BEFORE Red Rocks Classic:1. Rotate tires2. Tighten altenator belt--changed3. Valve adjustment ...Well, almost. One valve is loose.
4. Add bottom caps to windshield washer thingies5. Dome light 6. Hazzard lights (I've given up. It works sometimes when it wants, but never when I need it too.) 7. Replace sail pannel vinyl Yeaaa!
8. Oil change, filter, ect. 9. Leak in brake line-driver side10. Install stereo--boy that was a mistake!
11. Stop squeak in rear brakes12. Find that oil leak! It was the push rod tubes.13. Check tranny fluid14. E-brake hard to set & releases easily.
15. Clean seatbelt...make roll better.
Things for the future:1. Find exhaust leak
[s]2. Center consol pad (new or redo)
3. Passenger door alignment. (can not open without leaning on it....possibly hinge or sag?)
4. Pull hood alignment forward5. Install rear trunk hindge rollers
6. Adjust passenger headlight alignment (align with hood).7. Front hood squeaky springs
8. Touch up paint
Things for when I win the lottery:
1. New carpet kit
2. Rims polished
3. New targa top seal
4. 4-point seat belts
5. Rebuild engine
Ok, that's it..............for now.
*Update, Dec. 5th 2006, getten 'er done!!!* How are you coming along?
Powered by Invision Community Blog (http://www.invisionblog.com)
