This mounts the release below the E-brake handle. Everything you will need is included. A cover for the release in the trunk is also provided. Please see http://engmanparts.com for details
A look at the mechanism.
Dumb question that may have already been answered: Will this work if your trunk is locked??
This is really for the rear reflector that so many of us have added. It can be used with the stock trunk pushbutton lock - but the lock will not function. In other words if you lock the rear trunk it will still open by pushing the button inward, with this cable release installed. I have done this.
M
Does this mean you can shave the rear trunk button (and still open the trunk)?
similar question about the shaved trunk button, ive taken out the button and filled up that center portion between the rear lights with that red transparent panel that displays Porsche, so the question is will i be able to open the trunk front within the cabin?
Any pictures of this installed?
Here are pics of it in my 73.
Trunk
M
Pull handle for the release - located under the E-brake
M
I know this is off the subject But I am a long time admirer of the 914 (15 +years) but only been a owner about 1 yr I have this cream puff of a body but some one drilled holled for this reflector I was wonder where do I get one (heard 911) but if this is right what year. How do I install it . Does it require electrical? Where can I get one of those trunk releases also?
Looking at your trunk picture: Is the cable entering the trunk directly beneath the mechanism ?
How is the cable fed to the cabin mount ?
I like your set up !
QUOTE |
Looking at your trunk picture: Is the cable entering the trunk directly beneath the mechanism ? How is the cable fed to the cabin mount ? |
I like the set up; does the installation require the engine be removed ?
QUOTE |
I like the set up; does the installation require the engine be removed ? |
I bought this and it went in in about 25 minutes. Very slick!!
This guy, Sorry I can't remember your name, ROCKS!!!!
kp
Anyone have an extra porsche reflecter they willl part with
i would like to get a couple of these you can email me at Dreamzwvr@aol.com or call 1-317-431-3621 ask for Drew thanks
Just a few left..... Don't say I did'nt warn ya....
M
2 remaining....
M
Hi,
I put in your kit but I think I have the latch lined up funny. It
sticks a bit and unless my kids or wife assist with the lid it can't lift.
Any ideas on how to adjust the two latch parts.
I remember you are an engineer and have a way with things mechanical.
I, on the other hand, am just a musician.
Thanks for any advice.
kp
QUOTE |
I put in your kit but I think I have the latch lined up funny. It sticks a bit and unless my kids or wife assist with the lid it can't lift. Any ideas on how to adjust the two latch parts. I remember you are an engineer and have a way with things mechanical. I, on the other hand, am just a musician. Thanks for any advice. |
i have the same exact problem, but i have a question. does the trunk need to release (pop-up) a little to allow the catch to clear? my trunk doesn't do that so when i pull the release and then let it go, it re-catches. not to mention it looks like someone put some weld on the catch to build it up. should i file it down?
Check a couple of things...
1. Rear hood pin alignment - this is adjustable.
2. The 'catch' located in the rear trunk lid is adjustable also up and down - it is screwed in and there is a nut on the back. You may have it either too loose or too tight.
It really sounds like the problem is in this area.
M
your kit was installed in about 20 minutes. it's great, i love it! i recommend it highly. i agree on the problem being in that area. so is the trunk supposed to pop-up a little to allow the pin to clear? i always had to push the button and lift at the same time to open the trunk.
Yep it will pop up - but only a little - just enough for the latch to clear the catch.
Still have 2.
M
i guess my springs are sprung? my trunk doesn't do that. will have to replace. thanks again! your kit went in with no problems! my car has the problem!
M[/QUOTE]
[/QUOTE]Take the release portion off of the cable and check to see that the lever moves freely between the two halves. Lossen the bolt if necessary and or pry the two halves apart some if needed. The lever was checked here for this, but perhaps it needs some minor adjustment.
The oyther possibility is your spring on the latch located on the trunk lid latch. This may be too tight. It is adjustable.
The mechanism works great. It is binding up because the top is not lined up. If I take it off the lidd and press it in it will fly when I pull the magic nob. I have something out of line.
kp
I have been able to purchase some of the componets in smaller lot sizes, sooooo these will be back in 4-6 weeks.
I do have 1 left currently.
M
I have bought two items from Mark, the trunk cable release, and the third stop light. Both items are what the doctor ordered! Mark is a honest man, he delivers exactly what he advertises... Great products Mark!
You da Man!
Keith
Cables arrived!
Back in production!
M
PM sent
I have these in stock. As well as all of my other stuff as well.
M
Hi,
Do you have any of these left I am interested in buying one.
Thanks
Yes - PM or email me.
Thanks
Mark
One please, PM'ed
Chap
PM's sent.
I have several of these currently in stock.
Are these still available?
Mike
Finally got around to needing this and now I cannot see it on the Engman website.
I'd be very interested if you had another run also...just got a reflector in great condition ready to go in!
Add me to the "are these still available" list.
I installed one of these not long ago that had been sitting on the shelf... great stuff!
only thing I'd say was incorrect with the instructions were the drill sizes were too small to feed the cable through, I had to stepp up 1-2 sizes. but that might have been a slightly different cable... once installed it worked great though...
I'd take one of these as well.
I would also like to buy one, ASAP! Let us know if it's possible to manufacture another batch with a certain # of committed buyers???
I'd be interested too, if we need to make a waiting list.
Sorry for the delay - been out of touch - lost a good friend this last week - probably the best machinist I have known - sudden heart attack - and he was healthy too, kinda hit me hard.
As to the cable release - I am looking for a replacement cable comparable in quality to what I had. So far I have bought 3 differnt ones only to find the wire without enough pull, solid wire and of course the wrong cable ends. I am continuing to look. Should I find one I will post it on the board. My goal was always to supply well built and long lasting componets, and the cables thus far have not met my standards.
Thanks
Mark
Hey Mark,
Thanks for getting back to us and sorry to hear about your loss, I know it's never easy when friends pass away unexpectedly; hopefully his machine work will live on in all the vintage cars his parts are no doubt a part of...
I know you'll keep us updated so whenever you get around to it is fine, just FYI I'll probably buy a front trunk air block off kit at the same time as well, but I'm sure you keep those in stock.
Mark,
I hope you find a viable cable soon - my solenoid failed and I really want to replace with a manual solution.
Richard
Please add me to the waiting list once you find adequate components.
Thanks
David
would like to be in line for one as well, thanks!
"Me too," if there's another run. Stop me before I start raiding bicycle shops and motorcycle parts departments...
Add me to the list.
fteixeira
I guess I joined the board a little too late. I'm in too if they ever come around again! Thanks for all of your hard work!
-George
Mark - I am in need of one of your cable sets. I installed the solenoid recently and am not happy with the way it occasionally sticks. Question about the routing of the cable. I know the cable that releases the engin lid turns corners through small tubes. How does your cable run handle turns?
Please count me in too if there is ever one to be had.
I could really use one of these when they come available again. Add me to the list!
I'd like to get one as well, looking for price also.
Ok folks this is a little morbid.....
Your replying to a thread that will never be answered.
Sooooo What about the FRONT trunk? The whole metal tube thing is gone from my car and was wondering what another choice might be?
Thanks
Sean
If you need one -
Cable and tube
https://shop.914rubber.com/Front-trunk-guide-tube-only-NO-CABLEINCLUDED-914FTPT.htm?categoryId=-1
Guide tube only -
Put me on the list I could really use one. The solenoid is a joke!
Sadly Mark Bland passed away unexpectedly of a heart attack in 2010 (IIRC).
Ironically, his last post to this thread was regarding a close friend of his who died too young.
Add me to the list as well please.
Also, sorry to hear about your. My condolences.
Best regards
