Here is the latest gearbox I am building for someone. It is an F-N-X-HBf box and I wanted to show how easy it is to lock out 1st in a 4 speed box. I have heard that there are people that charge a chunk of change to do the same thing....I think that is wrong as it is way easy. All you need is a rear gasket, tubing cutter and a section of 3/8" copper tubing (1/2" shown as I bought the wrong size).
Here is the FNXHBf stack (Ooo, purdy).
Here is the shift rod end for 1st that needs the sleeve to lock it out. I removed 1st gear completely other than the gear on the input shaft as you need it for reverse.
And here is the section of ~2" copper tubing. You need to keep the slider for revers. It looks like the sleeve will hit the slider, but it is just the angle of the pic.
This could easily be done by anyone with limited experience.
Cool Evil...
I did the same thing to mine. Also installed an H gearset and fliped the others.
Very easy procedure. These are so easy to work on why would anyone pay someone to do it for them?
David
Is that the one we did at my place last month or another using the same method?
Cool stuff either way
T
Nope, this is a different box.
I was referring to the lockout modification as being easy and not worth paying big $$ for, I still understand when someone pays ME to do thier gearing and such.
When you guys say that you flipped other gears, what combo do you like best?
When Brad Mayeur did mine, he said it was no big deal, I can see why now.
I have the F- flipV-flipN-flipH setup, can't complain so far. Been running over 400 HP through for a while now. Nothing like hitting 100 in 2nd.
Mark
That seems like a tight grouping in the upper gears. Quite a bit of distance between 1 and 2 as well according to my chart.
What tire size are you using in your charts? 245/50?
Tire diameter of 25"
So based on this info, with a 26" tire, and a 7k rev limit... we could hit 60 in F gear? on a stock 901?
Dang, I am really short shifting.... Think of the 0-60 times... mid 3's!!
I think mine is a (1st gear delete) tight 1st, second, and third group. Then 4th is a big jump, a flipped H for freeway cruising.
Running errands has never been more fun.
Dr. Evil, I really like your ratio charts.
Is there a way to tell what gears I have by rotating the input shaft and counting rotations of the output shaft? or visa-versa? I'm curious what my 2 backup trans axles are running.
Looks good to me Mike....
thanks..
Michael
Hey Doc, are you still rebuilding 1st gear lock out 901s without the 1st gear installed? Have you encountered any issues with this method or is this your preferred way to setup a locked out 901?
I like this idea just installing the hunk of metal 1st gear spacer without the gear or needle bearing, but just want to make sure I'm not going to run into issues down the road.
. . . use one of these from a '65-'66 911/912 or a '67-'68 912 for your 4 speed modification . . . .
WANT
Never an issue. Toss 1st gear, keep the race as a spacer, and put a section of tube on the shaft so that 1st position is locked out. Easy
For those of us running a locked out first gear and taller gears: Is it easy to revert back to 5 speed and gear ratios for a turbo Suby?
Very easy. No special nothing needed.
Thats what I hoped, I'll give it a try. Thanks Doc.
BTW, anyone who doesn't own the Evil rebuild DVD is missing out big time. Didn't realize rebuilding a 901 would be so hilarious. Nice work
Thanks for the endorsement, Mark
who has best price on this knob???
found this...
http://www.autoatlanta.com/Porsche-Shift-Knob-Push-On-Type-Fits-1967-1971-4-Speed-Parts-PN-B90142401300.html
thanks
jim
