My hide a way place, Relay box or other, pic |
MecGen |
Mar 24 2005, 09:44 PM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Hey
This is what I did today, I made a 12volt power distribution center, in the pass side foam (spare). In the pic everything mounts to a stainless steel plate/sheet , I plan to finish the box in the same way and add a hinged cover (spare parts from a scrapped coffee truck). The relay board is from a Suzuki, has 3 fused 12volt, 30amp relay controling 1 fused 12 volt switched and 1 30 amp 12volt switched output (which I split to 3) Just to be clear : 12 volt batt constant = 12volt 12volt when key is in run position only = 12volt switched. Everything is nicely protected by a maxi 40 amp, which I mite downsize when I figure out what its for.... (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) Big radio, sub alarms Engine swaps, ecm controle, fan harness junction, HEATER Or just use the box to hide your personals.... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Fun project easy to do. Hope it gives ideas. Regards Joe Attached image(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 06:34 PM |
