| IronHillRestorations |
Mar 30 2010, 09:27 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,959 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Anyone bench test a wiper motor?
After I posted this, I went back and looked at the factory manuals in the wiper section and the wiring diagrams. I don't think you can properly test the full operation, but you can test the continuity of the motor and the two speeds. I'm pretty sure you'd have to mock up the wiring to the switch in order to get the motor to park correctly. To test the motor on the mid 72 and later motors, connect ground to the motor chassis ground and terminal 31b. Connect the positive to terminal 53 for slow speed and to 53b for the second speed. I always check and double check the position of the wiper system BEFORE installing the wiper arms. I make a pointer out of masking tape (wrapped around the wiper shaft) to mimic the position of the wiper arms. If you get it wrong you can take a couple nice chips out of the paint on the cowl ( (IMG:style_emoticons/default/smilie_pokal.gif) 1st hand experience!) |
Lo-Fi Version | Time is now: 19th November 2026 - 06:20 PM |
