2L core engine, longblock, 1 ea
2L heads
2L short block, core, 3 ea
2L case
2L crankshafts
2L rods
9550 camshaft and matching lifters
94mm pistons and cylinders
96mm pistons and cylinders
windage tray with seals
flywheel
D-Jet AAR, fuel pressure regulator, decel valve, cold start valves
L-Jet AAR, fuel pressure regulator, decel valve, cold start
throttle body
D-Jet 2L intake manifolds, intake air distributors, air cleaners
L-Jet 1.8L ntake manifolds, intake air distributors, air cleaners
engine cooling tin 2L
cooling fan housing +bus
relay boards
seats, black, 4 ea
backpad, black, 73->
door panels black
carpet, brown
center tray w/cushion, brown x2
console
combo gauge w/oil temp 73, 74, 74-76
oil temp sending unit/taco plate
alternators
starter
D-Jet ECU
D-Jet 2L fuel injectors, intake runners, intake air distributor, fuel rails
MPS
distributors, L-Jet & D-Jet
L-Jet ECU
L-Jet AFM
D-Jet 1.7 fuel injectors, intake runners, intake air distributor
D-Jet 1.7 oil bath air filter w/stand
D-Jet 1.7 air filter elements, 4 ea
transmissions 4 ea, 1 rebuilt side shift Dr Evil clinic
front hood
engine lid with letters, green
IMSA front fiberglass bumper
fiberglass front bumper GT
fiberglass front valance for flaired fenders
gas tank with expansion tank x2, +1 expansion tank
stainless steel heat exchangers, 2L
brake fluid reservoir
front struts
glass, door and vent, rear
lighting, front. rear, turn, fog, housings and lenses
heating system ducts
aftermarket steering wheel x2 with mounting hubs
4 bolt Fuchs with lug bolts
5 bolt Fuchs 6x16 x4 1 pair with RA-1's for 911SC/Carrera
5 bolt Fuchs 7x16 x2
5 bolt Fuchs 6x15 with Hoosier slick
5 bolt Fuchs 6x15 x2
911SC front spoiler
'69T 2.0L engine (see 6192376 blog)
'70T 2.2L engine 6106641
914-6 oil cooler
914-6 engine sheet metal
914-6 oil tank
Patrick oil tank
914-6 oil lines
914-6 throttle linkage kit
914-6 flywheels, clutch disc, pressure plate, throw out bearing
cooling fans and alternators
911 engine shrouds; black, orange and red
quick 6 engine mount bar
2.2 heads, set
2.2T pistons and cylinders, refurbished/honed
carrera chain tensioner kit
Powered by Invision Community Blog (http://www.invisionblog.com)
