<b>IPB WARNING</b> [2] Creating default object from empty value (Line: 113 of \modules\blog\rss.php)<br />
<?xml version="1.0" encoding="utf-8" ?>
<rss version="2.0">
<channel>
	<title><![CDATA[Okieflyr's mayhem]]></title>
	<link><![CDATA[http://www.914world.com/bbs2/index.php?automodule=blog&req=showblog&blogid=353]]></link>
	<description><![CDATA[Okieflyr's mayhem Syndication]]></description>
	<pubDate>Thu, 17 Sep 2026 10:40:03 +0000</pubDate>
	<webMaster>notification@914world.com (914World.com)</webMaster>
	<generator>Invision Community Blog</generator>
	<ttl>60</ttl>
	<item>
		<title>Test fitting the engine</title>
		<link><![CDATA[http://www.914world.com/bbs2/index.php?automodule=blog&blogid=353&showentry=2367]]></link>
		<category></category>
		<description><![CDATA[Starting to assess the initial fit and clearances.  The EGR on the back of the head protrudes into the rear firewall, but both will be removed as things progress.<br />The throttlebody is too close to the firewall, so the whole intake will be replaced with an Audi intake to change the direction and location.<br /><a href="http://www.914world.com/bbs2/index.php?automodule=blog&req=attach&id=9980" title="1.8T_throttle_body__Medium_.JPG" target="_blank"><img src="http://www.914world.com/bbs2/uploads/blog-3426-1233885679_thumb.jpg" width="125" height="125" alt="Attached Image" /></a> <a href="http://www.914world.com/bbs2/index.php?automodule=blog&req=attach&id=9978" title="1.8_firewall_clearance__Small_.JPG" target="_blank"><img src="http://www.914world.com/bbs2/uploads/blog-3426-1233885024_thumb.jpg" width="125" height="125" alt="Attached Image" /></a> <a href="http://www.914world.com/bbs2/index.php?automodule=blog&req=attach&id=9979" title="1.8T_clearance__Small_.JPG" target="_blank"><img src="http://www.914world.com/bbs2/uploads/blog-3426-1233885213_thumb.jpg" width="125" height="125" alt="Attached Image" /></a> ]]></description>
		<pubDate>Fri, 06 Feb 2009 01:53:52 +0000</pubDate>
		<guid><![CDATA[http://www.914world.com/bbs2/index.php?automodule=blog&blogid=353&showentry=2367]]></guid>
	</item>
	<item>
		<title>Adaptation Phase</title>
		<link><![CDATA[http://www.914world.com/bbs2/index.php?automodule=blog&blogid=353&showentry=1418]]></link>
		<description><![CDATA[Here's how my 76' 914 conversion to a VW 1.8T GT morphed..<br />(Adaptation Phase)  <br />  Out with the fine running 2.0, in with a low milage 1.8 VW 20th aniversary turbo engine. My goal is to recreate the 914-6 GT look, but with modern economical drive train. My primary time behind the wheel will be auto-xing, so areas of weight reduction, and chassis stiffening will be of interest.   I have sourced the required adapter plate, flywheel, and clutch package from Kennedy Engineering. This will allow me to use the current side shift 901 transmission.<br /><a href="http://www.914world.com/bbs2/index.php?automodule=blog&req=attach&id=5283" title="blog-1142394347.jpg" target="_blank"><img src="http://www.914world.com/bbs2/uploads/blog-1142394347_thumb.jpg" width="125" height="125" alt="Attached Image" /></a> ]]></description>
		<pubDate>Wed, 15 Mar 2006 03:38:47 +0000</pubDate>
		<guid><![CDATA[http://www.914world.com/bbs2/index.php?automodule=blog&blogid=353&showentry=1418]]></guid>
	</item>
</channel>
</rss>
