I got off from work early today and thought I would finish up my alluminum sunvisor mounts, I was wrong. I picked up an extra decel valve and decided to open it up. I plugged mine because It was all jacked up. I know most dont use their decel valve anymore, but thought if nobody had opened one up and posted it here before, this might help the ones that still have them.
In pieces:
Diaphram was in good shape considering it is 30 years old.
Top portion with the adjustment tube
and back together again after a really good cleaning, some crimping and JB Weld.
See how far you can throw it.
Just kidding. Interesting that they used a diaphram almost identical to a carb accelerator pump diaphram.
B
I almost did Brad. Figured I didn't need the damn thing, why not screw it all up by taking it apart.
Yah,.....give it the "float test"......
Why would one want to remove the decel valve, for what purpose???
Is that an early decel valve? Mine on the '75 was more of a flattish disk kinda thing.
Decel valve? I thought that was for fuel pressure, at least thats where I adjusted mine.
That is a decel valve, the FPR is similar. The 1.8 FPR has three fittings on it (fuel in, fuel out, manifold vacuum) and is not adjustable; the 1.7 and 2.0 FPR has two fittings (fuel in, fuel out) and is adjustable. The adjustment on the DV looks like the one on the FPR, but the fitting is much bigger on the FPR.
The 1.8s (except possibly some very early ones) had the flat disk skaped DV. The one shown here is a 1.7 or 2.0 one. (Or maybe that early 1.8.) The DV got hard to find a while back, so it is possible that the 1.8 one was retrofitted to other systems. I think the 1.8 version was still available for a good while longer because of its use in the Bus engines.
--DD
So what does a decel valve do??
Keeps the throttle from slapping shut too fast, leaving unburned fuel in the system....aka "smog shit"....
So is it better to have than not have?
