901.101.101.02R case half // 10/08/2014
911.107.512.00 piston 901.107.531.00 compression spring 900.123.071.30 gasket 999.064.010.02 screw plug
999.704.172.50 sealing ring 914:101-10 #24 qty:3
999.107.173.50 sealing ring 914:104-00 #2 qty:1
900.123.011.30 sealing ring A 22 x 27 for 900.136.013.02 union A 16 qty:1
oil bypass modification:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/553551-peter-morgan-68-rebuild-videos.html
911.107.008.01 oil pump 76-> PET 104-00 (911 1977) #(1) 911-911E/
springs, guide, plugs
case, cam housings and cam towers taken to Allied Machine shop for cleaning $100
total engine management system
http://www.clewett.com/index.php?main_page=index&cPath=2
youtube video SEXY!
https://www.youtube.com/watch?v=FT-f9ov5ypQ&NR=1
11/13/14 dropped off case and 11 through bolts/washers/nuts
12/08/14 stopped by to see progress, none to date, still waiting
01/13/15 project on hold due to CABG surgery
02/20/15 stopped by to check on status, no progress, still waiting
03/24/15 Mulligan CABG
04/17/15 6106641 type 911/07 arrives
05/18/15 stopped by to check on case. It's being worked on.
06/07/15 thanks to Gary, Chris, Rod, mark, mark, rob, Jon, Pete, Porsche friends, music friends. Church friends. My family I love you barb Kate jame Kim precious grandchildren.
07/14/15 Not dead yet, ignore tone of 06/07/15 entry. Removed frequency valve block-off, reinstalled frequency valve
"Four separate oil lines are required to connect the oil tank to the engine."
http://www.pelicanparts.com/914/914-6_construction_kit/914-6_info_guide.htm
http://www.914world.com/bbs2/index.php?showtopic=247015
2.2E p's & c's
http://lnengineering.com/index.php/products/porsche-911-22-84mm-nickies-inc-95-1-je-piston-set.html
shift linkage solution, CV's
http://www.tangerineracing.com/transmission.htm
machine shop for crankshaft and rods
https://www.facebook.com/pages/Burtonsville-Performance-Machine-Service/154349891267211
Mar 10, 2015: 6106641 2.2T not including carbs, distributor, coil, wires. Includes fan and housing, engine shroud, flywheel clutch pressure plate assembly
https://www.youtube.com/watch?v=l5GVA-RU4zQ
engine startup at Tangerine Racing
DIRTY! Apr 21, 2015
alternator connections? need harness
chain tensioner tech article: http://www.pelicanparts.com/techarticles/911_Carrera_chain_tensioners/911_Carrera_chain_tensioners2.htm
Powered by Invision Community Blog (http://www.invisionblog.com)
