acceleration problems |
apexnit |
Nov 18 2009, 08:21 AM
Newbie Group: Members Posts: 6 Joined: 28-October 08 From: Stockton Ca Member No.: 9,694 Region Association: Central California |
does any body know why my 914/4 2.0 fi
is acting like its going to stall /or somtimes when i push on the gas it acts like it has an accelerstion problem. some one told me to chenge the pionts , did , still doing it , not all the time |
detoxcowboy |
Nov 18 2009, 09:31 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
I have a 914/4 2.0 as well and have been through the entire DJET system, and what ails you can be found but it will take learning the system, reading and doing basically. I am a novice and could do it, so well my car goes on 1200 mile road trips and perfect idle , acceleration ect. ect. But when I first got the car it was freaking stalling almost then it would go .. then again.. Loose battery cable, another time it was the MPS, then timing, then sticking decel valve kept the idle high. So being it could be anything or a combination of things. I would read these links below and check your system through out. Make sure the wiring harness are secured connected ect.. It seems difficult but it is not and once you learn the djet you can repair and analyze issues quickly even on the side of the freeway in the middle of the night.
I would start with checking all your connections because you say it is not all the time..... something came loose..... or could be wearing or failing. And take notice exactly when it seems like stalling is it cold, warmed up ect. Is it at constant speeds or when your taking off from a stop, does it go away when you push the pedal further ect. It is getting worse or just came on all of a sudden. Report back.. Good luck.. http://members.rennlist.com/pbanders/ http://rennlist.com/techarticles/djetronicfuel.htm http://members.rennlist.com/pbanders/DJetParts.htm http://www.pelicanparts.com/914/technical_...4_20FI_diag.htm http://members.rennlist.com/pbanders/Djetfund.htm |
apexnit |
Nov 18 2009, 03:50 PM
its only when i am keeping a contant speed , i was thinking maybe the gas pump is going bad or the spark in the distriuter cap is no good bad rotor but its only at a contant speed . i did have a drip by the gas pump to
tod914 |
Nov 18 2009, 03:53 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Have you checked the throttle possition switch to see if the contact plate is worn?
underthetire |
Nov 18 2009, 03:55 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Fix the leak ! Read about the Djet. Go through everything, especially throttle position sensor and MPS. Adjust or remove the decel valve. Check the distributor to make sure it holds vacuum. They are simple systems, but you have a lot of tracing to do. |
apexnit |
Nov 18 2009, 03:56 PM
is thet the plug by the trottle body thet sits on the side
underthetire |
Nov 18 2009, 04:09 PM
apexnit |
Nov 18 2009, 04:14 PM
thanx im going to go out thier and klean it rite know
underthetire |
Nov 18 2009, 04:50 PM
U, you better find the calibration procedure for it. Not just a cleaning. It's on this site somewhere.
Lo-Fi Version | Time is now: 15th June 2024 - 10:54 AM |
