After a lot of work I finally primed the interior compartment today.
I stripped off the paint
Installed Engman's long stiffener kit,
Redid the speaker hole patch in the fire wall
Made a hand throttle
This is the speaker hole patch before and after
Paint srtipped and cleaned
And Primed
I just bought this new spray gun last week its a Devilbiss Plus. I've always like the
the old school guns with a pressure pot but this new gun is awesome. The delivery
is much like my older ones but atomizes so much better.
man, i wish someone could help me with that!
ive got weld/patching needs and am on the fence about paying some shop huge $$$ to do the floorpans, hell hole, and engman's kit install...
any volunteers? lol
That is a great job Craig! Have you decided about the spray on sound deadener for the firewall? I think having mine sprayed on both sides really helps (and I still plan to use that B-Quite I bought last year as well).
Looks great Craig, keep the pictures coming.
Hi Bill (Grimstead).
dude! you da man!!
Cool Craig!!
Nice to see you again.
Good Luck!
Nice. I love the look of a clean painted interior.
Post more pics!
Thanks for the reminder Bill.
Yeah! More pix!!
So you dug up my thread. Ok I'll post some more pics tomorrow as I've got quite a lot more done.
Thank you for all the good comments.
Thanks Toon. I remember see your engine compartment and my jaw dropped in awe.
Very nice job. I was considering using Quite Car before I saw your job and after seeing you use it I bought some. I'm going to spray it in the interior cabin, front and
rear trunks, engine compartment ,and underneath. I'm going for a quite comfortable car because me and the misses with be going to a lot of places with it.
nice repair Criag - I'm so glad that you replaced that speaker hole with a proper patch.
When you're painting interiors, trunks, or engine compartments a very easy way to mask the odd shaped parts like wire harnesses, steering wheels, or shifters is to wrap them with aluminum foil. It's cheap and easy to apply and remove. With tape at 6-8 bucks a roll a couple dollars of foil goes a long way.
Very nice work Craig. What was your choice of primer, and how does it fit into your paint method?
I was under the impression that the type of primer had to match the paint method used (single stage, multi-coat, etc), so I've reached a stopping point.
I've narrowed the primer down to either Epoxy or Polyester. Since it looks like you used chemical paint remover I suspect you went with an epoxy primer.
Keep up the good work & pics.
Thanks Stephen
I used PPG DP40 epoxy primer and had good luck with. I'm planning on using a primer surfacer over it then block sanding it then a sealer before the top coat.
You have to make sure that all the primer you use is compatible with each other and
your top coat.
Ok guys here is some more.
On to the front where I install a sway bar with Enmans swaybar supports. I then added some more weld to the front panel and wheel house because I replaced those years ago after a accident. I removed the fenders because the doors gaps were to wide and it made it a little easier to work on. They came off easy because I braised
them on before.
I had to remove the head light box because when I put it in before it rubbed with the corner of the hood.
As it turn out it was to wide so I had to shorten it and now its just right
With the fenders install
I thought it would be a good idea to check and make sure everything lined up with the hood, headlight doors and ebrows, and the fenders before I finalized everything. As it turned out everything looked good except the hood gap on the passenger side headlight door. So I added to the hood with some lead. Sorry I started taking pics after I had the lead on.
Hear it is done along with the drivers side.
Thanks Steve for the tip about using foil. I never thought about it but that would work pretty good and yes it is cheaper than tape.
This is a great thread. Thanks for taking the time to post.
Ok I've been bad about updating my progress its been awhile but its coming along pretty good. So here is the front end primed with PPG DP 40.
My wife came out and said I'm board is there anything I can do.
So I said hmm do you want to strip some paint and she said ok.
I was painting a wine rack for work and when I closed the garage door it pushed it over and fell on the car and made a dent but I was able to metal finish it without to much trouble.
This is how I chose to do the spoiler. I cut off the ends and mounted them on the rear fenders. I mixed up some fiberglass resin and took some mat and shredded it and
mixed it in with the resin used it to blend it into the lid. You have to make sure you get all the air pockets out of the resin or you could have trouble later on. Then I used body filler with fiberglass strands to finish it.
Here is how the ends look like.
There you are, hiding on the third page...
The car is looking great, I really do admire your level of detail on everything you do be it your car or my house
Alright I'll see what I can do
Rear end ready for 1st coat of primer
Rear end primed with epoxy primed
Next I sprayed some primer surfacer and a guide coat to aid with sanding
I put the suspension back on the car so I can push it in and out of the garage while wet sanding and painting. After over a year on jack stands here is the mess that was created.
Boy what a mess.
Craig
send these pics to info@wcr09.com so I can make your "start" file
nice work by the way
Craig: My car has been on the stands so long that I done major cleaning under it 4 times.
