1975 914 1.8 track/autocross car. Exceptionally solid and straight California body. No evidence of previous body damage or rust. Full bolt in roll cage, race seats and belts. Weltmeister sway bar, fuel cell and Weltmeister transaxle mounts. Dual Weber 40 IDF carbs on 1.8 block. There is a dent in the left front fender near the turn lens. The stock wire harness is unused but still installed and a race electrical system has been installed. This car has a lot of potential for any intended purpose, including returning to street use. $6500.
The battery tray and hell hole could use paint but both areas are original with no rust perforations or previous repairs. This is a rare, solid, straight body.
Very solid, straight chassis at a price probably cheaper than repairing the rust in your current project.
Still available, still a solid, nice car. Brad
Runs great!
pm sent
just seen this car again yesterday while at Brad's. A very nice solid straight car.
Bump!
bump for new price
Please tell me a bit more about the car? Was a new cam added with the carbs? Head work? Any suspension or break modifications other than the sway bars? Thanks in advance for your reply.
This car came from the Long Beach CA. area in the mid 90's. It has been used as a DE and autocross car for the Illinois owner and always stored inside.
I don't know anything about the engine build but I am assuming it is near stock.
Weltmeister 19mm front sway.
Turbo tie rod ends.
Stainless brake hoses.
Sparco race seats.
Simpson 5 pt. race belts.
Autopower bolt in roll cage.
Autometer tachometer with memory.
VDO oil pressure, head temp, oil temp.
The VDO electronic speedo is not operating.
I have not verified the torsion bars or the rear spring rate.
The main strength in this car is the condition of the chassis. This would be an excellent car to return to the street, I have all the necessary components available from my extensive stock of used parts. Brad
bump
Still have it?
Available and no rust perforations or previous rust repairs. Nice solid, straight chassis.
