Pic Request, Engine bays, let's see 'em! |
michel richard |
Oct 11 2004, 07:48 PM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
QUOTE(thesey914 @ Oct 11 2004, 02:35 PM) I want to see some more pics of Michel Richard's 914 -looks like Ravenna Green -one of my favourite colours. Ask an Irishman if he wants another pint. Ravenna green car is new to me. About a month and half at this point, so I don't have a ton of pictures. I got the car just before the 2004 East Coast Ramble and broke a CV joint while getting to the event. As a result, there were several pictures of my car taken there. See: http://community.webshots.com/album/181267453SQJTii Cheers, Michel Richard |
mharrison |
Oct 11 2004, 09:05 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
Well, This is it in the engine bay. I'm gonna pull it when I decide what color she's gonna wear!!
(IMG:http://home.jam.rr.com/mharrison/914Resto/EngineInCarResized.JPG) -Matt |
Curvie Roadlover |
Oct 12 2004, 04:11 AM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
srsrtusz
Curvie Roadlover |
eyiuydtt
joea9146 |
Oct 12 2004, 07:45 AM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
Here ya go
J P Stein |
Oct 12 2004, 12:01 PM
Hay, Joe.....sprung for an MSD, eh? Gud move.
Tidy job in the engine room (IMG:style_emoticons/default/biggrin.gif) |
joea9146 |
Oct 12 2004, 12:52 PM
QUOTE(J P Stein @ Oct 12 2004, 02:01 PM) Hay, Joe.....sprung for an MSD, eh? Gud move. Tidy job in the engine room (IMG:style_emoticons/default/biggrin.gif) JP Did u see the access hole in the Firewall (IMG:style_emoticons/default/sawzall-smiley.gif) |
Root_Werks |
Oct 12 2004, 01:56 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
QUOTE(joea9146 @ Oct 12 2004, 10:52 AM) QUOTE(J P Stein @ Oct 12 2004, 02:01 PM) Hay, Joe.....sprung for an MSD, eh? Gud move. Tidy job in the engine room (IMG:style_emoticons/default/biggrin.gif) JP Did u see the access hole in the Firewall (IMG:style_emoticons/default/sawzall-smiley.gif) What is that for????? (IMG:style_emoticons/default/sawzall-smiley.gif) |
J P Stein |
Oct 12 2004, 02:11 PM
QUOTE(Root_Werks @ Oct 12 2004, 11:56 AM) QUOTE(joea9146 @ Oct 12 2004, 10:52 AM) QUOTE(J P Stein @ Oct 12 2004, 02:01 PM) Hay, Joe.....sprung for an MSD, eh? Gud move. Tidy job in the engine room (IMG:style_emoticons/default/biggrin.gif) JP Did u see the access hole in the Firewall (IMG:style_emoticons/default/sawzall-smiley.gif) What is that for????? (IMG:style_emoticons/default/sawzall-smiley.gif) Maybe a new record for quotes. Ayup, I saw it. Access is gud.....even better to adjust/replace the fan belt, set timing, yada. |
joea9146 |
Oct 12 2004, 02:27 PM
QUOTE(J P Stein @ Oct 12 2004, 04:11 PM) QUOTE(Root_Werks @ Oct 12 2004, 11:56 AM) QUOTE(joea9146 @ Oct 12 2004, 10:52 AM) QUOTE(J P Stein @ Oct 12 2004, 02:01 PM) Hay, Joe.....sprung for an MSD, eh? Gud move. Tidy job in the engine room (IMG:style_emoticons/default/biggrin.gif) JP Did u see the access hole in the Firewall (IMG:style_emoticons/default/sawzall-smiley.gif) What is that for????? (IMG:style_emoticons/default/sawzall-smiley.gif) Maybe a new record for quotes. Ayup, I saw it. Access is gud.....even better to adjust/replace the fan belt, set timing, yada. Dan.... On a Six it saves you from having to pull the motor to access the Fan / belt... I recently had to replace the Alternator and was able to do it without droping the motor. Got access to the belt and shims from the Firewall hole. and pulled the carbs to get at the fan Housing. There is always a big debate if this should be done or not but I say fo a six its the way to go |
Root_Werks |
Oct 12 2004, 03:44 PM
QUOTE(joea9146 @ Oct 12 2004, 12:27 PM) QUOTE(J P Stein @ Oct 12 2004, 04:11 PM) QUOTE(Root_Werks @ Oct 12 2004, 11:56 AM) QUOTE(joea9146 @ Oct 12 2004, 10:52 AM) QUOTE(J P Stein @ Oct 12 2004, 02:01 PM) Hay, Joe.....sprung for an MSD, eh? Gud move. Tidy job in the engine room (IMG:style_emoticons/default/biggrin.gif) JP Did u see the access hole in the Firewall (IMG:style_emoticons/default/sawzall-smiley.gif) What is that for????? (IMG:style_emoticons/default/sawzall-smiley.gif) Maybe a new record for quotes. Ayup, I saw it. Access is gud.....even better to adjust/replace the fan belt, set timing, yada. Dan.... On a Six it saves you from having to pull the motor to access the Fan / belt... I recently had to replace the Alternator and was able to do it without droping the motor. Got access to the belt and shims from the Firewall hole. and pulled the carbs to get at the fan Housing. There is always a big debate if this should be done or not but I say fo a six its the way to go Going for record quotes here: Hmm, I have built 5-6 914-6 conversions, replaced 4 914-6 alternators, never needed the "hole". What I usually do is make a single cut along the fiberglass shroud. I found a special "H" shaped gasket that will allow you to remove this part of the shroud anytime you like. No more dropping engines, cutting up the car or removing the shroud. Easy stuff. I can see about posting some pics if people would like to see? Just preferance I guess, but I would rather put a cut in the fiberglass shroud than multiple cuts in the steel of the car. Nice idea though. Oh, I mark my flywheels for timing, adjusting valves etc..... BTW - very nice engine bay! Mine sucks. (IMG:style_emoticons/default/sad.gif) |
michel richard |
Oct 12 2004, 05:19 PM
Joe A,
Where's your battery, man ? Michel Richard p.s. I had the firewall hole in the pale-ivory car, I'm trying to do without it in the Ravenna-green one. I did have to cut a very small access hole to be able to adjust the MFI idle screw, but it's very small. I'd love to learn how to swap fanbelts without the hole. Factory sixes did not have one. |
dinomium |
Oct 12 2004, 05:30 PM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
before I was bit by the "whileyerinther" bug...
scotty914 |
Oct 12 2004, 05:51 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
Jeroen |
Oct 12 2004, 06:17 PM
Here's mine... (IMG:style_emoticons/default/unsure.gif)
(IMG:http://www.914world.com/bbs2/uploads/post-2-1097625247.jpg) |
URY914 |
Oct 12 2004, 06:40 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
dd
URY914 |
Oct 12 2004, 06:44 PM
not my car (IMG:style_emoticons/default/biggrin.gif)
rhcb914 |
Oct 12 2004, 07:05 PM
member Group: Members Posts: 358 Joined: 3-February 04 From: Boston, MA Member No.: 1,626 |
here's mine
Series9 |
Oct 12 2004, 07:29 PM
Those are some F'in nice engine bays.
Thanks for the nice comments on mine, but mine is obviously one of many. Instead of 914RS, call me Joe O'. Joe O' |
Series9 |
Oct 12 2004, 07:45 PM
QUOTE(URY914 @ Oct 12 2004, 05:44 PM) URY914, That's a nice option on that engine block. Mine didn't come with that, but it would make checking up on rod bearings very easy. Joe O' |
Lo-Fi Version | Time is now: 9th June 2024 - 11:41 PM |
