03-11-2006
I finished my dash wiring today so everything electrical is completed except running the battery cables from the front trunk to the starter area.
I also repaired my clutch cable tube as it exits the firewall. I repaired the "fix" that the last owner had done now since I had the fuel lines out. I didn't do it 13 years ago when I repainted the car because I didn't pull the fuel lines and I was worried about melting the plastic lines.
I will be running the stainless fuel lines through the center tunnel after I finish up the engine mount and floorboards. I will also be removing the battery tray and some useless brackets from the engine compartment while I'm in there.
I'll probably rework some of my welds that I did 13 years ago. It's amazing how much you improve at welding with more experience.
Powered by Invision Community Blog (http://www.invisionblog.com)
