sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
Elgin 7606-17 NOS camshaft. It's been floating from box to box for years, even before I got it. New gear installed, too. The lobes are ground to 1" so you'll need custom length pushrods.
304 deg. duration 365 lift 106 deg This is way too wild for stock injection. According to Mr Elgin, you'll want at least 10:1 compression for a 2056, 44mm carbs and big exhaust for this cam to work and it will make power between 3000 and 6500. This will not work with a single holley-weber and dented up old 1.8 heat exchangers and it won't be nice to drive with your mom in the car. $125.00 |
Lo-Fi Version | Time is now: 15th July 2025 - 03:46 AM |
