Just like a chimp with a stick at an anthill, Home made Ball Joint tool |
DNHunt |
Dec 20 2003, 08:21 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Just like the chimp I'm surprised it works. Left over 2" OD pipe. I used the galvanize elbow. It fits over the nut well an doesn't nick the ball joint. I transposed the notches onto the pipe with a pencil then cut on the lines with a hack saw. Removed waste with a cut off wheel (I just can't accept the fact I'm done grinding). It appears that the teeth on the tool are not evenly spaced as this only fit one way so, I think you have to work closely off of a nut. (Probably so the tool is proprietory)
Dave Attached image(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 11:55 PM |
