| wayne1234 |
Nov 20 2009, 12:53 AM
Member ![]() ![]() Group: Members Posts: 260 Joined: 6-April 09 From: indianapolis in Member No.: 10,238 Region Association: None |
Well I'm going to order some parts today to put the engine back together, I basically have a stock 2.0 with a mild cam, and carbs, nothing special, should I just get a new factory oil pump or something else, I'M not gonna race it or any thing crazy, so Im thinking a stock setup would be fine where is the best place to get one? or am I crazy not to get "Blank set up" . Thanks and again recommend a vendor.
| sww914 |
Nov 20 2009, 01:03 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
My experience with the aftermarket oil pumps is that their internal machining leaves a lot to be desired. I use the best used pump that I can scavenge out of my piles of parts. If it's in the budget I go for new OEM.
| type47 |
Nov 20 2009, 06:44 AM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
| jmill |
Nov 20 2009, 07:53 AM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
There was a big thread about this. I believe that you should talk with Jake. IIRC he recommends a modified T1 pump. Call him.
| tat2dphreak |
Nov 20 2009, 08:11 AM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
I used a shadak 30mm pump. jake said the shadak's are not as consistent as they used to be, though.
| Mark Henry |
Nov 20 2009, 08:40 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Small engine so a shadak 26mm pump is all you need. Shadek's quallity issues are nothing new, Gene Berg was O-ringing the pumps long before Gene died in '96. this O-ring is done very similar to the o-ring on the T4 pump.
If the pump drops in it's no good, should have a hair of a press fit. One part of the "bag of tricks" that many builders don't like to tell you. |
| wayne1234 |
Nov 20 2009, 11:57 AM
how do you know if they are any good? someone said mine looke funny?
| ME733 |
Nov 20 2009, 04:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
(IMG:style_emoticons/default/popcorn[1].gif) I have used MELLING oil pumps with great success., The housing is cast iron and will maintain the center to center distances of the pump gears much better than aluminum. The port openings into and out of the pump can be blended with porting tools, opened and smoothed with great success. The gears are extremely interferance press fit, so the "spinning shaft "problem does not exist.(never heard of one doing this)...the back housing, against the cam gear, is solid...no extra nuts... to assemble housing ...in the way..(or to screw with) SOME people will disagree, because the OIL PUMP housing is cast IRON, and the Engine BLOCK install area is ALUMINUM. Maybe it will be 190 /220 degrees. the expansion differences (if much)(at all).and the worry factor ?...Can be ELIMINATED by Radusing the inner /outer mating surfaces at the crankcase and installing a ..O..ring...at the pickup tube entry. now you got two seals, the oem one and the one you will creatate. Big deal. the oil pump is a critical component of the engine , and should be cleaned, inspected, assembled, "feel Tested" for binding and smoothness of rotation. I'm talking about "BLUEPRINTING " the damn pump guys. Its worth the extra trouble to know your oil pump is going to work properly perfectly. And...MELLING has more experience, and manufactures more oil pumps than all the rest of the "trick "oil pump companies combined and has been doing so for Years. :the end. (IMG:style_emoticons/default/popcorn[1].gif)
| Drums66 |
Nov 21 2009, 04:01 PM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
(IMG:style_emoticons/default/popcorn[1].gif) I have used MELLING oil pumps with great success., The housing is cast iron and will maintain the center to center distances of the pump gears much better than aluminum. The port openings into and out of the pump can be blended with porting tools, opened and smoothed with great success. The gears are extremely interferance press fit, so the "spinning shaft "problem does not exist.(never heard of one doing this)...the back housing, against the cam gear, is solid...no extra nuts... to assemble housing ...in the way..(or to screw with) SOME people will disagree, because the OIL PUMP housing is cast IRON, and the Engine BLOCK install area is ALUMINUM. Maybe it will be 190 /220 degrees. the expansion differences (if much)(at all).and the worry factor ?...Can be ELIMINATED by Radusing the inner /outer mating surfaces at the crankcase and installing a ..O..ring...at the pickup tube entry. now you got two seals, the oem one and the one you will creatate. Big deal. the oil pump is a critical component of the engine , and should be cleaned, inspected, assembled, "feel Tested" for binding and smoothness of rotation. I'm talking about "BLUEPRINTING " the damn pump guys. Its worth the extra trouble to know your oil pump is going to work properly perfectly. And...MELLING has more experience, and manufactures more oil pumps than all the rest of the "trick "oil pump companies combined and has been doing so for Years. :the end. (IMG:style_emoticons/default/popcorn[1].gif) I like them!....using them for decades,no adverse effects yet!!! (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
| Jake Raby |
Nov 21 2009, 04:41 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I'll post some pics of a Melling pump on Monday...
| StratPlayer |
Nov 22 2009, 03:14 PM
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,361 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains
I'm running a melling in my new engine build. Works just fine
| Cap'n Krusty |
Nov 22 2009, 04:12 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
And, besides all those features, you get, free of charge, LEAKS!
I use nothing but stock pumps on stockish engines. In fact, you're generally safe cleaning, insoecting, sealing, and reusing your old one. BTW, I have a nearly new Melling pump for sale. Cheap. The Cap'n |
| Jake Raby |
Nov 22 2009, 06:12 PM
| StratPlayer |
Nov 22 2009, 07:50 PM
The melling that I have on my engine has no leaks what so ever.
| Jake Raby |
Nov 22 2009, 09:07 PM
| Jake Raby |
Nov 23 2009, 09:33 AM
Here is your modern day Melling pump. This one failed a short time ago upon start up in a test engine on the dyno. I was quick on the switch and the engine wasn't compromised, but I was very lucky. The oil pump drive isn't centered in the body of the pump with this unit so it snapped off the drive tang. Thats a fault I had never seen or heard of prior to this, now I inspect every pump for it no matter who made it. Components are constantly changing. What worked 35 years ago or just last month doesn't mean a damn thing. We see this more and more with the AFU Economy as companies are cutting corners to stay alive and sending out JUNK in some instances. Nothing ever stays the same- become set in your ways and you will get bitten in the ass. Constant awareness is key. |
| craig downs |
Nov 24 2009, 12:56 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 769 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
I was using a Schadek oil pump and got scared of the low pressure at idle when the oil got warm. So while I'm waiting for Jake to release his oil pump I replaced the Schadek with a new Melling oil pump i got back from the early 80s. The oil pressure is a little bit better by about 5 lbs. with the Melling. At least the oil light doesn't threaten come on anymore.
| Jake Raby |
Nov 24 2009, 09:16 AM
| ME733 |
Nov 24 2009, 10:46 AM
(IMG:style_emoticons/default/popcorn[1].gif) ....Very Intresting...I wonder what caused the drive tang , where It broke off, to TURN BLUE......on both of them. Seems like with the offset that bad , the oil pump drive tang simply would not align with the camshafts internal indent, and insert into the cam, and may have been driven by the camgear bolts, which were hammering on the drive tang, causing the heat indicator (blueing) and ultimate breakage, (snapped it off). I wonder if that pump was actually for a 914 or something else. Any identifible part number?. This should be a good example of the fact that all parts should be checked before using them., especially If the oil pump drive and "idler" gears are not centered / centerlined, with the camshaft/ center of crankcase, and centerlined in the pump housing you have a defectively manufactured pump or one for some other application. Thanks Jake for the photographs and information. (IMG:style_emoticons/default/popcorn[1].gif)
| StratPlayer |
Nov 24 2009, 10:52 AM
How many out there are running melling pumps and have had the problems that jake described. Curious.
Lo-Fi Version | Time is now: 1st April 2026 - 09:30 PM |
