ok, sooooo, on my way back from Jeffs tonight,
there is this off-ramp (45mph limit) with all new asphalt and nice and all and i decided to push it a bit.
i was going through at a bit over 100mph and the car was sticking well and all, no under- or oversteer, no sliding,
BUT
the front suspension felt somehow wooble-y.
i sort of had to do this (not that extreme mind you)
as the car was slightly rocking.
weirdly enough it didn't feel unsafe as the tires were sticking.
what is that?
could it be the sidewalls flexing? i'm running 225/50x15 on 7" rims.
shocks toast? (did the push down test which they passed).
comments are apprechiated,
Andy
Make sure the nut (threaded collar) that holds the shock in the strut is tight. Check all the nuts & bolts holding the suspension to make sure something hasn't come loose.
Push down test only works on '72 Buicks. You can have completely toasted shocks and pass the push down test on Porsches (my experience anyway).
Hey Andy,
Can you try to describe it a little better?
Bumpsteer maybe?
How are your susp.bushings?
cheers,
Jeroen
perhaps you simply reached the limits of your setup. maybe 90 mph is a prudent rate of speed in that section.
kevin
Hey J...
Could be the adjuster on the rear of the torsion bar is a little loose fitting
Andy, don't see how it could be your tires. 225's on 7" rim should give you a pretty straight sidewall and you'r got 50 series tires.
Make sure all the suspension bolts are tight. Check for worn rubber bushings.
Could be that Kevin's right, taking a 45mph ramp at 100+ could make a GT3 feel a little strange.
What is your ride height? 914s don't like to be too low.....
I have had this on a different car it turned out to be tie rod ends.
just guessing here:
too fast, cold ground, cold tires (not evenly heated due to alignment/corner balance or lack of), oil on new asphalt.........take it easy, that car of yours is too damn nice to go getting up close and personal with the guard rails
I have felt the senastion you describe, but not in a 914....
Could it be that your front suspension just isn't super tight - so your shocks are a little soft, and you only have 19mm torsion bars right?? WHat do you have for a sway bar? What springs do you have in the rear?
For street tires, I think you might just be pushing the limits - I usually consider it safe to do double the posted limit for any given bend (bends only) - if you toook that thing at a real 100 - you were probably doing pretty well to make it....?
Did you tap the brakes to plant the nose before the turn?
Have you taken it at that speed in a different car?? Is it really smooth - or is it just smooth at 60?
Was it windy?
I'm clutching at straws now....
Like Fiid said, it could have been as simple as wind at that speed. Or some undulations in the pavement that you couldn't quite see.
If you didn't feel it through the steeringwheel, bumpsteer is out
Tie-rods too... you'd felt it on the steering wheel
I think that leaves you either bad bushings and/or bad shocks...
cheers,
Jeroen
I think he left out the fact that the chassis is cracked at the front control arm mounts. I'm almost 100%+ that the car needs front shocks.
Oh.. James.. the bounce test works on stock 914's (just not as well as a Buick)
B
He also installed a nice used set of Bilsteins on the rear.. combine this with worn Carrera shocks and you *might* get a funny feeling...
Hey Jeroen!! (good to see you) The early 911 site you did for Hayden is awesome.
b
Why didnt you weld the crack? or reinforce it???
Dont have a clue about suspension (trying to figure mine out right now.. I think I need 140lb springs.)
andrew
so, back to the topic:
Why is my car "wobbeling" during high speed cornering?
anyone?
Too many variables Andy. You will have to make the car do it while I ride with you. It could be multiple things.
B
Pre 74 struts can get "wallowed out" at the hole in the base where the ball joint connects causing erratic behavior going into and coming out of a turn. Solution = new style joints and pins.
Not sure if that's your problem but it is another area to check when eliminating causes.
are you talking about the notched pin style ball joint?
He has late 84 up Carrera struts.
B
not enough spring rate? 19mm bars are stock on carrera's too right?
It's political....your car can't decide if it wants to be a left wing liberal or a right wing nazi.....
If it only pulls to the left it could also have Nascar Disease.....
If it only pulls to the right, you're a member of the NRA.....
The car is well balanced with his current setup. I'm betting it has a bad shock or single bad tie rod end.
B
I'd start by checking the lug nuts then jacking the car and check the wheels are rotating without wooble, check bearing freeplay, then check for anything loose under the car and do a systematic retorque of all suspension parts. Then move to the back and do the same thing. Seems like looking at the car would be better than asking us when we can't see anything. I know the guys can float lots of ideas but you gotta lay hands on it to heal it.
Dave
miles, he was doing 100 and i wrote 90. i NEVER exceed the speed limit
kevin
Kevin
It's hard to keep up with you.
I'm not driving that fast all the way to Cali in June. If we add in orange, yellow and red cars we'll be cop magnets.
Dave
I NEVER thought I would see Dave Hunt utilize the BS smilie...
B
FIXED!
ok, it was the ball-joints ...
we (brad and i) put the car up on the lift last night and the pass. ball-joint had about 1/2" play. yuck
replaced both sides with brand new ball joints and now the car goes straight again!
took a 15mph offramp at full throttle and it felt like on rails. no wobble anymore.
now a need a good alignment and corner balance ...
Andy
