V8 CONVERSION, ELECTRIC REMOTE WATER PUMP |
914.SBC |
Dec 26 2010, 07:32 PM
Member Group: Members Posts: 248 Joined: 12-December 10 From: CORONA, CA Member No.: 12,479 Region Association: None |
I searched but could not find any pics:
Anyone have pics and brief description of how install a remote mount electric water pump. Also, will 40 gallons per minute be sufficient. Thanks and hope the holiday season is going well for everyone. |
Mike Bellis |
Dec 26 2010, 08:11 PM
You will need the hose barb bits for the front of the block. You want the pump to push water into the block at the timing cover... 40 GPM will be fine...
Hers a pick of the font of mine. I have a mechanical pump but they connect the same... The top outlet goes to the radiator via a high mount expansion chamber... |
streetrover |
Dec 27 2010, 08:06 AM
Member Group: Members Posts: 87 Joined: 22-December 09 From: Inland Empire Member No.: 11,163 Region Association: Southern California |
I searched but could not find any pics: Anyone have pics and brief description of how install a remote mount electric water pump. Also, will 40 gallons per minute be sufficient. Thanks and hope the holiday season is going well for everyone. I purchased a Meziere 40gpm pump for my Rover V8 conversion. It comes with a bracket that you can weld practically anywhere. The beauty of the electric pump is the flexibility of installation. I'll take a couple of pics today and show you how I mounted mine. It's in approximately the same spot as the one pictured above. Bob |
jmmotorsports |
Dec 27 2010, 08:22 AM
Member Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest |
I bought a Meziere 55 gpm pump for my LS1. Not much to installing one, you will have to fabricate a bracket to mount it. Other than that you can buy all the fittings needed from them. Their parts are very high quality and lots of $$$$. I don't have any photos,will take some when finished.
Jerry |
914.SBC |
Dec 27 2010, 02:36 PM
I bought a Meziere 55 gpm pump for my LS1. Not much to installing one, you will have to fabricate a bracket to mount it. Other than that you can buy all the fittings needed from them. Their parts are very high quality and lots of $$$$. I don't have any photos,will take some when finished. Jerry Thanks Jerry, I bought the same one only 40 gal. as it was 100 bucks cheaper. I am trying to get parts altogether so I can start fabricating and turning wrenches first of Janaury. Cant wait to see your LS1 engine. Wow... |
914GT |
Dec 27 2010, 02:50 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
Here's a picture of mine taken several years ago, with a Dedenbear remote pump and water manifold. Made a few modifications since then but mostly the same. An electric water pump works best mounted low in the system, and with a dedicated 12V supply line to battery or alternator to minimize voltage drop.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i216.photobucket.com-2923-1293483015.1.jpg) |
streetrover |
Dec 27 2010, 03:34 PM
Here are the pics I promised earlier of how I mounted my Meziere. The bracket was included with the pump and I simply welded it to the engine mount.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i221.photobucket.com-11163-1293485683.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i221.photobucket.com-11163-1293485683.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i221.photobucket.com-11163-1293485684.3.jpg) Hope this helps. Bob |
jmmotorsports |
Dec 27 2010, 05:07 PM
The guys at Meziere told me the pump will work the best mounted close to the radiator. I did not like the bracket they sent with the pump so I made an aluminum one that bolts in.
Jerry |
914GT |
Dec 27 2010, 05:59 PM
The guys at Meziere told me the pump will work the best mounted close to the radiator. I did not like the bracket they sent with the pump so I made an aluminum one that bolts in. Jerry Since the coolant will pressurize more towards the back under acceleration, I figured that area would be the best place to position it on a 914 That may not be the best on a front engine car though. |
stewteral |
Dec 28 2010, 09:10 PM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Here's a picture of mine taken several years ago, with a Dedenbear remote pump and water manifold. Made a few modifications since then but mostly the same. An electric water pump works best mounted low in the system, and with a dedicated 12V supply line to battery or alternator to minimize voltage drop. (IMG:http://www.914world.com/bbs2/uploads_offsite/i216.photobucket.com-2923-1293483015.1.jpg) 914GT: Are those iron drain pumbing fittings I see? Tisk, Tisk! Terry |
Mike Bellis |
Dec 28 2010, 09:23 PM
stewteral |
Dec 28 2010, 10:06 PM
I searched but could not find any pics: Anyone have pics and brief description of how install a remote mount electric water pump. Also, will 40 gallons per minute be sufficient. Thanks and hope the holiday season is going well for everyone. Hi 914.sbc, I built a 383 conversion car and have been running it on-track for some 5 years, although it is still street-licensed. I chose to tap the intake water ports in my SBC block with a 1" tap (just a little die-grinding and it was ready to go!), install 90Deg bends and then connnect directly to the output 1" nipples of the Meziere remote pump. Even though the Aeroquip 1" 90 Degree fittings have a threaded output side, I spent some time with my die grinder and created a "nipple" end to attach the 1" hoses with a hose-clamp. I chose the Meziere WP316 REMOTE pump with its 55 GPM capability, which matches the output of a Chevy pump at 6000 RPM. Of course the GREAT thing about electric pumps is that they pump at MAX cooling rate all the time. Sorry I don't have pics of the pump mounted, bit it was a simple 90 degree angle bracket bolted to the firewall behind the driver. Short 1" Green Stripe hoses connect the pump the the 1" nipples in the block. FYI: the Meziere folks are very helpful and give a 3200 hour MTBF on the pump (MTBF=mean time before failure). They also offered tp rebuild the pump for $50 including seals. Great deal! If I can be of further help, just ask, Terry |
Mike Bellis |
Dec 28 2010, 10:16 PM
I chose to tap the intake water ports in my SBC block with a 1" tap (just a little die-grinding and it was ready to go!), install 90Deg bends and then connnect directly to the output 1" nipples of the Meziere remote pump. That's the best way I've ever seen it done! (IMG:style_emoticons/default/aktion035.gif) |
914.SBC |
Feb 26 2011, 05:34 PM
I chose to tap the intake water ports in my SBC block with a 1" tap (just a little die-grinding and it was ready to go!), install 90Deg bends and then connnect directly to the output 1" nipples of the Meziere remote pump. That's the best way I've ever seen it done! (IMG:style_emoticons/default/aktion035.gif) Well I have purchased the Mezziere remote mount water pump. My engine is already installed so could not install it to the side of the engine like one of the members did. It will be mounted to the side of the firewall. I have made a bracket to mount it which was fairly easy. I have the shroud all fabbed out and mounted. I will put a skin of billet aluminum over it. Also installed an electric fuel pump. I have cut out the holes in the trunk for air circulation. I still need to cut the out the bumper and modify/install a grill from a 350z like one of the members suggested. Fittings for the water pump alone were over 100.00. I decided to go with full size radiator hose of 1 1/2 and 1 3/4. Including clamps this was 375.00...ouch. From the pictures I have seen, it does not appear that anyone has gone in that direction. The hoses seem small like 1". I have 1" from the block to the pump. I am getting closer...hopefully this week I will have the water pump and hoses installed. I am delayed somewhat becuase I just noticed that all the electrical to the rear of the car was cut. So now I have to re-wire the damn thing. But, I am making progress. I am shooting to have the entire car road ready and running by my birthday in May. |
914GT |
Feb 26 2011, 07:51 PM
Tisk, Tisk. Those 3/4" steel pipe fittings are still going strong eight years later.
914.SBC |
Mar 2 2011, 07:17 PM
Well I have made some good progress on the conversation:
ENGINE INSTALLED (HAS BEEN FOR A WHILE) RADIATOR AND FAN INSTALLED AND MOUNTED SHROUD FABBED AND INSTALLED WITH SKIN OF BILLET ALUMINUM HOSE RAN UNDERNEATH CAR TO ENGINE BAY ELECTRIC FUEL PUMP MOUNTED CARPET KIT INSTALLED CUSTOM CENTER CONSOLE FABBED AND INSTALLED GUAGES MOUNTED (STILL NEED TO GET TACH CONVERTED TO V8) THINGS TO DO: MOUNT THE ELECTRIC WATER PUMP ALL ELECTRICAL TO REAR OF CAR NEEDS TO BE RE-WIRED FAB AND INSTALL BILLET ALUMINUM SKIN ACROSS DASH FAB AND INSTALL FRONT GRILL HOOK UP CLUTCH CABLE BREAK IN THE NEW ENGINE----OH PLEASE DONT OVER HEAT MY GOAL TO FINISH THIS PROJECT IS BY THE END OF THIS MONTH... Attached image(s) |
914.SBC |
Mar 9 2011, 08:29 PM
Well I have made some good progress on the conversation: ENGINE INSTALLED (HAS BEEN FOR A WHILE) RADIATOR AND FAN INSTALLED AND MOUNTED SHROUD FABBED AND INSTALLED WITH SKIN OF BILLET ALUMINUM HOSE RAN UNDERNEATH CAR TO ENGINE BAY ELECTRIC FUEL PUMP MOUNTED CARPET KIT INSTALLED CUSTOM CENTER CONSOLE FABBED AND INSTALLED GUAGES MOUNTED (STILL NEED TO GET TACH CONVERTED TO V8) THINGS TO DO: MOUNT THE ELECTRIC WATER PUMP ALL ELECTRICAL TO REAR OF CAR NEEDS TO BE RE-WIRED FAB AND INSTALL BILLET ALUMINUM SKIN ACROSS DASH FAB AND INSTALL FRONT GRILL HOOK UP CLUTCH CABLE BREAK IN THE NEW ENGINE----OH PLEASE DONT OVER HEAT MY GOAL TO FINISH THIS PROJECT IS BY THE END OF THIS MONTH... WELL, I AM GETTING CLOSER TO COMPLETION OF THE CONVERSION LITTLE BY LITTLE. I INSTALLED 1 3/4 AND 1 1/2 RADIATOR HOSES. THEY ARE ROUTED UNDER THE CAR AND MOUTED WITH SOME BEEFY CLAMPS. THE WATER PUMP WAS A BEAR WELDING BRACKETS AND WELDING THAT TO THE FIREWALL BUT IT IS INSTALLED TOO. I MOUNTED THE ALTERNATOR WHICH WAS A NIGHTMARE GETTING THE BRACKETS IN. HAD TO MOVE THE BRAKE LINES BUT IT IS IN. JUST GOT BACK THE TACH FROM N. HOLLYWOOD SEEDO AND INSTALLED IT. MAN THEY DO A GREAT JOB RECONDITIONING IT. CLUTCH CABLE IS INSTALLED AND BILLET DASH IS INSTALED TOO. NEXT I NEED TO RE-WIRE ALL THE WIRES TO REAR OF THE CAR. THEY WERE ALL CUT. I NEED ALTERED THE FAN SO THAT IT IS CONNECTED DIRECTLY TO THE IGNITION SO IT WILL RUN ALL THE TIME. I AM MAKING PROGRESS AND I AM SHOOTING FOR THE END OF THE MONTH TO FIRE THIS BAD BOY U. Attached thumbnail(s) Attached image(s) |
bobo914 |
Mar 9 2011, 09:18 PM
Newbie Group: Members Posts: 12 Joined: 11-March 06 From: Riverside, CA Member No.: 5,708 |
I hate to say this but I think your pump is mounted to high in the system. You need to mount it as low as possible.
jmmotorsports |
Mar 9 2011, 09:35 PM
The Meziere pumps are gravity fed and need to be mounted below the center of the radiator. They also should be in front as close to the radiator as possible.
Jerry |
914.SBC |
Mar 9 2011, 09:49 PM
The Meziere pumps are gravity fed and need to be mounted below the center of the radiator. They also should be in front as close to the radiator as possible. Jerry HMM...I did in fact read that somewhere in the book I printed from this site. about mounting it low now that you mention it. You have no idea how tough it was to mount. I was happy now I am bumed. Now the delima. Why is it important to mount it lower than where I have it? Now to Jim, I have never heard or seen anything on mounting the water pump up by the ratiator. In fact, I never even considered that although that would have made the price of the hose alot cheper. Seriously though, I have not seen anything from the board like that. I am interested in each of your replies before tomorrow hopefully. Thanks gents |
Lo-Fi Version | Time is now: 8th June 2024 - 05:39 PM |
