| Mueller |
Aug 3 2005, 05:46 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Global Positioning System speedometer
a little on the expensive side at over $500.... (IMG:http://www.nordskogperformance.net/images/products/auto/speedos/gps02160_lg.gif) |
| ArtechnikA |
Aug 3 2005, 06:04 PM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
have you priced Porsche electric speedos?
('76+ 915) that's in the ball park. i'm gonna need one when i replace my transmission, but until i can find the one i want, i'm going to have to calibrate the tach from the GPS and go by that... |
| Rand |
Aug 3 2005, 06:05 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
That's the first one I've seen that looks like a traditional in-dash gauge. Cool.
I love the features in my handheld GPS. Speedo, trip odometer, average speed, top speed, maps, routes, etc... for a lot less $$. They look different, but can be mounted anywhere with a holder. http://www.garmin.com/products/etrexLegend/ |
| TonyAKAVW |
Aug 3 2005, 06:10 PM
That's my ride. ![]() ![]() ![]() ![]() Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
Officer: "Son do you know how fast you were going back there?"
Driver: "No, I don't, my speedometer was still getting a fix on the satellites." (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) -Tony |
| spare time toys |
Aug 3 2005, 07:47 PM
hooked on grilling food. ![]() ![]() ![]() ![]() Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
They work good untill you go into a tunel or come out of a parking garage and have to hold on until it aquires the satelites.
| Mueller |
Aug 3 2005, 07:50 PM
yea, but common sense should take over until the GPS comes back up (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
| Red-Beard |
Aug 3 2005, 09:19 PM
"Ya canna change the laws of Physics" ![]() ![]() ![]() Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
I bought the Uniden GPS-RD.
http://www.uniden.com/productsupport2.cfm?...m?product=GPSRD It bought it specifically because it has a speed readout. They are hard to find, but do come up on Ebay used, once in a while. Be prepared to spend around $200 used! Very accurate. Oh, and for $500, you can get a very very good mapping GPS unit from Magellan (A ROadmate 300). The locate screen gives you direction, speed, road name, etc. I have it's big brother, the Roadmate 700. Virtually the same as the Neverlost units Hertz uses. |
| ClayPerrine |
Aug 4 2005, 05:52 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Here is the trick thing to do. Gut a stock 914 speedo, and put the guts of this in. Then it looks stock, but uses the GPS.
BTW.. I have been looking at this for months. |
| Mueller |
Aug 4 2005, 09:27 AM
they also have less expensive model that is Speed only.....it tops out at 90mph, but I'm sure that you could change that if stuffing it into a new case. |
| lapuwali |
Aug 4 2005, 09:46 AM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
For a handheld, the Garmin Gecko has a speed readout and an odometer, and it's under $80. The only trouble with it is it takes forever (like a minute) to sync up with the satellites. This is a great toy to calibrate a stock speedo. I discovered by 912 speedo reads LOW at freeway speeds (65 indicated is 73mph actual), so I may have avoided an unexpected ticket, which more than paid for the thing.
The various electronic speedos are very easy to recalibrate, and pretty easy to set up with a magnet on a CV joint and the sensor on a diff cover stud. You can get a VDO that looks vaguely like the stock speedo and a handheld GPS to calibrate it for roughly half what these guys want for their all-in-one unit. |
| ClayPerrine |
Aug 4 2005, 10:59 AM
What kind of internal drive mechanism does it have? If we can use the speed only version, and make it fit the speedo cable connection on a stock 914 speedometer, then we have a way to get rid of the whole tire size problem. It would be accurate until you got in a long tunnel or underground parking garage. |
| Type 4 Unleashed |
Aug 4 2005, 11:13 AM
CREATIVE TYPE lV ENGINEERING ![]() ![]() ![]() Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
Common sense? I own 914's, I work on my 914's, I spend lots of money on my 914's, relativly speaking, So, I don't think the term Common Sense applies, to me or any other 914 owner (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) |
| ClayPerrine |
Aug 4 2005, 11:17 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif) |
Lo-Fi Version | Time is now: 13th November 2025 - 05:35 PM |
