How much cooling is gained with the GT double grill?, Other ideas for cooling outside of an addtional cooler? |
mskala |
Mar 8 2023, 08:03 AM
Many years ago I did some controlled experiments in semi-hot weather to see the effects
of the lid removal and some other things like having holes in the tin where hoses used to be. I'll need to find the thread, but the oil temp does go down when you remove the lid, and probably will be similar with the double grill lid. |
Superhawk996 |
914 Guru Group: Members Posts: 5,904 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I know you posted this question and pic before. The 911 runs at 210 all day long. The mark on the 77 gauge is directly in the middle. The 914 is using a GT style gauge with 100C (212F) in the middle. 210 seems right to me 210 is nice but not so easily achievable with the 2.7L without an external cooler. However, looking at the gauge you posted, there is no need to be excited with excursions to 250 under high load / high speed. Agreed? For OP - question, what is the real difference between 210 and 230 in terms of engine life and oil life? 20 degrees is basically a 10% variance. |
mskala |
Mar 8 2023, 08:10 AM
Craigers17 |
Mar 8 2023, 08:16 AM
Senior Member Group: Members Posts: 749 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
To the original question...I sincerely doubt the single-grill lid creates any significant restriction to cooling airflow on a street car. On an always-7000-revving engine? Sure. But I do doubt that on a street car. That said, I did Sergio's GT lid conversion on both my 4-banger street car and my 4-banger 2056cc race car*. The former because it looks good and the latter because...well, I looks good and is lighter and my race car lid is pinned and gets removed for service... - GA *I also removed/trimmed all the external horizontal sheet metal on the race car, to improve airflow and access/serviceability. I also put Sergio's GT lid on primarily because it looks good, it's lighter, and mine is fastened with hood pins, so access is better(pretty much the same reasons as Greg). That said, drive your car around for a half hour or so, and then pop your engine lid and see how much heat comes flowing out....even 5 or 10 minutes later. When you have a double open grill vs a piece of sheet metal and a plastic rain tray, there's absolutely no doubt that you are holding more heat in that space. I'd say it's theoretically possible that even that amount of heat could contribute to higher head temps. Maybe someone's already done the R&D. Anyone here with an aftermarket head temp sensor and a stock lid that they aren't afraid to remove could do some simple controlled tests. |
Olympic 914 |
Mar 8 2023, 08:40 AM
Group: Members Posts: 1,676 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
This thread may have some useful info.
Under trunk temps, with under trunk oil cooler. http://www.914world.com/bbs2/index.php?sho...347282&st=0 At this time I was running the regular engine grill with raintray, /4 Have since acquired one of Sergio's double grill lids, and switch to it in the hotter months. Have not done this same test comparing the single grill lid /w tray to double grill lid. Maybe someday. An under trunk oil cooler may work for you @peteinjp less work than the front mount. I used a Setrab 119 fanpack cooler but they have larger ones that may give you better cooling. That said, I'm very happy with the setup I have now. Oil temps are reasonable on the hottest days. |
DRPHIL914 |
Mar 8 2023, 08:58 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
This thread may have some useful info. Under trunk temps, with under trunk oil cooler. http://www.914world.com/bbs2/index.php?sho...347282&st=0 At this time I was running the regular engine grill with raintray, /4 Have since acquired one of Sergio's double grill lids, and switch to it in the hotter months. Have not done this same test comparing the single grill lid /w tray to double grill lid. Maybe someday. An under trunk oil cooler may work for you @peteinjp less work than the front mount. I used a Setrab 119 fanpack cooler but they have larger ones that may give you better cooling. That said, I'm very happy with the setup I have now. Oil temps are reasonable on the hottest days. I dont have a /6 but i have a performance tuned and built 2.1 running highe compression, and you know 2.0 motors run a bit hotter anyway, but i found that without a aux oil cooler , with long highway drives evey at 3500-4000rpm head temps were fine but oil temps were wanting to go to 230-240, and same with a 90 degree day idling in traffic more than 30 minutes, even with the cooler but the fan not working this past week in florida at Amelia, then i got the fan wired back up and it made a big difference, which goes to the discussion of trapped heat uder rear trunck where my cooler is located. I still would like to have it more at that 210, so i am considering a larger aux oil cooler and i have Sergio making me a GT double grill lid too. We get really hot and humid here in SC and Florida. SO my question would be if i leave the cooler where it is, what brand/size cooler should i be looking at. also is there a difference in the mechanical temp triggered thermostat in that adaptor for these aux coolers? are most of the 180? i dont know for sure what mine is, it was installed by Tangerine about 4-5 years ago and did great on the stock 1911 motor but i feel like i need more oil flow or surface area for better more effective cooling. - sorry to OP for the hijack . Phil |
DRPHIL914 |
Mar 8 2023, 09:25 AM
This thread may have some useful info. Under trunk temps, with under trunk oil cooler. http://www.914world.com/bbs2/index.php?sho...347282&st=0 At this time I was running the regular engine grill with raintray, /4 Have since acquired one of Sergio's double grill lids, and switch to it in the hotter months. Have not done this same test comparing the single grill lid /w tray to double grill lid. Maybe someday. An under trunk oil cooler may work for you @peteinjp less work than the front mount. I used a Setrab 119 fanpack cooler but they have larger ones that may give you better cooling. That said, I'm very happy with the setup I have now. Oil temps are reasonable on the hottest days. @Olympic_914 what cooler are you using? mine is not as deep/thick as yours, would this help me get down to that 210-215 , switching to a double ? I have a fan and its definitely a must. sorry just re-read the other post and saw you already answered that - Phil iu think what i have now is a series 6 or very similar, and wonder if the 119 would be better than what i have or as you stated , could go to the double unit butdont know it will fit in that location. |
Olympic 914 |
Mar 8 2023, 10:19 AM
@Olympic_914 what cooler are you using? mine is not as deep/thick as yours, would this help me get down to that 210-215 , switching to a double ? I have a fan and its definitely a must. sorry just re-read the other post and saw you already answered that - Phil iu think what i have now is a series 6 or very similar, and wonder if the 119 would be better than what i have or as you stated , could go to the double unit butdont know it will fit in that location. @DRPHIL914 The Setrab Series 6 is a longer cooler than the 119 I have which is a series 1 (119= 19 row) Looks like the series 6 25 row will fit without a lot of problem and they have a fanpack version also. I still have my stock cooler installed, a sandwich plate without a thermostat and a remote thermostat , the setrab 119 unit is in addition to that. did Chris leave your stock cooler in place or eliminate it in favor of the remote cooler? Setrab thermostat > https://www.pegasusautoracing.com/productde...asp?RecID=32981 |
DRPHIL914 |
Mar 8 2023, 10:38 AM
@Olympic_914 what cooler are you using? mine is not as deep/thick as yours, would this help me get down to that 210-215 , switching to a double ? I have a fan and its definitely a must. sorry just re-read the other post and saw you already answered that - Phil iu think what i have now is a series 6 or very similar, and wonder if the 119 would be better than what i have or as you stated , could go to the double unit butdont know it will fit in that location. @DRPHIL914 The Setrab Series 6 is a longer cooler than the 119 I have which is a series 1 (119= 19 row) Looks like the series 6 25 row will fit without a lot of problem and they have a fanpack version also. I still have my stock cooler installed, a sandwich plate without a thermostat and a remote thermostat , the setrab 119 unit is in addition to that. did Chris leave your stock cooler in place or eliminate it in favor of the remote cooler? Setrab thermostat > https://www.pegasusautoracing.com/productde...asp?RecID=32981 stock cooler with sandwich plate just like you . i currently have an adjustable rheostat i have it set to come on at 200, i think it turns off ( the fan) at 180 or 185. i think my sandwich plate has a built in thermostat but i dont know for sure i would have to ask Chris but i was thinkg about if it does not , have one that opens at 180. |
dr914@autoatlanta.com |
Mar 8 2023, 10:41 AM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we did a study with a 914 3.0 six GT replica with front GT oil cooler with and without the stock engine lid on the car at the Atlanta Motor Speedway for many laps each, and there was no difference
My 2.7 get up to about 230F in the summers and I'm looking to try everything possible to keep the temps down a bit. I am planning on installing a front cooler but that is more of a project that I can handle in the short term. So does the GT style double grill actually help cooling significantly? Any other mods that can increase cooling- different fan or pully etc? 230 seems to be a high but acceptable limit but sure would like to have a little more wiggle room. Other weeks- will check the timing to ne sure its spot on. Also will try going back to the initial rich mix on the MFI. Pete |
GregAmy |
Mar 8 2023, 10:46 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
That said, drive your car around for a half hour or so, and then pop your engine lid and see how much heat comes flowing out....even 5 or 10 minutes later. When you have a double open grill vs a piece of sheet metal and a plastic rain tray, there's absolutely no doubt that you are holding more heat in that space... Emphasis mine. Something I had not considered, as I've always run "sans" rain tray so my statement was based on single-versus double-grill only. There's a thread around here where I took a 4-thermocouple barbeque tray bluetooth thermometer to check temps inside the engine compartment and under the rear trunk; I was fighting an oil cooling problem (turned out to be an engine problem). I found that the upper area of the engine while underway was within 2-4 degrees of ambient; it's all about airflow. Problem with checking when you're stopped is that there's much less more engine induction and cooling airflow demands, so it tends to heat sink. Use one of these to do direct back-to-back comparisons of upper engine compartment airflow, with stock lid and raintray, stock lid w/o tray, and double. I'd be interested if there was much difference, $25 or so with click-coupon...but if someone in CT wants to borrow mine for testing you're welcome to it...won't say bad things about you if you buy me a beer... - GA https://www.amazon.com/gp/product/B076QDC5VL |
Eric_Shea |
Mar 8 2023, 01:13 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Pete,
1. Low Pressure flaps are $20.00 and a great investment. We put them on everything. 2. I like the GT lids and there was a thread herein that gave some great figures. The front cooler is a great idea for that car. We have quite a bit of real work experience with 2.7's. Love that motor for a 914. I wouldn't let a 2.7 leave the shop without a front cooler. |
Mar 8 2023, 01:35 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Pete, 1. Low Pressure flaps are $20.00 and a great investment. We put them on everything. 2. I like the GT lids and there was a thread herein that gave some great figures. The front cooler is a great idea for that car. We have quite a bit of real work experience with 2.7's. Love that motor for a 914. I wouldn't let a 2.7 leave the shop without a front cooler. I agree, there was a thread someone did long ago that measured temp difference between the two deck lids. It may not be simple to dig up. rich |
peteinjp |
Mar 9 2023, 08:05 AM
Member Group: Members Posts: 201 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
Thanks all- great info and ideas for sure. Cooler is the way to of for sure with the front cooler being ideal.
Its interesting to me that most think that 210F is acceptable. In reading factory literature it often refered to operating temp as 80C (176F) for MFI tuning so I was thinking that was kind of the ideal but in retrospect they were probably referring to the minus operating temp. Then there is the idea that breaking 212F is a good thing to help any condensation evaporate... So is 230 considered high but acceptable? I think I might try as an interim system running the lines for a front cooler but just putting in a trombone type of deal in the front fender. If 230 is not terrible then it would be interesting to see how much I could drop the temps with such a simple system. IF this did work it would keep all the frunk space and keep things simple and clean under the rear of the car. Heck if I added some louvers to the rocker cover I might be able to get enough of a drop in temps without even going to the front wheel well. Maybe used some finned tubing? Pete |
jim912928 |
Mar 9 2023, 08:34 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Well, the trombone setup works for my 3.0 SC….I’d say give it a try and let us know. I don’t run a 2nd cooler in my 3.2 conversion and hit 230 on hot days…would love to lower temps and not have to cut things up.
Superhawk996 |
Mar 9 2023, 08:39 AM
Written in 1973 - based on Dyno oil - modern synthetic will tolerate 300F easily before thermal breakdown becomes a concern.
zoomCat |
Member Group: Members Posts: 162 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None |
Thanks all- great info and ideas for sure. Cooler is the way to of for sure with the front cooler being ideal. Its interesting to me that most think that 210F is acceptable. In reading factory literature it often refered to operating temp as 80C (176F) for MFI tuning so I was thinking that was kind of the ideal but in retrospect they were probably referring to the minus operating temp. Then there is the idea that breaking 212F is a good thing to help any condensation evaporate... So is 230 considered high but acceptable? I think I might try as an interim system running the lines for a front cooler but just putting in a trombone type of deal in the front fender. If 230 is not terrible then it would be interesting to see how much I could drop the temps with such a simple system. IF this did work it would keep all the frunk space and keep things simple and clean under the rear of the car. Heck if I added some louvers to the rocker cover I might be able to get enough of a drop in temps without even going to the front wheel well. Maybe used some finned tubing? Pete The believe the factory internal oil thermostat activates at 80c, so it’s the most easily maintained temp for testing. From the manual: |
Eric_Shea |
Mar 9 2023, 08:51 AM
Hey Pete,
I think "operating temperature" with regard to the manual means the engine has now warmed up and is no longer in a cold start type mode. This is when you can start to tune things like carbs and MFI. I'm my experience most street 911's run at 210. 240 starts to cause me concern and 250 is pull over time. This has been widely parroted and published from Bruce Andersons extremely thorough 911 book. With front coolers, our cars seem to stay at 180-200. When pushed at the track, 200-205. This is when the lightbulb comes on and you can see how the factory won these endurance wars of attrition. |
Root_Werks |
Mar 9 2023, 11:34 AM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Good write up on different configurations. I'm lucky, my six won't need a dual grill. (IMG:style_emoticons/default/driving.gif) |
VaccaRabite |
Mar 10 2023, 09:51 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I've used all three variants (GT grill, stock / no rain tray, stock with rain tray) and there is not really a difference in temps that I can find with a street car for either heads or oil temps.
Where is makes a HUGE difference is noise coming into the cabin. For longer drives, the GT grill really lets a lot of noise out of the engine bay and into the cabin. Earplugs needed. Stock - no rain tray cuts that down some, but I still wanted ear plugs on longer drives. Stock with the rain tray you could hear the passenger in the car. Considerably more tolerable on longer drives. Bearing in mind I have a SETRAB aux cooler and fan pack to help keep my oil in check on a hot 2056. I don't need the fan pack for most drives - but for some of the camping trips with bikes on the car and every inch of the car PACKED the fans were really helpful once the engine heat soaked. Zach |
Lo-Fi Version | Time is now: 10th June 2024 - 02:44 PM |
