Group buy air deflector for cooling. Change airflow under the car, $28 A set. |
walterolin |
Dec 8 2017, 11:55 AM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
One set.
Thanks - again. |
74K914 |
Dec 8 2017, 04:56 PM
Newbie Group: Members Posts: 6 Joined: 5-April 17 From: Orange County , CA Member No.: 20,999 Region Association: Southern California |
One set.
Thanks |
cary |
Dec 8 2017, 10:58 PM
Here's your starting point. Based on the 3 cars I looked at here at MiddleMotors the first bolt is 15mm from the jack point plate. But beware ................
Most cars have seen some sort of rust repairs so use the 15mm as a starting point. But make sure you can drill the holes and get your 8mm socket or nut driver on the other two 5mm bolts. Here's the pilots modification the bottom edge. I think Phil Knight has something like that on his G650. I put them back on Doug's car for photos but forgot a couple shots. (IMG:style_emoticons/default/mad.gif) Tomorrow |
Mikey914 |
Dec 8 2017, 11:37 PM
The rubber man Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Good news is I will be able to better the offer a bit too. More to come
914six |
Dec 9 2017, 10:30 AM
Newbie Group: Members Posts: 28 Joined: 29-March 10 From: Los Angeles, CA Member No.: 11,521 Region Association: Southern California |
Hi Mark,
would like a set also.. Thanks, Harry |
cary |
Dec 10 2017, 10:26 AM
slotty008 |
Dec 10 2017, 01:13 PM
Member Group: Members Posts: 191 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None |
I'm in for a set.
Larry.Hubby |
Dec 12 2017, 07:20 PM
Member who doesn't post much, but has a long time in 914s Group: Members Posts: 186 Joined: 24-November 04 From: Palo Alto, CA Member No.: 3,172 Region Association: Northern California |
If the buy is still open, I'll take a set too.
jcambo7 |
Dec 12 2017, 09:35 PM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
I'm in for a set!
theer |
Dec 13 2017, 09:31 AM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
If a car was an early 70-72 than there are no holes in the body to install them. Some measurements or a template for installation would be very helpful. The Haynes manual has specific instructions (& measurements) on how/where to install these on early cars. I'll try to post pics later. Tom |
Mikey914 |
Dec 13 2017, 01:03 PM
Awesomeness thanks,
Mark |
74 sunflower 914 |
Dec 13 2017, 02:42 PM
Newbie Group: Members Posts: 25 Joined: 25-August 08 From: Bonsall, CA Member No.: 9,460 Region Association: Southwest Region |
I would like a set as well.
theer |
Dec 13 2017, 06:42 PM
If a car was an early 70-72 than there are no holes in the body to install them. Some measurements or a template for installation would be very helpful. The Haynes manual has specific instructions (& measurements) on how/where to install these on early cars. I'll try to post pics later. Tom Ok - here are the pics (from page 194 and 197 of the Haynes manual). Not much there, but hope it helps. I recall having to dig some seam sealer off the weld seam to drill the holes, but it's pretty easy job: |
Mikey914 |
Dec 20 2017, 01:22 AM
Just running these tomorrow will be sending PMs out tomorrow evening.
Thanks all |
DRPHIL914 |
Dec 20 2017, 07:44 AM
Dr. Phil Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
can I get in on a set of these too Mark?
Mikey914 |
Dec 20 2017, 11:55 AM
Yep just starting to open this one up and we'll be shipping product here within the next week. Also got a couple other little goodies I'm going to put a group Buy on. The sign up here.
Mikey914 |
Dec 20 2017, 09:02 PM
Well looks like I will have to go into work early this week. I will be able to finish these up late next week, but will open these up with the rubber roof holders which we have changed the tooling on and improved them. A few of you may have got a set of these recently. (IMG:style_emoticons/default/biggrin.gif)
Mikey914 |
Dec 21 2017, 01:34 AM
PMs sent to all.
Thanks Mark |
tsvo |
Dec 21 2017, 02:55 PM
Member Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest |
Mark, I would like a set of air deflectors as well.
Thanks, Terry |
jesse7flying |
Dec 21 2017, 03:20 PM
Member Group: Members Posts: 134 Joined: 9-August 16 From: Burleson,TX Member No.: 20,281 Region Association: None |
Count me in for a set. Thx. Maybe combine with the A arm tools?
Jesse |
Lo-Fi Version | Time is now: 15th June 2024 - 02:26 PM |
