Quick summery of what I've done since the last post:
- Replaced sway bar's drop links, tightened bar
- Fixed decklid pull cable
- Removed Decel Valve
- Removed Cold Start Valve
- Mounted ECU
- Installed Optima Red Top Battery
- Replaced Oil Pressure Sending Unit
- Found my missing Turbo Tie Rod Kit
- Removed sound pad from firewall, found some more rust. McMark, I need you!
Tomorrow I'm headed off to the Sonoma County Airport to auto-x with the Redwood Region PCA. Wish me luck!
Borrowed Eli's cone cam setup (thanks Eli!), will post video:
