New Bushings for headlight assemblies, anyone want any for the holidays |
dlestep |
Nov 28 2009, 07:36 PM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
smontanaro |
Nov 29 2009, 08:56 AM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
How do I know if I need this?
dlestep |
Nov 29 2009, 09:36 AM
How do I know if I need this? If your headlights sit crooked, it may just need adjustment on the outboard and inboard support tube brackets. The major reason is if there is movement in the assembly when driving, causing "jittering headlights." When your headlights are up, and your grab the upper edge and can feel movement, the bushings on the push rod are worn, and/or the pivot pin is loose or bushings are funky. I replaced everything in mine to remove all play in the system. Remember that the acetal resin bushings in your car are 30+ years old. The new pivot pins have a larger thread and boss than the original pivot pin. If the pivot pin has or had loosened, the failure mode is that the area of the thread relief cracks or fails and that light would not sit flush, and when up have a lot of play. |
dlestep |
Nov 29 2009, 03:00 PM
I could post the instructions again, if you want to go through them to determine things.
pjhaun |
Nov 29 2009, 06:49 PM
Member Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None |
dlestep |
Nov 29 2009, 07:09 PM
...I have six sets left.....one set per car
I take paypal at 914dlestep@gmail.com |
dlestep |
Nov 29 2009, 08:08 PM
...I wasn't implying that you had to buy all six sets....Ha ! (IMG:style_emoticons/default/biggrin.gif)
If you need one, buy one...Dave (IMG:style_emoticons/default/type.gif) |
Lo-Fi Version | Time is now: 12th June 2024 - 05:56 AM |
