I thought you guys out there with steering rack spacers would find this interesting.
If you space the rack higher, you should think about having a steering coupler (that rubber bisket) that is shorter.
That was the situation I was in and went looking for options. One is that on the "other" 914 site there is a guy that makes billet units that are the correct height. However I feel there are a couple reasons to retain something rubber.
After doing the math, I wanted a coupler that is 1 1/16" thick. (the stock one is about 1.33" high)
Now I've got to admit that what I came up with isn't totally an original idea. The site "nlaparts.com" sells a coupler for the 356C that's pretty much the same, but made to match the height of the original 356C coupler.
What I came up with is to use two early VW steering couplers. This gives a combined height of 1". They are only about $11.00 each.
The original 914 bolts are a little long, but could have been used. I purchased new 8mmx1.25x35 grade 8.8 (the original bolts are grade 8.8).
I've also ordered from Pelican new lock tabs (not shown in the photos).
So, here are the photos;
The only thing that would make it better is if somebody with a lath made up the steel collars to the correct length (1"). (Racer Chris has a lath! hint, hint)
Wes Vann
Make sence , I have the turbo tie rods and the spacers just in case and I wondered about a possible solution to the extra rack height. A 1/16 of an inch could be easily offset by the inside steering rods. The spacers cut on a lathe wouild be a luxury , they could be made from aluminium tubing at the right inside / outside dimenions using a plumbing tubing cutter , filed for clearance making this a possible option .
I sure others have addressed this issue with rack spacers , maybe we will hear from them.
Jaxdream
Very cool Wes.
That seems like a much better solution. Substituting a solid metal couple seems like a terrible idea. They factory must have wanted some damping.
Ever measure a hockey puck???
BTDT, it works like a charm...just drill out for the bolts, recycle the steel tubing (after you grind it down) and you get a 3 dollar spacer that fits tight.
Rich
Doesn't the oem biscuit have a metal cylindrical perimeter for bracing? I'd be concerned about distortion or even stripping out the holes. Plus, possible movement between the 2 layers. Afterall, you're probably not running 155/80/15 tires - there will be alot of force acting on that thing.
Maybe a better solution would be to cast your own part using Flexane. Flexane is available in different hardnesses. I've read about Boxster owners using this stuff to make engine mounts.
