Stuff I need to get rid off:
Rust free front hood
Rust free rear hood
Stock left side door w/ all the window works removed
Stock metal right side with the beam cut out, and window parts removed
2.0 (94mm) Cylinders which can be taken out to 96mm
2.0 long block-crank/cam/case (no heads)
1.7 Complete engine
1.7 case, open and hot tank cleaned
1.7 heads, ugly but will clean up nicely
Headlight parts, motors, bits and pieces
Rear window glass
Stock starter
Stock FI fuel pump
Boxes of odds and ends
Engine fan housing and sheet metal
USED Long block w/ big valves heads, 1.7 counterweighted crank, 96mm NPR p/c
Stock metal rocker panels
Outside and inside door handles
Single progessive weber carb
Powered by Invision Community Blog (http://www.invisionblog.com)
