Hi All -
Is anyone remaking/selling the 9146GT firewall mounted shoulder harness mounts?
Thanks!
Scott S
hint try mc master carr
Yep, been there. This is as close as I could find:
http://www.mcmaster.com/#pull-handles/=1kq0z3
I do not even remotely trust them as they are all drilled and internally threaded vs being a threaded rod with a nut on the end.
Do you really want to risk your life using door pulls
Just found the fabrication instructions on the GT site...
What GT site? Armando's? GT Racing?
T.C.
Hi TC -
- over at Armandos... I will look up the exact link (I always forget about how much stuff is on his site!)
Scott, I go to Armando's site regularly. I just looked and saw the set that Armando has for his car, but I didn't anything about fabricating a set.
T.C.
For sure you can fab these things up...but, if you are looking to purchase them they are most certainly available on:
http://www.mittelmotor.de/content_e/angebote/activeNews_categories.asp?catID=12
I have never seen them available in the US.
Don't forget that when you are installing these there should be a square plate welded onto the firewall where these are secured.
Peter
Hi TC -
Here is the link - scroll down to the comments below the picture menu...
http://www.pbase.com/9146gt/factory_original_9146_gt_parts
