his_engine_was_professionally_rebuilt_and_installed_2.0_engine.doc ( 23k )
I purchased this package to put into a Bumblebee so I would be able to drive it while doing work on it. I have gotten the engine in and started and it sounds like the engine is everything as advertised.
The clutch cable was about 20 mm to long. I was able to put a couble of nuts on it to get it to feel somewhat normal, but the to bearing lever hits trans housing. I want to keep the flywheel and clutch package together. I plan to remove the tran this week to fix the linkage issue. I believe that I should probably put in a new TO bearing while I am at it. Do I neet to get a different TO bearing or how do I shim the stock or do I have something else out of place. I do not know how the flywheel was lightened. I did not measure this before putting new engine and clutch package together with old trans and TO bearing.
Powered by Invision Community Blog (http://www.invisionblog.com)
