.
This will be one of the nicest cars.... if you ever finish
Looking very good so far though
Wow, I can't wait to see your car on the street.
Very nice work!
Very nice, this car is going to be amazing.
Those are some awesome brakes you got there!
Had a few spare hours this weekend and got some stuff done.
NOS Proportioning Valve
Installed with new hard lines too.
Also installed new stainless fuel lines. I couldn't put that plastic Crap back in.
Mounted the fuel pump.
that is one clean mean machine!!
keep up the great work
Got a NOS heater valve...
and rebuilt the pedal assembley and started to install...
Trunk shot. Lot's of sanding to make it look like this...
I had some spare time this weekend to assemble the trailing-arms. New bearings, fresh plating on hardware and the original 6 hubs and stub-axles.
Installed new Turbo Tie-Rods
Cleaned the Torsion-Bar adgusters and lubed with anit-seize grease.
What did you rebush the rear trailing arms with? They look like rubber.
Kev
they're OG bushings. Rubber.
How's it going in the LBC?
WOW. Fine work!
I want to know if you are selling tickets for the Release of this beast?
Pick a completion day and I wouldn't mind being in the front row to watch this one roll out of your garage!
Porsche Factory didn't put this much love into their Six machines.....
Great work!
I just know that there is an amazing woman behind you on this one! KUDOS to her!
This thread is like watching mine being put back together (in my dreams!).
Beautiful work!
OK this car was on a shelf somewhere for the last 30 somthin years right? you just took it apart and cleaned it.......no way you redid everything so clean and neat...right? I mean I am right , right?....lol looks too good to drive. I can help design a nice glass case if you wish...
Josh
This is one beautiful car, you & our Rdauenhauer have really got it going, works of art !
I'm working on a project myself, what did you use as undercoating on the pan & wheel wells? I like the idea of texture for durability. ( & less sanding).
Keep up the great work.
Wow, gorgeous. Subscribing to your thread now.
Wow, I don't know how I missed this thread, absolutley beautiful.
My hat is off to you.... You are doing a FANTASTIC job. I look forward to seeing more!!!
I hade some time to start on the rear suspension.
Here's the new Bilsteins. Thank's Gunner!
The suspension starts to take shape.
Rebuilt rear calipers (yup, real 6). Rebuild done by Eric Shea. Thanks again Eric!
Replated backing plates and related hardware
New Rotors
E Brake cable Prophylactic (HaHa)
With Calipers and new lines installed
Another angle
This 6 didn't come from the factory with sway-bars, but I always wanted them. I welded in these cool mounts for the brackets before paint. They look like factory, at least to me...
Perfect work, and I love your trunk.
When you had the car Media Blasted, did you remove the sealant in the trunk? If so, what did you put in to seal it again?
Terrific job. Your car is amazing!!!!
These Fog Lights are the ones usually used on the early 911's with the thru-the-grill set-up. I know the 914 units are black, but I think these'll brighten up the front bumper area along with new chrome Fog Light grills.
These are the horns that came with the car. I assume they're the original's. I cleaned em with steel wool and degreaser.
The fog's are mounted too.
Got the front stabilizer installed today. New rubber, repainted 15mm bar, old hardware replated in yellow zink.
This six was not equipped from the factory with this option. I hope it will improve handling. The Bilsteins should help too.
Some more pics of the Stabilizer.
I also replaced all the metal brake lines as well as the hoses.
Inside pics of the Stabilizer under the gas tank.
Wow, ive been following this build thread and all I can say is wow. Its too nice to drive, it would be a sin to drive it. Incredible work and attention to detail!
Great pics and wonderful attention to detail, awesome.
If ever a car needed an anit-sway bar it's a 914... even a six. Good work
(that was the "only" mod I did to mine)
Wow! This thread/car is the definition of 914 Porn.
Looks like the standard for excellence.
Great job. I sold these cars new and believe me, they were never that nice brand new. Al.
My Dad used to say when I was working on one of my cars "you might as well jack up the radiator cap and run a new car under that thing the way you are going!" The radiator cap part may not apply but that is going to be one fine new car when you are finished. Thanks for sharing...
Breathtaking
You've raised the bar so high, I'm afraid the rest of us can only walk under it from here on.
"Nice work" doesn't begin to do justice to what you have done, superlatives escape me.......
Paul
Went back in the garage to do some work. Started by installing a new 19mm master and the rebuilt pedal assembly. Also put in a new gas peddal.
Installed the NOS oil tank with all new seals, washers, boots, hoses etc.
More progress on the oil tank.
NOS rear trunk button. I had a locksmith use the internals out of the old button so I could use the original key. He made me some extra keys from NOS blanks too.
Long-block is back from a local OC engine builder. This is a '76 2.7 S engine which was true.
I decided on this build because I want a high RPM carburated Peeky engine with more HP that torque. This is a copy of the 2.7RS spec. which should make around 200HP.
Case:
All the oil plugs were removed in order to clean the pasages. The bypass was done, the squirters were replaced and a 3.0 oil pump was used. Allign-bore was done. All bearings were replaced, time certs installed and new dilivar head studs were installed. The counter-shaft gear was neplaced with new. This is a commonly overlooked, but affects the cam and ignition timing.
Crank:
All plugs removed, galley's cleaned and new plugs installed. Crank was micor polished and balanced.
Rods:
Al rods checked, balanced, and small end bushings replaced with new.
Cam Towers:
Machined to flat surface. Oil tube removed, cleaned out and replaced with new plugs.
New German billet Cam Blanks ground to "S" Spec. and hardened.
Heads:
Replaced all valves with Aasco, guides with silicone-bronz. Replaced springs, keepers, retainers. CIS injector holes were welded closed and machined since I will be running Webers. Ports were opened and polished. Air injector holes were pluged.
Cylinders:
New Mahle 8.5-1 RS type pistons and cylinders.
Chain Boxes:
New ramps and chain, and pressure-fed tensioners.
Take a look...
New 930 shroud will give a "S" kind look.
PMO Tall manifolds will math up to the large intake ports on the heads.
The Holy Grail. NOS Weber 40IDAC3 carbs. OMG!!
Putin' some of the stuff on...
Plastic insulators are used between the heads and the manifolds to keep the carbs cooler which helps to reduce perculation.
New tubes and supmp plate.
New RS Bosch distributor with new Pertronix and a 7300RPM rotor. WEEEE
Shroud and Fan going on
Wll we see this car at the WCR? I sincerely hope so.
Manifolds are on. I decided on a wrinkle finish on valve covers, not a factory look, but hey, I get to pick. Right?
Weber's test-fit.
Absolutley Beautiful Job
The paint I used on the fan is "OEM Paints"; zink phosphate gray. I bought this can at the Pomona swap meet. You can probobly buy it on their website too. It goes on very easy and is supposed to hold up to heat too.
Mahalo for the compliment MrKona.
Tried something a little different on the Weber banjo fittings. Not OE, but cool looking and I dont think I'll ever have to replace them.
Update please
Time for some updates. The sheetmetal is painted and installed, and a NOS plastic air cleaner housing.
NOS rear trunk lock from my parts stash. I matched the tumbler to the ignition and then cut three new OE key blanks.
I got the interior back from the upholstery shop. This is a complete jod including door panels, back pad, center seat, and dash. The grain is as close to OE as I could find. I also used German Houndstooth which was not original to this car, but hey, what else is new?
Got the dash back from the upholstery shop. They installed new 1/8" foam and vinyl.
Back side of dash had some hand writting underneath. I decided to leave it. Maybe it was Fritz's signature back in May '70 ??
Starting installation in chassis with new OE rubber seal between dash and windshield.
NOS dash. I like the fact that the visor over the instuments is not saggy like my old one. This came from Kamp 914 about two years ago.
Dash top on and starting to install switches, controls, glove compartment.
Since I'm a big dude (6'-4" 230 lb), I wanted the steering column to be tilted up for more room. The original steering wheel position was almost in my lap. This was a big hasstle when mounting the column and linkage to make sure everything worked correctly with the steering.
This pic shows the new angle, I put the seat and steering wheel in and it made a big difference. It was a lot of work, but worth it.
Again, not original, but...
wow, that is amazing work! truly impressive!!!
I asked my body shop to reccomend a sound deadening material. They said the Honda (I know rice burner) product was the best. I cut paper patterns, cut the material, and installed. This product is adhesive on the back. After it was stuck in place, I used a heat-gun. This material is like flat heat-shrink, and I think it's on for good.
Solid, no rust origial floors. Original tar material was removed prior to paint.
Paper patern and first piece of Sound material cut out.
Use a heat-gun and the results are awesome (at least to me). The material shrinks down to all the reliefs in the floor.
Last shot of the peddal board installed.
I've been following this thread forever it seems; fantastic job doesn't seem high enough praise.
Soon enough you'll be out there trying to dodge flying bugs from desecrating that paint.
Kudos my friend
AA has the floor sound pads already cut to size.
Got to work in the garage this weekend. The air-box is installed.
I was lucky to find a new old stock Bosch Blue Tip antenna for 914 on ebay (but I'm sure these antenna's were used for many other models too). Even came with the two keys.
Started to repl internals on the original 914/6 transaxle. Repl all front and rear bearings, side bearings, syncros, and of course converted to side-shifter. I saved the old shifter, linkage, internal selectors and rear cover.
Big wrench is a must.
Back together.
another pic of finished transaxle.
I received the restored gauges from North Hollywood Speedometer; their work is beautiful. The combo gauge is original, the speedo is new 914, and the tach is '70 911E (I asked NHS to move the redline to 7200 to match the Distributor). I'll keep the original 914/6 gauges.
Gauges installed.
Magnificent.
I am really admiring your work, this car is turning out absolutely gorgeous!
I have two questions for you:
1.Since I see you are using ALOT of NOS parts, what are you using for seals?
2.What did you do for a dash? Is that an original or a recover? If it is a recover, what is your opinion of the quality?
Peter
Pete-
Thank you sooo much for the compliment. I've seen your work so I'm humbled that you approve.
The seals (weatherstrips) are all genuine. I've looked at the repros which are good, but I believe there is no substitute for OE. Of course the problem is they're always expensive, and can be challenging to locate.
The dash is genuine, however I believe this is one of the last production runs which Porsche made proboble in the '80's but I don't know that for a fact. I bought this dash from Camp 914 about three years ago.
Are you building another 914?
Eddie
Eddie,
For the time being there is not another car in the works. But, that doesn't mean I am not accumulating all the appropriate parts. The chassis is the easy part to find. The parts are another story.
I have to agree with you 100% there is nothing like OEM...and that is one of the reasons I am biding my time...collecting as much OEM stuff first, rather than paying up for it, when you need immediately in the middle of a build. Made that mistake once, easier to have as much collected before you start.
I was curious about your seals, if you were using aftermarket would have liked your opinion, but, you just reinforced my thoughts, buy original.
Same goes for the dash...keeping my eye out for a REALLY good early dash. The one that went into my car was NOS as well, had it for at least 12 years.
Keep up the great work on your car, I look forward to seeing the thing getting finished.
Peter
Been workin on the six, but slackin on the pics. Here are some updates;
Gagues rebuilt by NHWS, and odo set to 0. I gues that makes this six TMU! Oh well... I never knew the true miles anyway.
Gauges installed.
another dash pic.
Lower dash, new leather steering wheel and some of the NOS carpet pieces installed.
starting headlight install.
The other side.
Headlight completed with new Hella's, hardware atc. These are a BIG PITA to adjust!
the otherside. Also PITA to adjust.
6 new rubber tits to hold the lower covers in place. They also require slight adjusting of the metal tabs in order to make the gaps uniform.
Gaps look good. This was a 6 hour project. I'm shure the factory workers were more efficient when installing the headlights.
Other side gaps.
Man I cant wait to start my 6 journey, Just like you've done only Canary Yellow
Truly Awsome
ebay score. a NOS Bosch blue-tip antenna w/ keys for the 914 (and others I'm sure). These were probobly used on many cars of the period. Surprisingly, this car had a blue-tip on it, but it was trashed.
[attachmentid=197837]
a little more work in the front trunk.
Original Porsche Fox wheels, 16x7 refinished by Harvey. Anodized outer rim surface, satin inner rim surface and mat black centers. I added the valve stem supports and the orange lettering
rear
Holy Shit!! It's a roller. I think it's been five years since this car sat on its own wheels.
WOW! Extremely impressive! That is one of the most beautiful labor's of love I think I have ever seen. As previously stated, and obviously some of the most meticulous attention to detail I believe I have ever seen.
Congratulations on your project, you must be very proud. It looks like you are down to the short strokes.... New Years unveiling?
WOW looks like it should be on the new car showroom! GREAT work!
I'm a picky old bastard. But even this makes me look like a slob.......
Great looking Eddie; looks like you will be on the road by the Hangover Run Jan 1
Going through your work just now was quite a ride. I do not have the right words to say to you on your car but that is one CLEAN mother.
Bob
This thread is like crack, I just cant stop looking at it
Eddie, your car is amazing! Great work!
Wow, this car is sick!!! In a good way of course...a very good way. Please keep the updates flowing.
Amazing work, really first rate.
Makes me want to roll my cars off a cliff.
Out of shame for not measuring up to this standard.
True Excellence Eddie.
You, not the car.
It becomes the product of your diligence;
a testament to achievable restoration.
Outstanding Job, I can appreciate the effort you are going through and I hope you are enjoying every minute of it.
What size tires are you running on the 16x7's"
Dave
After reading Marv's thread, I just thought this one should be bumped as well. Two of the most interesting builds I have seen on this site.... Along with Chappy and Rick's Alien.
I'm doing an original six and want to let you know that yours look superb! Great job....Any more photos of how you did the black on the targa bar and sides? When did you cut the holes for the trim?
Is the wooden dolly strong enough to wheel onto a flatbeb or was it just used in a shop?
Thanks for the compliment.
Sorry, the pics of the side vinyl are the only ones I have. The holes in the body are original. I cut the holes in the vinyl with a very narrow exacto knife after the vinyl was glued in place.
I built that wood dolly with my kid in about an hour. I would not trust it to use on a flatbed. The bare chassis was on a flatbed three times; for that I used four regular furniture dolly's with no problem. BTW, a bare chassis can be carried easilly by four adults.
I will post some new pics when I figure out how to use my new camera and PC.
Please post some pics of your project if you have a chance and good luck with your project.
Eddie
???????Anyone?????????
What's the status of this build? I miss reading about the updates!
Ok; I've been lazy about updating this post. No more excuses, so on with the engine compartment.
New plastic stopper's...
Test-fitting the heat exchangers to the motor just to make sure there weren't any surprises since I want to install the engine with them off to assure no damage to those beauties.
Also you can see that I machined a little off of the ribs on the valve covers. I know you can do half only (where the suspension consol is tight) but I thought it looked cleaner to shave them evenly.
Getting things ready to go together.
BTW, the rear bumper and new OE top installed now.
Looking good from the under-side. Side shift conversion completed and adjusted perfectly. Cables, ground-strap etc. all connected
Exhaust has never passed through those beautiful heat excnagers...
Very nice!
Perfect.
Your knack for acquiring NOS treasures is staggering. Like everyone else, I keep waiting for updates and when they happen I always end up going, "OMG, he's found those too!?!"
mike
stunning...
One of the most incredible builds I have ever seen. My hat is off to you and I am bowing. I just love this thread and it is the example I hope to follow when it is time to restore my '71 914-6. Just leaves me speechless. I can't wait to see more pictures - please.
UPDATE PLEASE
Beautiful restoration! I'm sure the results are spectacular in person, there doesn't appear to be any short cuts taken. Your commitment to the high quality of this project is inspiring.
WOW!!!! Fantastic job!!!!!!!!!! Since you are in Rossmoor, that means I may be lucky enough to see it on the street !!!!
I am in the east side of long beach by the 405/605 interchange.
BTW what size tires did you go with? The profile looks great!!! I will be going 16" wheels as well.
Thanks to all for the kind feedback. I am sorry I have not been good about updating this thread. Rest assured, I am making progress, hopefully I will get back to more pics soon.
No real secrets to report on sourcing parts. Ebay is a great source and I couldn't have done this level of restoration without Auto Atlanta.
Thanks and sounds like we're very close to eachother. I hope to be on the road by year-end.
The tires are Michelin Pilot Primacy 195-55-R16. I test fitted them while the original car was still on the road. They fit great, and I like the look of these on the 7" Fuchs. I believe these are standard for the Mini Cooper??
I am expecting wheel-spin as the contact patch on the 195's are minimal. I will know the extent when it's on the road.
9146FAN,
Your attention to detail is amazing,Really nice...
I own a really clean six,How did you attach the fuel
rail line to the body?? Only one Original clip is holding mine.
Where did you find them??
Take Care,Alan
Eddie,
Thanks for the reply.Ive been looking for the clips
to no avail.. Does anyone have some out there??
Again really nice job on your six.You look like
a detail guy like me.
Alan
I have just been thro all 13 pages and suddenly it's stopped....It really is an inspiration to us all. I guess this is what they call "Museum Quality"! Do hope it goes even half as good as it looks. Well done Sir.
Any chance of an update? PLEASE.
Camera with updated pics was lost for a while and found by our son. Thanks for all the requests for updates, here are a few:
Rear axles; NOS Real 914/6 CV joints, replated hardware, new washers and clips:
Believe it or not... NOS 914 Sun Visors, perfect for this project:
New Sigla (made in Austria) windshield, New OE aluminum moldings, new OE clips, and of course a NOS correct early-type slim mirror. Local installer did the installation:
Interior including NOS carpet and a NOS s
Leather Steering Wheel; I collected all the pieces separately. Auto Atlanta was a good source for some of the hard to find carpet pieces, and the only source for a perfect wheel. Horn button is old but a very nice one. Aluminum thresh-hold trim is reproduction.
914/6 No, 2145 is finished. First drive was to Glenn and Ron's 914 swap-meet (sorry, forgot the camera) but it was a great time.
Second time out was to local PCA Concourse. I pulled in looking for spectator parking since I was not entered and I wasn't a PCA member. The local president was working the entrance, looked at the six and asked if I would park at the entrance of the display. I was honored to be able to park there. After the judging, the awards were announced. To my surprise, my six was honored with the people's choice award.
After the event, I went online and joined the PCA...
Awesome build. Congrats!
Congrats!! Beautiful car, well worthy of the award!!
Eddie,
Really Nice..Congratulations..
Alan
Hooray! Beautiful teener.
Saw you driving through Sunset Beach Sunday, actually I heard the engine first; just missed you as I was crossing North Pacific.
Looking good !
Did you or will you have the car dyno'd? Just curious how much HP that six is making.
Congrats on completing a wonderful car. Very happy to hear you have it on the road. Thanks so much for sharing all the details of the build with our community. This is truly one of the finest restorations ever to hit this forum.
I don't know who I hate more, you or Sawtooth.
Just kidding.. Absolutely beautiful restoration, congrats!
That is an amazing six!
Fabulous build and a great bonus to the 914 community to have such a minter back on the road!!
OOPS....I ain't pushin' buttons too gud this morning.
200 hp at the wheels should be easly doable. I'm no big fan of the S cams for a road car but they do pull bigger numbers than my Solex cams at the top end.
Here's a dyno graph on a similar motor. I have a couple sessions on different ones
& the numbers are about the same.
Way way cool, very impressive.
Ferg
What . . . A . . . Car!!!!!
Congratulations. Truly one of the most impressive restorations I've seen. It was fun to follow along.
Enjoy it.
mike
I have seen Eddie's stunning tangerine dream a few times at Cars & Coffee in Irvine. Let me tell you it's way better in person than in the photos. The car is better than any 914 that came out of the factory; it really is flawless. It has caused me to only bring my 911 to C & C as my 914 would look so ragged in comparison, and mind you, my 914 is pretty nice!
Great restoration and an enjoyable thread to say the least.
Nick
I am humbled at all the support and compliments I've received on this board. Making this thread has kept me moving on this project even though there was plenty of times I took a break.
This project could not have been completed to this level without the 914World community; you guys are great. Thanks very much to all!
After this build, I now realize why 914's are not as popular as other models to restore. You really have to be crazy to spend this much time and money on a 914. In the end, I am very very happy with the results. I promise to drive it regularly and do my best to keep it looking great.
I've been a regular at Irvine CC as a spectator but it's a real blast to drive this car there for display; lot's of lookers and lot's of questions.
Thanks again for all the looks and compliments. You all are great!
When are you going to drive it around town neighbor? I wanna point and show the wife and tell her thats my inspiration.
Just spent about an hour going thru this thread. And I must say..........WoW!!!! I enjoyed every minute, this is absolutly an awesome car. Well done.
Very nice work! Keep this car in your family and your time and money spent will
be repaid multiple times over.
John
This is one of the finest -6 restorations around; I just heard it has a new owner
