Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Thanks guys, I'm actuially having some "flaps" waterjet cut to close the ends better. I should be able to "plug" and cover with smooth flap. These are a little ove a week out. Bringing the other main targa seal repair piece actually slowed it sligtly. Amother posting next week.
ellisor3 |
HPWhore ![]() ![]() ![]() Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States ![]() ![]() |
I would be in for a plugged set as well if it is not to late.
James |
klikkid3 |
Member ![]() ![]() Group: Members Posts: 111 Joined: 2-July 08 From: san bernardino Member No.: 9,242 Region Association: Southern California ![]() |
I am still in for a set, I havent checked for a while are they ready to sell now?
Thanks Phill |
Mikey914 |
These will be in hand this next week. I don't want to start taking any cash until I can confirm a ship date. I'll be posting more this upcoming week. I appreciate your patience. I was trying to get the other repair sedal for the top front 3 part seal and I've been it school for a new position at my day job, so my attention has been more focused on that. Otherwise these would be done.
KevinP |
Member ![]() ![]() Group: Members Posts: 205 Joined: 16-November 04 From: Orlando,FL Member No.: 3,127 ![]() |
Mike,
Put me in for 2 sets of the plugged type. KP |
Mikey914 |
I'm setting up to make them all plugged, it'll be easier for everyone. Thanks
Chevota79 |
Member ![]() ![]() Group: Members Posts: 83 Joined: 11-September 07 From: Rocklin, CA Member No.: 8,113 Region Association: None ![]() |
I'm in for a set
Mikey914 |
Here's pictures of the fitted pieces. you can see from the first picture how the seal allows the glass across the first lip and that's the first barrier, it also touches the back of the glass.
the original seals had a hole drilled into the extrusion for a screw that kept the extrusion from sliding around. This is a tight fit and I do not believe that it will be necessary. The parts is shown with a hand cut piece of rubber that's glued onto the extrusion. I'm actually having the ends water jet cut for a more presise fit and more finished look these will be done next week. I'm planning to start shipping these after the Thanksgiving weekend. I'll be contacting all this weekend to confirm orders. I hope this answers some of the questions on how the seal will work. Unfortunately these will install like OEM, the outside is fitted into the track and the inside is pushed in 1/4" at a time. I used a butter knife, but if anyone has any better ideas of how the OEM seals would install easier I'm sure it would work on these also. Thanks All. Attached thumbnail(s) ![]() |
Mikey914 |
More
The last picture really shows how the vertical targa seal (the one on the sail) has the glass sit on it, and the upper has a lip that the glass just clears to help seal out the water. Attached image(s) ![]() ![]() ![]() |
Jonny 914-6gt |
Newbie ![]() Group: Members Posts: 4 Joined: 19-May 06 From: Seattle, WA Member No.: 6,030 Region Association: None ![]() ![]() |
Ohhhh..... those look very nice.
Mikey914 |
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
Well you do very nice work no matter how long it takes. So when can I buy a set?
Mikey914 |
I'm going to start sending out the paypal / address information to those that want these this weekend.
klikkid3 |
AWESOME! (IMG:style_emoticons/default/aktion035.gif) I can finally put an end to the whistleing sounds above fifty miles an hour.
mike_the_man |
I like stuff! ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 ![]() |
Is it too late to get in on this? I could really use a set too? No rush on when I get it, just sometime before next spring would be good! (IMG:style_emoticons/default/biggrin.gif)
Cheers, |
jeeperjohn56 |
Member ![]() ![]() Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None ![]() |
Hey mark, I'll take a set, you said you're going to make them all plugged correct? thanks John (IMG:style_emoticons/default/pray.gif)
Mikey914 |
Hey mark, I'll take a set, you said you're going to make them all plugged correct? thanks John (IMG:style_emoticons/default/pray.gif) I can go either way , but it's easier to go plugged. But, there are those that want to save a few $. |
arvcube |
Member ![]() ![]() Group: Members Posts: 170 Joined: 25-September 07 From: poway, ca Member No.: 8,147 ![]() |
Just got my plugged set today. First look....WOW! They look great! I won't be able to install them until after the weekend but am looking forward to it. Long awaited for that's for sure!
Thanks Mark!! |
TC 914-8 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 812 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest ![]() ![]() |
Hi Mark,
I'm Not home til Thursday, but my wife tells me my rubber(s) came in the mail today. I'll be putting them on Fri. I'll keep you posted, Thanks, Tony |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
I got my set, they look like they will be great!!!
Lo-Fi Version | Time is now: 10th June 2024 - 04:07 PM |
