take a look guys, by the way I did get her home the other night, and i beat the snow.
more
last ones
Zach said he would loan me a compression tester, i guess that is my next step.
thanks for looking
joseph
Been a while since I had FI on the car. Could you tell if it was coming from one of the breather tubes for the heads? Any smoke out of the tail pipe while running? I can't imagine anything other than excessive blow by causing that - which the compression test should show you.
Tons of blow by... Either the rings are shot or the exhaust valve guides are shot, or both..
Good thing a response I made didn't get posted..... I questioned the compression test.... My lack of skilz...
I would like to know about the "blow by" you (especially Jake) mention. What is it exactly and would it cause that much oil mess? (Just asking for my education).
When combustion gases go flying past the rings they can only escape through the PCV and the head vents. The gases pick up oil and oil vapor(s) along the way giving you a nasty mess (as witnessed above).
Bad rings can create blowby as they allow gases to fill the crankcase, forcing an oily mess from every orfice...
The same thing happens with bad exhaust valve guides as the exhaust gases pass between the stem of the valve and the valve guide, pressurizing the rocker box and then the crankcase..
So, when are we going to rebuild your engine
My engine does the same thing when a hose falls off the head breathers or any other part of the pcv system. Check all your hoses and connections...sometimes they crack or loosen up down by the cylinder head.
Hey Joe,
I'm not in class this week. Next week I have Monday off, but it gets insane again for me right after that. If it is sucky outside, we can warm up your engine by running it in the garage with a hose hooked up to the exhaust pipe. If your valves have not been done in a while, I'll bring feeler gauges too.
If it comes to it that you need to rebuild, all my resources are at your disposal. If you get good numbers, we can look and see if there is something else funky.
I won't lie. I want to help you rebuild your engine. I've got all this crap now, and I want to use it.
Zach
How did your engine run before this mess? The stacked vacuum elbow being disconnected would have been a MAJOR vaccum leak. Is this your oil leak problem. No.
anyone know where this came from??
oh, the oil is from your Head vent hoses and the lines going into the intake manifold
Rich
by the way, if it is bad rings...
the only constraint for finishing a top end rebuild in time for Hershey in April is machine shop wait time. I know two machineists in town that can deglaze and score the cylinders. Get rings from Jake. Your bottleneck will be heads if (okay, when) they need work (which they will if its valve guides).
Options options. this need not take all summer if it needs a new top end.
But, i'd start calling head shops now and asking about wait times.
Zach
Way off the deep end, but did you check the oil pressure switch? if its loose
it will cause a problem of splashing oil around. It's located by the distributor.
The switch would not pump oil in to the air cleaner... You will find you have low compression when you do the check.
I just finished the compression test..... drumroll......
#1 107
#2 97
#3 120
#4 120
Keep in mind, i just did my first valve adjustment, by myself. Zach came over and showed me the ropes...
....Thanks Zach......
....so I either did somthing wrong or the left side of this engine is BEAT. Do you think i should attempt to adjust the valves on that side again or pull it? I am pretty sure i did a good job on the valves, note to myself (always have valve cover gaskets when doing adjustments, PO had some kinda silicon there, and i dont have anything to put back on em yet. Small mess on the garage floor, but that should not effect the compression right.
lastly give me an opnion about lucas oil additive i just bought 2qrt. Dont do it or what. I figure get new gaskets add lucas, drive it for 100+ miles and do another test.
can someone slap me I am trying not to pull this engine
Well, since the two on the samer side, 1 and 2, are low I would consider that ther head may have a problem in seating, twisting, etc. Did you check the head nuts on that side for tq? Is there any reason you should have bad rings? Did you put a tsp of oil in the bad barrels and then recheck to see if that improved the numbers? = bad rings.
Just a few thoughts
The AAR valve you are using the 4th photo
is common to a 1.8 how does that work for you???
I know it's off topic!
The combination of oil in the air cleaner and low numbers are pretty much all you need to know. You need to do a top end rebuild at the very least.
I haven't been around these motors as much as Type I's, but I have yet to see a motor that had bad rings that didn't have a bad cam.
Ah ya, if you are getting oil in your filter you are pressurizing your case via bad rings. Time to pull the 1,2 side and at teh very least put new rings on. Thats is all else is OK.
I would think it unwise to do just the 1-2 side. If you are gonna bother you might as well do both sides, get the heads looked at, check the cam for wear, etc...
