I'm an idiot, what the hell do I do with this? |
McMark |
Jun 20 2005, 02:05 AM
You know when your clutch stops working. If you can shift, things aren't broken. |
michelko |
Jun 20 2005, 02:51 AM
Senior Member Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
Hi guys,
right procedure to adjust clutch cable and stop: Adjust the nut at the end of the clutch cable where it connect to the through out arm, so that you can move the pedal about 15-20mm see the picture Attached image(s) |
michelko |
Jun 20 2005, 02:53 AM
after that adjust the pedal stop just enough, so you can shift in reverse without grinding. Thats what the manuel say.
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
Lo-Fi Version | Time is now: 13th May 2024 - 05:14 PM |
