Aeroquip fittings & oil cooler install |
BravoHotel |
Jul 8 2003, 08:26 PM
Member Group: Members Posts: 153 Joined: 5-March 03 From: Columbus, MS Member No.: 399 |
I finally figured out a place to mount my oil cooler. The car didn't have any of the airbox stuff when i bought it (mainly track and nice day car). I think it will work pretty sweet. If I am still not getting enough cooling, I have a Spal puller fan that I can install. The lines will go thru the pass. side long. where the hot air used to go. (2) AN-12 hoses fit just perfectly...
Anyway, to the question: Anyone plumbed anything w/ AN fittings? Do I have to use teflon tape for all the threads or just leave bare? Thanks BH Attached image(s) |
Qarl |
Jul 8 2003, 08:39 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
The only problem I see is that there is no where for the hot air to exit other than your trunk. There is no vent to the "outside" world.
Eventually you will get a really hot trunk and you will get warm air leaking into the passenger compartment. The cowl inlet does not have the highest inlet pressure flow in since the inlet is parallel with the airflow over the trunk. Plus... air has to flow through . You will not get very much flow through unless you have a fan sucking air through, and then it still needs to vent out . Do this experiment... Blow air into a cardboard tube from about 6" away... you get decent airflow on the other end of the tube. Now blow into a tall empty drinking glass from about 6" away. Since the glass is already "full" of air, it comes right back at your face. Your front trunk will act like an empty glass and not much air will flow in, if it has nowhere to escape. Great idea.. great location... but it needs some more engineering. |
drew365 |
Jul 8 2003, 08:41 PM
These are the good old days! Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 |
No teflon tape on any of the AN fittings. I just finished my car this weekend and have no leaks. I would suggest buying the vise adapter to make the fittings and have the right size open end wrenches, no adjustables.
Qarl |
Jul 8 2003, 08:43 PM
Looking at your picture again... here is an idea.
It looks like you're going to run a fuel cell. Why not build a little box on the backside of the cooler with flexible ducting (similar to dryer vent tubing) that runs to the floorpan of the gas tank area and exits near the steering rack underneath the car? You can also build a mini hood scoop to capture the airflow! |
BravoHotel |
Jul 8 2003, 08:51 PM
Karl,
I am running a fuel cell and there is a 4" dia hole to the right of the steering shaft that should evacuate the hot air...plus another misc 1" hole in the same area. Hopefully, the 4" hole has some neg pressure. I will keep you posted. Attached thumbnail(s) |
Aaron Cox |
Jul 8 2003, 08:58 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
one is the acces hole to the bottom of the fuel tank. the other is.... (IMG:style_emoticons/default/confused24.gif)
john rogers |
Jul 8 2003, 09:03 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Personally I don't think there will be enough air flow for that setup. Additionally, I'm not sure if a tech inspector would pass that since if the oil cooler were to rupture you could very well end up with a lap full of very hot oil!!!??? I'd put it in behind the front bumper.
BravoHotel |
Jul 8 2003, 09:14 PM
It is yet to be seen whether or not there will be enough air flow (it is definitely somewhat of an experiment)...if not, I have a piggyback puller fan to supplement. If the cooler were to rupture for some reason, there is really no way to end up w/ a lap full of oil...all major hole into the pass compartment have been capped/plugged/plated, etc.
The main reason I didn't mount it behind the bumper, is cause I didn't want to cut into the tub...the car is just too clean. |
Aaron Cox |
Jul 8 2003, 09:32 PM
has anyone ever don a 911 fenderwell oil cooler install? put it up at the fron of the fenderwell? (IMG:style_emoticons/default/idea.gif)
Qarl |
Jul 8 2003, 09:36 PM
The 1" misc hole is for the drain for the airbox that has been removed.
Karl |
BravoHotel |
Jul 8 2003, 09:39 PM
riiiiiiiight...that make sense. I have all of the airbox stuff...just was removed b4 I bought the car.
Brad Roberts |
Jul 8 2003, 10:38 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
This area has a ton of FREE air flowing in. I had to block it off on my tube frame car because the air was hitting the FLOOR so hard it was blowing shit up into my helmet (the windshield cowl is one of two factory steel pieces on my race car) The "vents" basically exit onto my floor.
I wanted to know how much air it was moving.. so I was going down the back straight at Buttonwillow at 100+ and started moving my hand near the opening. It literally blew my hand away. I'm not sure how well this spot will work... but I know of 3 other people trying it right now as we speak. I say capture the heat and use it for the interior of the car (when you need it) B |
campbellcj |
Jul 8 2003, 11:08 PM
I can't Re Member Group: Members Posts: 4,545 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
It definitely gets air...I have no blower box or ducting and the air entering the cowl grille just -blasts- out of the defrost vents. That's why I'm gonna duct it into a more useful/adjustable location shortly. Also with an inline blower fan for when the car isn't moving or needs defrost assistance (not likely, but hey).
Brad Roberts |
Jul 8 2003, 11:12 PM
The 3 inch inline fans ROCK. This is what Winston Cup cars use for brake ducting and getting air to rear end coolers and oil coolers. The one car we sold had 6 blower fans just for the brakes (Road race car)
B |
Aaron Cox |
Jul 8 2003, 11:57 PM
i think Mountain914 is running the same setup. ask him if it works well.
Qarl |
Jul 9 2003, 12:01 AM
Bravo:
Okay Dr. Evil! |
andys |
Jul 9 2003, 10:07 AM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
Teflon tape on the threaded portion (and only on the threaed portion; keep it off of the flare) is particularly useful when frequent dis-assembly and assembly is the case. The anodize on the fittings will wear quickly leaving the thread interface bare alum to bare alum. It will gaull quickly. The teflon tape will help prevent this. FWIW
Andy |
Mountain914 |
Jul 9 2003, 10:17 AM
Too much time in thin air! Group: Members Posts: 367 Joined: 22-May 03 From: Conifer, CO Member No.: 725 Region Association: Rocky Mountains |
I think this is a great setup. I have a thermostat for the fan which kicks on at 180, and even in stop and go traffic, or a day racing, I haven't seen it get much over 180 ( I live in Colorado, so it's a dry heat (IMG:style_emoticons/default/happy11.gif) ).
As long as you don't need wipers - I don't see anything wrong with it. I can attest to the fact that it does NOT create warm air into the passenger compartment (though if I drove it in the winter, maybe I could hook something up to do that since I don't have heat exchangers... hmmmmm...) and it gets plenty of ventilation (no ram-air needed here). As long as the fan works, I think it's an ideal solution. ACK! It's raining! Oh Nooooo! What do I do??? (IMG:style_emoticons/default/rolleyes.gif) Attached image(s) |
J P Stein |
Jul 9 2003, 10:35 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
My personal preference for oil coolers is to keep the cooler below the level of the oil tank.....it would be nice to keep it below the engine sump also, but that ain't happening.....this minimizes "drain back".
Good access to the cooler also allows filling the cooler and lines rather than waiting for the thermostat to open and "burp" the system. The nose is good for both this and airflow....why reinvent the wheel? I'll pass on the teflon tape, thanks. I've had no problems with galling of fitting's theads.....the seal is not at the threads with AN fittings. |
campbellcj |
Jul 9 2003, 11:01 AM
Not trying to hijack the thread, but does anybody know why it isn't possible (or is it?) to make an adjustable oil t-stat? Most of them seem to be set for 180F but it is debatable whether that is a good operating temp for our cars. I usually hear 210-220 stated as a better target temp, i.e. warm enough to boil any water or by-products out of the oil.
Just wondering... |
Lo-Fi Version | Time is now: 17th May 2024 - 06:01 PM |
