Printable Version of Topic
914World.com _ 914World Garage _ Where is Your Battery ? Poll
Posted by: jsayre914 Nov 6 2008, 11:33 AM
Since My tray fell off now is a good time to consider relocating the battery. Where did you put it and do you like it there. Would you move it to another location?? My car is not a conocours. Its a daily driver. Any feedback
Posted by: Rick_Eberle Nov 6 2008, 11:42 AM
I think the stock location in the engine bay is the most practical place for it for a daily driver. You would lose way too much space if it's in the boot/trunk.
Posted by: Vacca Rabite Nov 6 2008, 12:04 PM
I'd move it to the rear trunk for a quick fix just so you can get in a little more driving time. Then I'd weld in a new battery tray and go back to the stock location.
Zach
Posted by: AvalonFal Nov 6 2008, 12:11 PM
Mine is in the upper right corner of rear trunk. Keeps the weight nearly in the stock location. Fits without interfering with the top storage and gives much needed room to work in the engine bay.
Paul
Posted by: iamchappy Nov 6 2008, 12:13 PM
In the trunk with other essentials...
Posted by: SirAndy Nov 6 2008, 12:34 PM
QUOTE(jsayre914 @ Nov 6 2008, 09:33 AM)
Where is Your Battery Pole?
On my optima, they're both on top. One has a - next to it, the other one has a + next to it ...
Andy
PS: On a more serious note, now is a good time to clean up that mess in your hell hole! Then, if reusable, tack the tray back into the stock location or get yourself a new tray.
IMHO, for a daily driver, the stock location is the way to go ...
Posted by: 7275914911 Nov 6 2008, 12:39 PM
QUOTE(AvalonFal @ Nov 6 2008, 12:11 PM)
Paul
I also have spare, jack, jack stands and two tool/parts bags in my rear trunk and can still carry top. A PO had the ECU in there to but I recently moved to cabin firewall. At same time made new hole for battery wiring w/ grommet soe's to not have wires running thru targa top hole(another PO upgrade). Also added battery tray soe's I could get rid of those nasty bungy cords.....
Had thought about moving battery back in engine bay but really like the extra work room.
jkp
Posted by: McMark Nov 6 2008, 01:46 PM
Stock location. Why would anyone move it? (serious racers are excused from the question)
Posted by: 7275914911 Nov 6 2008, 02:36 PM
QUOTE(McMark @ Nov 6 2008, 01:46 PM)
Maybe...running without rain tray battery stays dry therefore eliminating one of the main causes of death for our vehicles??
jkp
Posted by: Krieger914 Nov 6 2008, 03:04 PM
When TRG corner balanced my car they commented on how close my car was than other 914s that had the battery moved. They only needed to raise my RF up a few turns.
Posted by: jsayre914 Nov 6 2008, 03:08 PM
Where does the battery go in the cabin?? Just curious
Posted by: SirAndy Nov 6 2008, 03:24 PM
QUOTE(jsayre914 @ Nov 6 2008, 01:08 PM)
Passanger Footwell ...
Andy
Posted by: jwang Nov 6 2008, 05:18 PM
Wrong login
Posted by: PanelBilly Nov 6 2008, 05:33 PM
I used to keep mine on some scrap wood on the floor of the garage. That was before I split with the wife. Now I don't know where she keeps it, but I can think of some places where she can put it....
Posted by: 1970 Neun vierzehn Nov 6 2008, 06:50 PM
Where the engineers decided it would provide the best location to offset the drivers' weight, keeping it close to the center of the car to keep the moment of polar inertia low (as opposed to in front of the wheels, i.e early 911), and where it could do the most structural damage should it bleed battery acid (though that problem was probably not forseen).
Paul
Posted by: LarryR Nov 6 2008, 07:21 PM
mine is in my shed
Posted by: 9146986 Nov 6 2008, 08:15 PM
Stock. Why loose any luggage space? Unless it's a racer, then put it where you want.
Posted by: MikeSpraggi Nov 6 2008, 08:59 PM
The 914/6 is in the stock location. The track car is in the rear trunk.
Posted by: TC 914-8 Nov 6 2008, 11:45 PM
Mines up front next to the radiator Next to the fuel pump. I didn't move it, it came that way from the PO. he used welding cable thru the tunnel and back to a buss bar at the stock location. plenty of grounding straps at the Batt. , Trans, and Engine. I never have any Starting issues what so ever.
Posted by: DBCooper Nov 7 2008, 06:21 AM
QUOTE(1970 Neun vierzehn @ Nov 6 2008, 04:50 PM)
Where the engineers decided it .... could do the most structural damage should it bleed battery acid (though that problem was probably not forseen).
Wait a minute, "not forseen? These are GERMAN engineers, yes?
Posted by: morgan_harwell Nov 7 2008, 08:29 AM
Engine Bay in a new location
Since this is my Daily Driver, I wanted to keep all engine related stuff in the engine bay: batteries, oil tanks, ignition modules, oil coolers, etc.. Trunks are really handy for things like: bookbags, gym bags, car cover, groceries, MotoCross helmets ...
The oil tank is in the stock battery location. So I put the battery on the other side of engine bay. I took the old rusty battery stand out, flattened it, then used it as a template for a new battery stand, which I formed into a mirror image of a stock battery stand. I then welded it in place on the left side of the engine bay before repainting the engine bay. I then put a new stock battery tray on it. Yep, I had to perform Hell Hole surgery, too.
This is an old picture, there is an Optima Red Top in there now. My last 3 Die Hards were Die Easys
Posted by: McMark Nov 7 2008, 11:42 AM
QUOTE(7275914911 @ Nov 6 2008, 12:36 PM)
jkp
Um, Gel Cell batteries? Much easier to replace a battery than run cables all over the car, fabricate clamps, etc.
Posted by: 1970 Neun vierzehn Nov 7 2008, 02:47 PM
QUOTE(DBCooper @ Nov 7 2008, 04:21 AM)
I'd surmise that the engineers who designed the 914, those who were involved with the tooling, fabrication and construction of these cars, and the designers who wrote the specifications for the various sub-assemblies and outside contractor sourced parts (Bosch,Mahle,ATE,Thiessen Steel,etc.) did not foresee these cars lasting this far out from their build date.
Paul
Posted by: jsayre914 Nov 7 2008, 03:28 PM
QUOTE(1970 Neun vierzehn @ Nov 7 2008, 03:47 PM)
Paul
I still cant believe mine starts up every time I turn the key.
Posted by: effutuo101 Nov 8 2008, 02:06 PM
Trunk location with the other gear. And the top still fits without issue
Posted by: zymurgist Nov 9 2008, 09:23 AM
I don't actually own a 914, but the one I maintain has the battery in the rear trunk. I can't say that I recommend the location, but you do what you have to do to keep the car on the road.
Posted by: jsayre914 Nov 9 2008, 11:24 AM
The battery tray seems perfect, now that im looking at it. It was never welded at all three rivets at the top lip into the fender, and three rivets at the bottom lip right on the shoulder. I guess it was a quick fix, and over time vibration took its toll. I am down a little between the hood rust and the battery falling off, The car will go on stands tonight.
Posted by: JRust Nov 9 2008, 12:09 PM
Stock location on both of mine. I prefer it there as opposed to relocating it. If you need the space for something else I guess I can understand moving it
Posted by: wbergtho Nov 11 2008, 01:09 PM
My V-8 car has the battery in the front trunk and my stock 76 has the battery in the stock location.
Posted by: Todd Enlund Nov 11 2008, 01:17 PM
I don't even have a battery.
Posted by: SLKWrx Nov 11 2008, 03:48 PM
These things need batteries?! Ugh.. no wonder it won't start!
Posted by: BIGKAT_83 Nov 11 2008, 04:50 PM
Stock location works for me........
Posted by: Vacca Rabite Nov 11 2008, 05:06 PM
QUOTE(jsayre914 @ Nov 9 2008, 12:24 PM)
Between this and your front trunk "fix" I think we need to assume that your PO was actually a DAPO. When you put the car to bed for the winter, start inspecting the car with a critical eye. God only knows what else your DAPO may have "fixed."
Zach
Posted by: OU8AVW Nov 12 2008, 03:17 PM
QUOTE(BIGKAT_83 @ Nov 11 2008, 02:50 PM)
WTF?
Wow......
Posted by: Justinp71 Nov 12 2008, 03:27 PM
QUOTE(OU8AVW @ Nov 12 2008, 01:17 PM)
WTF?
Wow......
No Sh!t... That is cool, what trans is that hooked to?Stock axles?
Posted by: tommy914 Nov 13 2008, 10:17 PM
Where is my Battery?...... What?... You know something I don't?
You talking to me? I'll show you where my battery is!
Posted by: zymurgist Nov 14 2008, 05:30 AM
Knock it off. I dare you.
Posted by: Rob Ways Nov 26 2008, 06:20 PM
I've kept it stock on my "stock" car, but moved it to the rear trunk on my last AX car. It really doesn't make a difference if you maintain your car and rust issues.
Posted by: naro914 Dec 2 2008, 04:59 PM
QUOTE(iamchappy @ Nov 6 2008, 01:13 PM)
where did you get that battery bracket/stand/whatever you call it that's holding your battery in place? I could really use one like that!
Posted by: Rob Ways Dec 3 2008, 06:58 PM
With an Optima battery, I had a flat piece with 2 teeth in the grooves at the base of the battery on both sides. The pieces bolt to the trunk floor. To close the trunk with a top in the back, you can make it if you don't go too high.
Posted by: J P Stein Dec 7 2008, 04:24 PM
In the rear trunk.....but it could go bout anywhere.
Posted by: okieflyr Feb 4 2009, 07:05 PM
My gel cell is mounted on the the engine crossbar down loooow!
Posted by: jt914-6 Feb 6 2009, 07:22 AM
Front trunk..........had the room and to put a little weight up front.
Posted by: Maltese Falcon Feb 7 2009, 04:57 PM
rear trunk
Marty
Posted by: PThompson509 Mar 17 2009, 09:33 AM
QUOTE(racunniff @ Nov 11 2008, 09:57 PM)
That's what I'm doing too!
Posted by: benalishhero Mar 18 2009, 05:17 AM
Original position in my '74 2.0
Posted by: GreatPumpkin Jul 14 2009, 08:46 AM
here is mine
Posted by: ghuff Jul 14 2009, 09:48 PM
I have to do something about the battery situation in my 914 this weekend. I think I may run a deka battery where the yellow car has it's located.
Still use the targa, and since it is a sealed battery, stuff can be put in back.
I had to cut my tray out and refuse to install a new one.
That tray collects dust/dirt/debris that soaks moisture and will just rot out again from the back like mine was starting to, and you can not get under it to clean :|
Posted by: derepaskos Jul 15 2009, 01:52 PM
Rear Trunk
Posted by: thomasotten Jul 18 2009, 08:31 PM
Mine is in the front and had I not put it there back in '89, I don't think my car would be structurally sound. I did install a new shelf, so maybe one day it will return to the rear - but only with a sealed battery!
Posted by: Brent Sep 15 2009, 06:00 PM
QUOTE(PanelBilly @ Nov 6 2008, 04:33 PM)
Thank god I made off with all my 914 goodies. She just has my DVD's and Yearbooks.
Posted by: brp986s Sep 15 2009, 09:22 PM
frunk
Posted by: campbellcj Oct 16 2009, 11:51 PM
PC680 in stock location. It is light and my tray is solid so I did not even consider moving it.
Posted by: jsayre914 Mar 10 2010, 02:35 PM
I forgot to update this thread, since the upgrade
