Will this work?, Tired of blowing dust. |
Pugbug |
May 5 2005, 11:54 AM
Member Group: Members Posts: 449 Joined: 14-February 05 From: Victoria, BC Member No.: 3,604 |
My engine shroud blows the air straight down and blows dust everywhere, so I want to try these baffles I made up to blow it out my rear.
Can anyone see a reason why this would be a bad thing? Attached thumbnail(s) |
brant |
May 5 2005, 12:01 PM
914 Wizard Group: Members Posts: 11,623 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
don't have any personal experience.
and don't want to sound negative either... but off the top of my head, I would think that the shroud would increase motor temps (oil and head) because it would radiate heat back and because it would prevent some heat from escaping... again, don't take this negative and maybe temp isn't an issue for you. Nice fab work though! brant |
mattillac |
May 5 2005, 12:19 PM
robots! Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 |
maybe drill some holes in it or add some louvres(?) so it's more like a diffuser than a
shield. |
rhodyguy |
May 5 2005, 12:28 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
wouldn't be easier to get the proper air guide plates for your engine application?
k |
mattillac |
May 5 2005, 12:31 PM
he already made the deflectors tho. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) and buying stuff costs $$$. (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
mattillac |
May 5 2005, 12:33 PM
louvers...
Attached image(s) |
tat2dphreak |
May 5 2005, 12:34 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
I was thinking the same... if you have trouble finding them cheap, LMK, I know a guy who parted several cars last year and I have bought several parts from... |
Pugbug |
May 5 2005, 12:47 PM
Stock air guides won't fit this shroud, so I'll try these, but keep a close eye on the temps.
Attached image(s) |
nebreitling |
May 5 2005, 12:49 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
interesting exhaust.. are those the 75-75 stubs turned backwards? giving the mating angles, i thought they would not work in that orientation?
SirAndy |
May 5 2005, 12:54 PM
Resident German Group: Admin Posts: 41,636 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) moving air under the engine helps with cooling, that's why the factory added the "flaps" to the lower firewall in later years ... you'll probably see higher oil temps ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Pugbug |
May 5 2005, 12:56 PM
I have no idea what the exhaust is from...Was on the car when I got it, along with twin cherry bomb mufflers. They are history now, but man was it ever loud!
I think I'll take Mattillac's suggestion and put some louvers in the baffles. I think that will minimize any radiant heat created. I'll also paint them flat black. Thanks for the input all. |
Pugbug |
May 5 2005, 05:52 PM
I've modified the tins....Added louvers, and cut a wider opening in the front......Thanks for the tips guys.
Attached image(s) |
StratPlayer |
May 5 2005, 05:55 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Ya didn't waste any time. Looks good, hope it works for you... (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Reiche |
May 6 2005, 12:08 AM
Member Group: Members Posts: 169 Joined: 13-October 04 From: Vista, CA Member No.: 2,934 |
Looks great. With your fab skills, I think it would be easy to make some tins that replicated the factory ones in function. Right now, your cooling air is cooling the top of your engine well, but it is missing the hottest parts of the heads and cylinders: the bottoms. If you can channel the air around those bottom-side curves a little (like the factory did) I think you will run much cooler. At least your temps would be more even, which is as important. I wouldn't use the stock type 4 bottom tin though. A type 1-style bottom tin would do (basically a flat plate under the "cleavage" between the two cylinder barrels.) |
messix |
May 6 2005, 12:15 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
ot
nice cj hood. whats the rest of it look like [what it mounts up to] i have a '75 cj 5 built for the trail |
jgiroux67 |
May 6 2005, 12:56 AM
Guitar Shredder Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 |
I'm interested about that exhaust. What year engine do you have?
McMark |
May 6 2005, 01:02 AM
Am I the only one who doesn't understand the motivation for this? You "blowing dust"? WTF?
Pugbug |
May 6 2005, 06:23 AM
McMark;
The shroud on this engine bows a lot of air straight down, so whenever I encounter gravel or sandy roads...(Like a construction area) often I have to stop and wait. When I do there is a major sand storm rising from under the car. That is me waiting on the other side of those gates. Josh; The engine was originaly a 1.8 litre. It's been increased to 1910cc. I'm not sure, but I'm thinking the exhaust may be bus parts?? Attached image(s) |
URY914 |
May 6 2005, 07:50 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,563 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
You should email RicerChris pictures of those headers. He is the expert in 914 exhaust systems. I've never seen a seen one like that before.
BTW- we have two Pugs. Great dogs. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Paul |
davep |
May 6 2005, 08:21 AM
914 Historian Group: Benefactors Posts: 5,141 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
It appears you are missing the lower air guides. This may cause uneven cylinder cooling and that may be a bad thing. What I'm thinking of is that the bottoms of the cylinders will run much hotter since the airflow bypasses them. This could cause the running cylinders to be slightly out of round.
Lo-Fi Version | Time is now: 14th May 2024 - 04:03 PM |
