Electromotive pick-up?, crankfire trigger mounting? |
jhadler |
Nov 16 2005, 01:03 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Hey all,
Is anyone out there running a crank fire ignition with the stock fan setup? Where and how did you mount the pick up and triger wheel? How sturdy is it? Pictures would be fantastic! Thanks! -Josh2 |
Mark Henry |
Nov 16 2005, 01:10 PM
I've got an SDS crankfire...PITA on a T4 but it works good.
Search SDS and my name...you might find it...I never can. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) BTW if I was to do it over I'd cut down a 911 pulley (use it instead of the hub spacer) for the trigger wheel. |
lapuwali |
Nov 16 2005, 01:13 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
airsix is running a hall-effect (magnetic) setup he made by attaching the magnets to the belt pulley. Mark Henry has a hall-effect setup that uses a disc he made to replace the spacer behind the fan (between the fan and the hub), and mounted the sensor to the back side of the fan housing. Dave Hunt made a similar setup using an EDIS 36-1 toothed wheel.
For the Electromotive 60-2 toothed wheel, I'd say the behind the fan approach is the most promising. It will require that you make a wheel or an adapter so the spacer thickness is the same as stock. Dave Hunt's setup allowed the VR sensor to slide along an arc he milled into the fan housing for adjustment. A search will find photos (DNHunt, EDIS). Note that the wheel, if you fabricate one, has to be made of ferrous material, or the sensor won't see the teeth. |
Britain Smith |
Nov 16 2005, 03:04 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I am not running the stock set-up, but here is what I did to mount the sensor and wheel.
(IMG:http://www.britainsmith.com/Porsche/912Project/TurboMotor/CustomFab/images/210_0009_JPG.jpg) -Britain |
jhadler |
Nov 16 2005, 03:08 PM
Britain,
Nice looking setup there. However, I put the fan conversion project on hold and am planning on using the stock fan and fan shrouds. So far it looks like mounting the trigger wheel on the back of the fan might be the best way to go. Then it's a matter of pick-up location. Hmm.... -Josh2 |
brant |
Nov 16 2005, 03:32 PM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Josh...
no pictures but AJ makes a trigger wheel. I think he charged 150 back when I used it with a stock fan. don't have it anylonger... sorry brant |
jhadler |
Nov 16 2005, 03:35 PM
A trigger wheel to replace something else? Where and how does it mount?
I don't want to call AJ unless I've got a solid idea what about. -Josh2 |
SLITS |
Nov 16 2005, 03:38 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
How 'bout drilling the flywheel for the magnets and using the engine case flange to mount the pickup?
Carrera916 |
Nov 16 2005, 03:46 PM
Member Group: Members Posts: 292 Joined: 9-February 03 From: Pleasanton, CA Member No.: 273 |
Yeah....
I'm looking into it now....will head off to Pick & Pull, german car section, gonna look for that magnet pick up thingy and go from there.... any suggestions on which perticular car to look into? I'm heading to the idea of Audi & some Porsche models... and see what's do-able.... j |
lapuwali |
Nov 16 2005, 03:48 PM
The Electromotive setup doesn't use magnets, it uses a steel toothed wheel with a VR sensor, and only works with a 60-2 missing tooth wheel. Putting magnets on the flywheel for an SDS, Perfect Power, or MS ignition setup using a Hall sensor is doable, as you only need 3 magnets. Attaching the VR sensor to the back of the fan housing produces a very tidy setup. Search for Dave Hunt's photos on his EDIS setup, and I'm sure you'll agree. |
Mueller |
Nov 16 2005, 04:40 PM
ask and you shall recieve (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Mark Litherlands old 914.... (IMG:http://members.rennlist.com/mlitherland/engine5.jpg) (IMG:http://members.rennlist.com/mlitherland/trigger.jpg) (IMG:http://members.rennlist.com/mlitherland/trigger2.jpg) |
Brett W |
Nov 16 2005, 04:48 PM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
Make sure you keep at least one back up sensor with the car. The electromotive sensors are known to die prematurely.
jhadler |
Nov 16 2005, 04:52 PM
-That's- what I was looking for!!
How stable was the mount? Any need for tweeking it once it was in? Looks pretty close to what I had in mind. Cool... Is the trigger mount custom? Or is it commercially available from someone? -Josh2 |
Powerman |
Nov 16 2005, 05:52 PM
Newbie Group: Members Posts: 37 Joined: 24-November 03 From: Stafford, VA Member No.: 1,384 |
I second the pickup problems, use an MSD.
They had a lot of problems, I think the larger diameter Electromotive is improved? |
Lo-Fi Version | Time is now: 17th May 2024 - 04:32 PM |
