After reseaching the cost to rebuild the Koni Reds I found it was only about $45 more to buy new Yellows from Performance Products.
Memorial Day weekend I started putting things back on instead of removing them. A milestone of sorts. I installed the new torsion bars, Delrin bushings, new ball joints, and the new Koni Yellow struts. The new turbo tie-rods were aleady installed. I still need to connect the sway bar to the a-arms. When I went to install the wheel bearings I found out that the guy I bought the 911 front end from had wrapped the new bearings in paper towels. These had gotten wet and rusted the bearings badly. I should be able to pick some new ones up locally so I can get the front wheels on.
Got the trailing arms off a couple of weeks ago and got the Delrin bushings and new axle bearings for the back. Since my ex-wife went to court and managed to suck more money out of me it will take awhile before I can afford the rear shocks. I need to get new springs too. Stay posted.
Powered by Invision Community Blog (http://www.invisionblog.com)
