I need to:
Next thing to do:
1. Complete the wing.
2.
3.
4.
5.
Future:
1.
2. Cut some holes in the front wheel wells. (no hurry)
3. Clean up the underside. (no hurry)
4. Mallory Dizzy
5. Rebuild the Konis
6. RennShift!
7.
Done:
Pull the engine and weld in the 3/4" tube to the inner ear to the firewall. (DONE)
Complete the installation of the shoulder belt bar than install the belts. (DONE)
Grind/cut off the old tabs on the upper roll bar where it connected to the targa bar. (DONE)
Install a reduction gear starter and save 7-10 pounds! (DONE)
Grind/clean up the welds on the bars. (DONE)
Patch over the drivers side jack hole. (DONE)
Rework the tonneu cover to fit the new bar layout. (DONE)
Weld in the main hoop at the floor and remove the bolts. (One side DONE)
Attach a bracket to the back of the seat for support. (DONE)
Move the sub belt to under the seat. (DONE)
Make the body panels fit. (DONE)
Remove the dust covers from the front struts. (DONE)
PAINT! (Done)
Need to mount slicks
Weld gusset to right side door bars
Move the electical kill switch to the top for access
Polish and paint wheels
Powered by Invision Community Blog (http://www.invisionblog.com)
