Type IV Deck Height Plate, Ready To Ship! |
yeahmag |
Mar 1 2012, 11:59 AM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I'm having a few Type IV Deck Height plates being made as I wanted one. These are being made from precision tool plate AL used for fixturing items in large CNC machines. They will be flat to within .001" and have slot(s) for a depth mic.
I should be able to offer these in one and two cylinder configurations for a very affordable price. Let me know if you might be interested. -Aaron |
yeahmag |
May 21 2012, 03:55 PM
Roughly 7 of the first batch of 14 are sold and paid for. Just a heads up.
yeahmag |
May 24 2012, 11:49 AM
yeahmag |
Jun 7 2012, 11:48 AM
Just a heads up that I'm about sold through the first batch. If you want one grab it now. Not sure when or if I'll be doing a second run.
McMark |
Jun 7 2012, 11:16 PM
Crap! I'm in! Gotta find the payment info...
lonewolfe |
Aug 11 2012, 02:03 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Do you still have any of the first production models available? Your last post is a couple of months old now.
yeahmag |
Aug 11 2012, 04:22 PM
I do. I think I'm down to less than 10 though. $80 shipped.
pilothyer |
Aug 11 2012, 06:13 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Just in case anyone is wondering about this item, It is truly a wonderful addition to your engine building tool chest. It is the most accurate of any I have ever seen....plus it is just plain sexy. I bought 2 just to have one for each bank and I could not be happier. You won't be disappointed in any way with this fine, lab quality instrument. Thank you, Aaron for all the R & D that went into creating this fine Deck Height Plate Kit.
cgnj |
Aug 11 2012, 06:20 PM
Senior Member Group: Members Posts: 625 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
I just bought one. Came in the mail yesterday. It's a nice tool, well worth the money
Carlos |
yeahmag |
Aug 11 2012, 08:48 PM
Wow guys... You're making me blush!
stugray |
Aug 12 2012, 11:50 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I am am about to use this tool today.
Perhaps a video of how you expect it to be used would be good. I see the multiple holes for measuring and the small space that is machined into the plate. What is that machined spot used for? Also wouldn't it be better if the flat plate was made from steel instead of aluminum? Then my magnetic dial indicator stand would stick down to it. Stu |
yeahmag |
Aug 12 2012, 01:19 PM
The "multiple spots" were put there because we could and thought it wise even though the 12 and 6 measurements really aren't used (at this time). Use the center one to get the deck height measurement.
The "slot" is designed to measure co-linearity between your cylinders. This helps to double check that your deck is true. Simply zero on one cylinder edge with a depth mic and then slide over and measure the other. Any difference in height needs to be addressed. The parts were made somewhat to a price point without sacrificing accuracy. the AL is designed for fixturing and is flat to within .001" across the entire length when I buy it. That piece is *not* normal AL plate. The fixtures to torque the cylinders down could be made from steel, but would have added to the cost due to the additional time to machine it if not for the cost of the steel alone. I typically make a little plate that bolts to the intake on the head that I can snap my magnetic dial indicator to... I agree a video would be cool, but I'm barely covering costs at this point and consider this a contribution to the 914 cause and my motor is buttoned up. Maybe sometime after now... |
Jesco Reient |
Aug 12 2012, 07:00 PM
Member Group: Members Posts: 135 Joined: 18-July 12 From: Western Washington Member No.: 14,690 Region Association: Pacific Northwest |
I want to order one of these would you PM me the information where to send payment etc. I am ready to order. I have sent you a PM
Thank You, John |
yeahmag |
Aug 13 2012, 02:20 PM
John,
I replied to your PM. -Aaron |
stugray |
Aug 18 2012, 02:43 PM
I am attempting to use this tool today and I have constructive comments:
1 - Be sure to use large washers when tightening the longer bolts. Mine were small enough to start pulling into the aluminum tube and actually split one and distorted another (wondering why the torque will not reach 22 ft-lbs....) 2 - It is very tricky to get our cheapo harbor freight style dial indicators to reach far enough into the aluminum rails without interference. 3 - You NEED to find a way to attach the dial indicator to the engine case very securely. the video of how to use it would still be helpful even if from a customer. I am trying but cannot get my dial indicator someplace stable that can reach into the holes. Stu |
yeahmag |
Aug 18 2012, 02:56 PM
It's designed to use the stock head nuts and washers. I think I show that further back in the post. If not I may have a picture.
yeahmag |
Aug 18 2012, 02:58 PM
Jesco Reient |
Aug 18 2012, 04:47 PM
yeahmag |
Aug 18 2012, 04:55 PM
Don't see the PM... Try again?
twinfin360 |
Jan 5 2013, 11:24 PM
Newbie Group: Members Posts: 2 Joined: 30-November 08 From: SANTA CRUZ, Calif. Member No.: 9,803 Region Association: None |
Hello. I wish i would have seen your post earlier this last year for your Type IV Deck Height Plate!! Do you have any more of these? Or are you planning to make another batch in future. Also i dont mind buying a used one either. Thanks in advance for your answer.
-Damon in Santa Cruz, Calif. 95062 Ps i also PM'd you |
yeahmag |
Jan 25 2013, 03:45 PM
I'm now sold out of the full kits. I have some of the plates left (which are the key piece) that I will sell individually until I'm out. With this option you will need to fashion your own cylinder hold down widget.
$50 shipped each. -Aaron |
Lo-Fi Version | Time is now: 3rd June 2024 - 08:32 AM |
