Printable Version of Topic
914World.com _ Member Vendors _ I can fix Outside Door Handles
Posted by: URY914 Mar 23 2004, 08:06 PM
Is your outside door handle broken? Just wait, it will.
Send it to me and I'll fix it better than new. I make a piece that replaces the small mounting tab that bolts to the door. You can see this piece when you look at the handle from the side. The cheap pot metal breaks off and the handle flops around.
Pelican Parts sells replacement handles for $204.75!!!
I'll fix it and add a new plastic slider (that you provide) for $75.00.
Here is a picture of a fixed handle. This handle has the original plastic slider.
PM me for address and any questions.
Paul
Posted by: swood Mar 27 2004, 10:11 PM
Paul, Does this mean you can fix the flapper/handle too? Tell us more...
Steve
Posted by: URY914 Mar 31 2004, 06:31 PM
Steve,
I can change out the flapper handle but this is just a replacement that I buy just like you can. It can be replaced while I'm doing the the mounting tab fix.
You can buy the flapper and the plastic slider, than send them to me with the broken handle and I'll put it all back together better than new.
The mounting tab is the item that breaks and really spells the death of the handle up until now. I have developed a means of repairing the mounting tab.
Paul
Posted by: URY914 Dec 29 2004, 11:39 PM
QUOTE (URY914 @ Mar 31 2004, 04:31 PM) |
Steve, I can change out the flapper handle but this is just a replacement that I buy just like you can. It can be replaced while I'm doing the the mounting tab fix.
Paul |
The flapper handles are no longer sold by Pelican.
If your flapper breaks, you got a problem.
Paul
Posted by: dcicchetto914 Jan 11 2005, 08:07 PM
Pelican Parts is not the only place that sells 914 parts, you can also get parts from Performance Magazine , and Tweeks and they both have websites.
Flappers are a dime a dozen, if you go to any 914 dismantling place they will have a crapload of them for dirt cheat. (they also have a crapload of borken doorhandles because they dont understand that there not worth anything.)
Drue
Posted by: rdauenhauer Feb 19 2005, 08:13 PM
Paul was it you that was also considering offering these refinished for instance in black chrome or powdercoat?
Posted by: rdauenhauer Sep 12 2005, 03:55 PM
Paul, From the Pic Im not sure I understand the fix. T
The problem is that the 8mm post breaks off and the ususall fix is to drill a hole through the body of the handle and use a bolt and nut, which is protrudes into the cavity that you reach behind to pull the flapper handle (does that make sense?) What are you doing in the image?
Posted by: URY914 Sep 30 2005, 02:53 PM
Let me post a broken handle picture so you can see what happens.
Posted by: URY914 Feb 12 2015, 05:51 PM
I just repaired another handle. This one was for a 914 owner in Sweden.
If you have a few spare handles laying around you should think about getting them repaired. I don't know how long I'm going to keep doing this.
Posted by: jack20 Feb 18 2015, 12:44 AM
QUOTE(URY914 @ Feb 12 2015, 03:51 PM)
My tab broke off, driver side. Looks as though you have machined a new integrated "tab" that bolts into the same space. Am I correct? If so, how can I send my handle to you for repair?
Thanks,
Jack
Posted by: URY914 Feb 18 2015, 12:52 PM
Yes that is what I do. I hand fit an aluminum piece that replaces the pot metal tab. I've been doing it for years and have never had one fail on me or returned. I PM'd you my address.
Posted by: North Coast Jim Dec 12 2015, 08:23 AM
QUOTE(URY914 @ Mar 23 2004, 09:06 PM)
Paul
I've got two handles that need repair. One is broken and the other is only a matter of time. While their out of the door i's like to get them refurbd. How to get in touch ??
Posted by: URY914 Dec 12 2015, 02:41 PM
QUOTE(North Coast Jim @ Dec 12 2015, 07:23 AM)
Paul
I'll send you a Private Message.
Posted by: NeunEinVier Dec 29 2015, 05:09 PM
QUOTE(URY914 @ Sep 30 2005, 02:53 PM)
A photo of a broken one would be awesome, thanks.
Posted by: URY914 Dec 29 2015, 07:04 PM
Posted by: URY914 Dec 29 2015, 07:37 PM
This is a repaired handle.........
Posted by: RacingDreamz May 16 2016, 03:10 PM
Ury914, Brian Cheney referred me to you about broken handles. I also have a 'broken' pot metal tab on my passenger door. What's your cost to replace that piece. The plastics in the handle is in good shape. Just that metal tab is broke.
Posted by: mburnley Aug 27 2022, 08:06 PM
Paul
Is this something you still do?
