Kent,
OK, so I did a little test fitting and it seems like unless I cut the MC hole so that the MC comes through a bit it's not going to bolt up right.
Here's a pic of the two MC's:
The Wilwood body is significantly shorter on the pin side, and it smashed up pretty close against the front of the firewall/back side of the pedal area when we installed them. The Honda one is at least an inch longer. Doesn't seem like there's any way I can bolt it up without cutting the hole out so that the MC can go through the firewall area a bit. Does that make sense?
I'm totally fine cutting the hole, just making sure I'm not messing it up. Because once you cut...THAT'S IT!
Powered by Invision Community Blog (http://www.invisionblog.com)
