924 wiper switch, Will this Mod work in a 73 |
AZ914 |
Jul 18 2006, 08:08 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
Here be the pics:
AZ914 |
Jul 18 2006, 08:09 PM
Back side with wires..
Aaron Cox |
Jul 18 2006, 08:27 PM
want to do another pic? can you seperate the turn signal from it?
Casper |
Jul 18 2006, 08:40 PM
Newbie Group: Members Posts: 35 Joined: 5-June 05 From: Omaha, Nebraska Member No.: 4,207 |
Aaron,
How bad do you want a turn signal wiper switch? There is a 1977 924 in one of the local u-pull it yards that may have one. I could check it out either Thursday or Friday, (It's supposed to be 101 here tomorrow and I don't think I'll go searching for parts). Another place that I know has them is NPR - Tekamah. He sells alot on ebay. The direct number for him is 402.374.2781, e-mail is NPRKIRK@huntel.net. His wife, Linda, will more than likely answer the phone or reply to your e-mail. His prices are a little high at times, but if you don't say you heard about it from me you will probably get it for half the price he would quote me. He will treat you fairly. Tom Cooper |
Aaron Cox |
Jul 18 2006, 08:43 PM
i need one or two reaaally bad. i owe eric shea one also...
what would it cost me to have you pull it? dinner? + cost? feel free to let me know AA |
AZ914 |
Jul 18 2006, 09:11 PM
want to do another pic? can you seperate the turn signal from it? Hey Aaron, Just trying to figure out the best way to do that without breaking any plastic. If I get it, I'll post the pic. I bought this thing a couple of years ago off of ebay but hadn't bothered to do the conversion yet. |
eg914 |
Jul 18 2006, 11:52 PM
Member Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
The VW switch is the same, 111-953-519-G. I bought mine at Bugformance a couple of years ago. The old plastic is difficult to remove without breaking the tabs that hold the pieces together, but it can be done. I think it has both types of washer control to reduce the number of switches that need to be stocked.
Stieve |
Jul 19 2006, 02:50 PM
Senior Member Group: Members Posts: 587 Joined: 6-May 06 From: Sacramento Member No.: 5,996 |
It needs the extra red/black and brown wire, then you tyranser the 914 plastic connector to the 924's then you have the extra wires run where the hoses where. I know how to do it! Equipment required: 924 steering column windshield wiper switch (111-953-519G) Small 12 volt water pump (I used a VDO pump, 191-955-681) Multi-strand copper wire suitable for wiring automotive electrical components. I used 18 gauge wire. (Red and black) Plastic tubing T-connector (one already exists between your washer nozzles), so you don't really need to buy one. I can take a picture later if needed. Wish they made replacement decals or something to replace the white lettering on the arms. |
Aaron Cox |
Jul 19 2006, 11:13 PM
woohoo. i got one of these bad boys inbound, already have the pump..
ill write up a how to when it arrives (or add pics to Karls thread) |
Stieve |
Jul 20 2006, 12:02 AM
Look at Pelicans write up
Aaron Cox |
Jul 20 2006, 12:04 AM
Look at Pelicans write up uh.. karl wrote that one, and i said i would add pics to karls write up as i mentioned above (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 02:00 PM |
