Do I need these for the /6 engine?, Want to clean the shop |
PanelBilly |
Nov 15 2009, 02:52 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I will be using HE on my 3.0 (some day when $ is comming in rather than just going out). Will I still need any of these things?
The flapper boxes and hot air tubes off my 2.0? The rubber seals off the 2.0? Are they different on the /6 tin? The diffusers that hang down under the firewall? |
Eric_Shea |
Nov 15 2009, 05:23 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I kept the air foils for my 6. Rubber seals should be the same.
ClayPerrine |
Nov 15 2009, 06:59 PM
Life's been good to me so far..... Group: Admin Posts: 15,519 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If you are going to put heat exchangers on the six, then you need the flapper boxes. Also keep the rubber seals and the plastic flaps.
The rest is four cylinder only parts. |
PanelBilly |
Nov 15 2009, 08:22 PM
Thanks, I guess that means I can make a project out of cleaning up the flapper boxes
SLITS |
Nov 15 2009, 10:59 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
/6 flapper valves have a big hole in them ..............
(IMG:http://i239.photobucket.com/albums/ff312/professor914/flapper.jpg) |
ClayPerrine |
Nov 16 2009, 06:31 PM
/6 flapper valves have a big hole in them .............. (IMG:http://i239.photobucket.com/albums/ff312/professor914/flapper.jpg) Yea, but they are hard to find, and the /4 flappers will work. And if you check PET, the /4 part number supercedes the /6 part number for the flapper boxes. |
Lo-Fi Version | Time is now: 9th June 2024 - 08:41 AM |
