Trunk light and License plate lights., not working |
steveherman |
Nov 2 2009, 04:09 PM
Member Group: Members Posts: 380 Joined: 12-September 09 From: Kissimmee Florida Member No.: 10,799 Region Association: South East States |
I got the interior light working.
The big relay under seat was removed. And the black wire there was broken. I am now working on the license plate and trunk light. There are no fuses blown yet... the wiring harness looks to be totally unmolested. i am thinkin something is unplugged some where. i have pulled the lights and they are pluugged in no power... where do i look? |
neil30076 |
Nov 2 2009, 04:13 PM
Recovering dismantler! Group: Members Posts: 397 Joined: 12-September 06 From: San Diego ( RB) CA Member No.: 6,826 Region Association: Southwest Region |
I got the interior light working. The big relay under seat was removed. And the black wire there was broken. I am now working on the license plate and trunk light. There are no fuses blown yet... the wiring harness looks to be totally unmolested. i am thinkin something is unplugged some where. i have pulled the lights and they are pluugged in no power... where do i look? (IMG:style_emoticons/default/idea.gif) Try the wiring diagram, its available on the pelican parts website, free. |
Spoke |
Nov 2 2009, 04:14 PM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The wire that powers the trunk light and license light originates at the headlight switch in the dash, goes across the tunnel, through the engine compartment and to the lights.
Have you verified zero voltage on the lamp pins? Got good grounds? Have you measured resistance from the lamp holder to ground? |
steveherman |
Nov 2 2009, 04:25 PM
The wire that powers the trunk light and license light originates at the headlight switch in the dash, goes across the tunnel, through the engine compartment and to the lights. Have you verified zero voltage on the lamp pins? Got good grounds? Have you measured resistance from the lamp holder to ground? no voltage at lamp pins. where is it grounded at? |
Eric_Shea |
Nov 2 2009, 04:38 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE where is it grounded at? Just above the left engine shelf on the side. |
steveherman |
Nov 2 2009, 05:08 PM
under the passenger seat there is 2 brown wires with a small female connector connected to it.
iit is unhooked. it is in same loom as the seat belt relay wiring. could this be it? where does it hook into? |
Lo-Fi Version | Time is now: 3rd June 2024 - 01:20 AM |
