Won't start, What to check? |
ThinAir |
May 26 2005, 11:11 PM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
I'm trying to get the newly overhauled 2.0L Type IV engine started for the first time. I know I have fuel pressure and spark. I have not pulled a spark plug yet to see if I have fuel in the cylinders, but I suspect that the FI system is not powered so the injectors aren't firing.
I won't be able to work on this again until Monday and I'll be spending some time with the wiring diagrams between now and then, but I figured it was worth asking here for some pointers of things to check. I've got a brand new Bowlsby ignition wiring harness. Besides the engine cranking, but never even coughing (much less firing), the only other indication I have is that I have no oil pressure indicator light. I've checked all the ignition and FI harness connections, including the trigger points and the grounds under the air filter. Anyone got any ideas? This post has been edited by ThinAir914: May 26 2005, 11:16 PM |
Lo-Fi Version | Time is now: 30th May 2024 - 12:22 AM |
