V8 Topic: Shifter extension at coupler, what do you think?, Eliminates modifying the rear shift bar |
neo914-6 |
Aug 2 2006, 04:41 PM
What if a male to female extension ~ 1.5" were made so it fits between the coupler and tunnel bar so it is all a bolt-on solution? (IMG:style_emoticons/default/idea.gif)
Eliminates cutting, aligning, adding material, and welding... I need one! (IMG:style_emoticons/default/biggrin.gif) |
Andyrew |
Aug 2 2006, 05:40 PM
Seems feesable... Tell rennegade to do it.. but then they wont make as much money ($200 for 1.5in of tube, and 30 seconds of weld... hmm)
IMHO, this would be great for the non welder guys.. but for me.. its 10x easyer and one less piece to break/ adjust.. Make one... and have someone (DLO for instance) mass produce them.. If it works for the suby too.. added bonus (BONUS!!!) |
Mueller |
Aug 2 2006, 06:13 PM
sounds fairly easy...if I can get some spare time in the garage this week and can get the dimensions I'll make you one...
no problem on the use of the trailer...cannot help with the tow vehicle |
neo914-6 |
Aug 3 2006, 02:13 PM
sounds fairly easy...if I can get some spare time in the garage this week and can get the dimensions I'll make you one... no problem on the use of the trailer...cannot help with the tow vehicle Mike, I can get you the shifter and coupler, Let me know when you are at work BTW, will you be coming to SEMA? Thanks! |
Mueller |
Aug 3 2006, 02:50 PM
i'm going to the office on Friday for a few hours, around lunch time....as for sema, I need to look at the dates to see if sherryl will be home to watch the girls...
oh yea, I already have the material for the extension.... |
neo914-6 |
Aug 3 2006, 04:28 PM
i'm going to the office on Friday for a few hours, around lunch time....as for sema, I need to look at the dates to see if sherryl will be home to watch the girls... oh yea, I already have the material for the extension.... Ok, I'll drop them off... I listed you as an assistant, at least someone with your nametag will be there. (IMG:style_emoticons/default/laugh.gif) |
Mueller |
Aug 8 2006, 01:41 AM
mild steel....I still need to add the taper for the cone-set screw and add the threads for the other set-screw
neo914-6 |
Aug 8 2006, 02:18 AM
(IMG:style_emoticons/default/pray.gif) great machining skills! See ya tomorrow...
type47fan |
Aug 13 2006, 10:17 PM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
Lo-Fi Version | Time is now: 8th June 2024 - 10:24 PM |
