I have weber 40 idf carbs with a bugpack linkage. Is there supposed to be a spring on the accelerator pedal that returns the pedal idle or are the springs on the carbs the only springs to return the pedal to idle?
Thanks again-
Steve
Spring on Carb is the only one. I had similar problem and had to get a heavy duty spring to accomplish the idle release that I wanted. If you want, I can take a picture of what I did.
I have Webers, but use 3 springs; one at the end of the cable and attatched to the firewall, and one on each carb between the linkage and the base plate. For me, it helps fully close both carbs at idle.
I made that little piece to accomodate the large spring. We have a store called Tractor Supply Company where I got them. I bought several in different lengths and stiffnesses before I go this one right, but I will tell you, my throttle snaps back.
He's got a single and you have duals. If you add a spring run one at the center of the linkage. If you run a spring at each carb you have to get the geometry the same on both. Otherwise the difference in spring pressure will tweak the linkage and your carbs will be out of sync.
Too much spring can be worse, for the car, than no spring at all. Before you spend the money, check the pedal bushings and the cable itself. The Cap'n
Cap'n, I am relatively new to this, and I did this in an effort to solve the problem of poor return that I was having. Can you elaborate on what potential problems I could have by putting that big spring on? Thanks.
x2 w/the cap'n on this one. the cable pivot piece has a shaft that inserts into the pictured tube in the the box assem. the pivot tube may still have the old plastic bushings (that have been removed on this box). the bushings wallow and the pivot shaft sits cockeyed and can feel bound up. i chased a slow to return to idle issue. bigger springs only made matters worse. i installed the 2 small bronze bushings that come in the bushing kit and the pivot was smooth as glass. you may note a loud sound while pushing on the pedle also.
k
The pedal itself should provide some spring action. New ones do, worn out ones don't.
The bushings in the pedal cluster require regular maintenance. Brake fluid will cause the plastic bushings to swell and bind. Annual inspections can warn of impending failure. A few people on the forum offer cluster rebuild services.
The Weber tech manual for VW applications suggests adding a return spring to the carb linkage arm to make sure it closes. This is for dual carbs, obviously.
Zach
