Printable Version of Topic
914World.com _ 914World Garage _ help me ID my 914/4
Posted by: john914/4 Aug 5 2009, 09:44 AM
I purchaced a 1972 porsche 914/4 a few weeks back and am having a bit of trouble getting the numbers broke down. the VIN is 4722919064. it was manufactured on 06/72. the karman plate in the drivers door reads NR. 2439512. L9H. the engine was out of the car and it has a number stamped onto the block AW009121. there was a set of webers with it and I found the following on them 40 IDF 19. ? the car seems very original with very minamal rust. it cam from michigan. the color is a gold color under the red paint. I bought a 1970 914/4 a few months before I ran into this one and being the other (1970) is body is completely rusted I am going to use it for parts. I have purchaced a number of books on the 914 and some kind of point me in a direction but not very through. I am under the impresion that this is a 1800 VW bus engine. and maybe a off color. I am prepairing to rebuild the engine and I want to be able to get the correct parts. will these webers work? any help would be very greatly appeciated. this is my first porsche/VW 914. I have a 1972 El camino restored by myself so I do know cars. but these little guys are a mystery right now. thanks for reading. before I leave one more thing that I thought was interesting is the front of this 914 has no grills for the driving lights and is rounded unlike the flat fronts of all the 914's I have seen below the rubber bumper its plain and rounded (2 piece).
Posted by: type47 Aug 5 2009, 09:54 AM
Welcome!
According to this site: http://w2.wolfsburgii.com/t2e.htm your engine is a 1.8 73-74, however, due to the age of the engine, it could be built into just about any configuration by a previous owner (PO). I don't believe there was a factory gold color offered. Could you post a pix of the bumper?
Posted by: Sleepin Aug 5 2009, 09:56 AM
19064th 914 built in 1972
Engine number not sure, unless it is AN instead of AW, which would be a 1975 1.8L
Your body color is missing a number, probably an L97H which was gold metallic.
Oh... and :welcome:
Posted by: tat2dphreak Aug 5 2009, 09:58 AM
1st
2) AW engine code is a 73-1975 1.8 from a bus. are you getting the number from by the oil filler? just to be sure.
http://www.type2.com/bartnik/enginecodes.htm
3) your VIN is a "late" 72...
The factory changed the strut housing, ball joint, caliper and rotor at VIN 4722919032, so when you go to buy parts, buy a 73 part, not a 72... mine is the same way, and every "70-72" part I've ever bought had to go back for the 73-74 version
4) dual weber 40idfs are a common carb replacement for the factory FI.
post pics, please it probably just lost the grills, but I don't know what you mean about it being flat
Posted by: SirAndy Aug 5 2009, 11:59 AM
QUOTE(rick 918-S @ Aug 5 2009, 07:55 AM)
Someone here has the paint codes listed someplace.
That would be us ...
http://www.914world.com/specs/914info.php
Andy
Posted by: Ferg Aug 5 2009, 12:06 PM
Cool, another Gold one, to bad it was color changed. Seems like a high number of gold, ravenna green, and orange cars were color changed.
Pic of my old Gold car the "Dijon Bomb"
Posted by: jt914-6 Aug 5 2009, 12:34 PM
Andy,
Here's a pic of my car's color tag. I see it is called Delphi Green Metallic. As you can see what it is called on my car. BTW, quickly changed the color to Ocean Blue Metallic (3AY).
Posted by: john914/4 Aug 5 2009, 03:34 PM
QUOTE(Ferg @ Aug 5 2009, 10:06 AM)
really nice car. I will return mine to its original met. gold. I met a friend at a car show a couple weeks back that had a green 914 as you mentioned. his car is really nice. he was from germany and living over here now.
Posted by: john914/4 Aug 5 2009, 03:38 PM
QUOTE(SirAndy @ Aug 5 2009, 09:59 AM)
Andy
thanks for the info the site has been very helpfull. I look forward to continuing to use the site.
Posted by: john914/4 Aug 5 2009, 03:41 PM
Andy
thanks for the info. the site is fantastic
Posted by: john914/4 Aug 5 2009, 03:50 PM
[quote name='tat2dphreak' date='Aug 5 2009, 07:58 AM' post='1199589']
1st
[quote]before I leave one more thing that I thought was interesting is the front of this 914 has no grills for the driving lights and is rounded unlike the flat fronts of all the 914's I have seen below the rubber bumper its plain and rounded (2 piece).[/quote
below the front bumper is 2 metal panals with no openings. the lower panal has 2 small dimples and thats it. I have not seen these on any other 914 I have looked at. I take it when I get parts for this car I can refere to it as a 73, 1.8 liter VW bus engine? are these considered the opossed cylinder flat motor type 4. are th 40 idf's worth installing and is there rebuild kits for them.
[/quote]
Posted by: tat2dphreak Aug 5 2009, 04:16 PM
the carb rebuild kits are readily available, I recommend aircooled.net. what is the car running on now? if it's running on the L-Jet, then leave it... if it's not running, and carbs will make it run... well, connect the dots
Posted by: SirAndy Aug 5 2009, 08:45 PM
QUOTE(jt914-6 @ Aug 5 2009, 10:34 AM)
http://www.914world.com/bbs2/index.php?act=colors&sortby=sCode
L99A Delphi Green Metallic (Saturngelb-Metallic)
From the Page:
The German color names are added in (small print) where available.
Saturn Yellow Metallic is what it's called in German.
Andy
Posted by: john914/4 Aug 6 2009, 09:05 AM
QUOTE(SirAndy @ Aug 5 2009, 06:45 PM)
From the Page:
Andy
thanks I found the code and it is origially to be a gold met. I will paint it as such as I restore it. again thanks
Posted by: john914/4 Aug 6 2009, 09:16 AM
QUOTE(tat2dphreak @ Aug 5 2009, 02:16 PM)
thank-you for the info. when I purchased the car the engine and trans were in box's. needless to say I was and am worried. I hope its all there. there was one box with a set of weber carbs (40 IDF's). the guy had purchaced a new set of jugs and pistons but the bill of sale says they are, VW 96mm piston and cylinder BUS, 914 type IV 2 liter stroke. he paid like 301.90 for these and I don't know if they will fit the engine. it appears my engine is a 1973 VW 1.8 liter. type 2. as you can see I am a little worried going into this engine.
Posted by: tat2dphreak Aug 6 2009, 09:55 AM
well, you will need to replace the crank and rods to use 2.0L pistons, assuming the 1.8 is still a 1.8, and wasn't rebuilt into something else.
if they are 2.0L pistons the pin height is for a 72mm(2.0) crank, with 2.0 length rods, the 1.8 and 1.7 used a 66mm crank and different rods with different pins.
if you are going to build the engine, I suggest getting Jake Raby's build video and studying it like your new favorite porno.
you can get it at type4store.com
if my engine was in a box of pieces I'd be worried too... but don't worry, with jake's video, and us here... we'll help
Posted by: Cupomeat Aug 6 2009, 12:32 PM
Wayne, I don't know about you, but I only get about 4 minutes into my favorite porno...
WAIT, sorry, too much info.
Posted by: tat2dphreak Aug 6 2009, 01:17 PM
no, you get your porno in 4 minute increments, there's a difference
Posted by: john914/4 Aug 7 2009, 03:25 PM
QUOTE(tat2dphreak @ Aug 6 2009, 07:55 AM)
I really appresiate your help and advice. I will check the block and get a new crank and rods if needed. I will also get the vidio. again thanks.
Posted by: john914/4 Aug 7 2009, 03:40 PM
QUOTE(john914/4 @ Aug 7 2009, 01:25 PM)
I wanted to show you the front of this 914. I have been having a hell of a time figuring out how to download photo's to the site I'll give it a go.
Posted by: john914/4 Aug 7 2009, 03:55 PM
QUOTE(john914/4 @ Aug 5 2009, 07:44 AM)
Posted by: john914/4 Aug 7 2009, 03:56 PM
QUOTE(john914/4 @ Aug 7 2009, 01:40 PM)
Posted by: tat2dphreak Aug 7 2009, 04:08 PM
I think you are talking about the stock Valance being rounded, where others are flat...
others have gone to aftermarket air dam, or LE-style Valance
I think your 914 looks awesome, btw!
Posted by: Pat Garvey Aug 7 2009, 05:47 PM
Where the heck did that front bumper come from?
Pat
Posted by: tat2dphreak Aug 7 2009, 06:22 PM
QUOTE(Pat Garvey @ Aug 7 2009, 06:47 PM)
Pat
I'm guessing it came with the car when he got it, Pat...
I kinda like it, never seen one like it tho
Posted by: john914/4 Aug 8 2009, 08:30 AM
QUOTE(tat2dphreak @ Aug 7 2009, 02:08 PM)
thanks. the front valance was on the car when I purchaced it. it is unusal as I have never seen one. I don't know if I will keep it on as I like the style on my 70 parts car. I may put the rear valance from my 70 on as well. it looks pretty cool. but there is a factory hole on the drivers side and it appears that there is some sort of electrical hook in? me and my brother can't figure that one out. maybe a battery connection. I don't know. again thanks for you valuble knowledge with my car. I am also thinking of putting the 1.7 from my 70 in it to get it on the road while i rebuild the 1.8 over the winter. again thanks for all your help.
Posted by: john914/4 Aug 20 2009, 09:08 AM
QUOTE(tat2dphreak @ Aug 7 2009, 04:22 PM)
Pat
I really appreciate all your help and I would like to ask another question. on my center console on the floor there is a VDO boost, press. gauge. I have not seen this in any other 914 so far. what was the reason for the gauge. It apears stock. thanks.
Posted by: tat2dphreak Aug 20 2009, 09:32 AM
dunno. stock console had oil temp, voltage and a clock.
I pulled out the voltage and clock on mine, for oil pressure and CHT,
maybe that is an oil pressure gauge? or if the person was going to turbo the car, they may have indeed wired a boost gauge.
Posted by: john914/4 Aug 26 2009, 10:37 AM
QUOTE(tat2dphreak @ Aug 20 2009, 07:32 AM)
thanks for the reply. I believe I will change mine as well. need better info then those gauges. again thanks.
Posted by: Cupomeat Aug 26 2009, 10:52 AM
Nah, leave the boost gauge and wire it so that upon full throttle, the gauge reads 2bar boost.
It will impress the ladies...
Posted by: tat2dphreak Aug 26 2009, 11:13 AM
QUOTE(john914/4 @ Aug 26 2009, 11:37 AM)
I used this http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=310-012-M82&catalog_description=VDO%20Oil%20Temperature%20Gauge%20(2%201%2F16%20inch%20diameter%2C%20120-300%20degrees%20F)(Use%20323-055-M82%20Temperature%20Sending%20Unit)
this http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=VDO-350040&catalog_description=VDO%20Oil%20Pressure%20Gauge%2C%2080%20PSI%20(2%201%2F16%20inch%20dia)
be sure and use the dual http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=VDO-360025&catalog_description=%3Cfont%20face%3D%22Verdana%2C%20Arial%22%20size%3D%222%22%3EVDO%20Oil%20Pressure%20Dual%20Sender%2C%2080%20PSI%20(retains%20the%20use%20of%20the%20green%20oil%20pressure%20light%20on%20dash)%20sender%20%3Cbr%3E%20%3C%2Ffont%3E%3Cfont%20face%3D%22Verdana%2C%20Arial%22%20size%3D%221%22%3E%20(for%20use%20with%20green%20light%20on%20gauge)%3C%2Ffont%3E, so you will have the stock light + the gauge
I also used the CHT from VDO, but at this point I can't recommend it since I can't get the F'n thing to work right.
edit: almost forgot, you will need the little adapter rings, these are slightly smaller than stock. the adapter rings can be had from egauges.com cheaply or you can make your own
Posted by: Grelber Aug 26 2009, 12:44 PM
Why not just add extra gauges? There's plenty of room:
