> Anyone here recognize this camshaft?
hasaramat
post Dec 12 2009, 05:28 PM
Looking at this cam on ebay but I cant seem to find out where it is from. Anybody here got any idea? I hope the links works.
ebay
Eric_Shea
post Dec 12 2009, 06:30 PM
PMB Performance
Grandbury, silly. (IMG:style_emoticons/default/hide.gif)
McMark
post Dec 12 2009, 06:43 PM
914 Freak!
Why?
It's an unknown cam, the lifters and the cam may not be the same company or the same production run, so they may not be the same hardness. If you buy it you're risking a poor running motor from an improper cam profile, or worse, a flat cam which can destroy the rest of your motor, just like this piston out of a flat cam motor.
But, to answer your question, no I don't recognize it. Both WebCam and Engle cams come in boxes with their names on them. This is not a WebCam or and Engle.
ME733
post Dec 13 2009, 09:55 AM
QUOTE(McMark @ Dec 12 2009, 07:43 PM) *
Why?
(IMG:style_emoticons/default/popcorn[1].gif) ............A FLAT cam, means that, in the begginning, there was no taper ground into the lobe....WHAT!!!!.....thats right GUYS camshaft lobes have a .5 to 1 degree angle GROUND INTO the lobe. This induces the LIFTER to spin/rotate with every cam lobe cycle, creating even wear for all the moving parts in the valvetrain and promoting lubrication for/to the cam and lifters... A" flat cam " is one that is worn down or manufactured WITH OUT an included ( perpendular) angle in the lobes..... (IMG:style_emoticons/default/popcorn[1].gif) I do agree that buying a camshaft on e-bay is just N U T S !
hasaramat
post Dec 13 2009, 11:19 AM
OK OK OK, no e-bay camshafts. (IMG:style_emoticons/default/wacko.gif)
ME733
post Dec 13 2009, 03:55 PM
QUOTE(hasaramat @ Dec 13 2009, 12:19 PM) *
(IMG:style_emoticons/default/popcorn[1].gif)..were not busting you b----, for fun. we just don't want you wasting your hard earned money on junk. .. a sincere MERRY CHRISTMAS.... (IMG:style_emoticons/default/popcorn[1].gif)
McMark
post Dec 13 2009, 04:01 PM
914 Freak!
QUOTE(ME733 @ Dec 13 2009, 07:55 AM) *
Why?
(IMG:style_emoticons/default/popcorn[1].gif) Thats a forged piston...It failed because the three piece (SET)OIL CONTROL RAILS were not installed. the centerpart/ as it was not restrained, expanded to the cylinderwall and ate itself and the cylinderwall,s up. the mammoth galling of the piston could also be from improper piston to cylinder wall clearances. a quick death in two directions. .............A FLAT cam, means that, in the begginning, there was no taper ground into the lobe....WHAT!!!!.....thats right GUYS camshaft lobes have a .5 to 1 degree angle GROUND INTO the lobe. This induces the LIFTER to spin/rotate with every cam lobe cycle.,( creating even wear for all the moving parts in the valvetrain.).................A" flat cam " is not going to destroy the piston, especially to the extent shown.... (IMG:style_emoticons/default/popcorn[1].gif) I do agree that buying a camshaft on e-bay is just N U T S !
You sure know a lot about a complete motor from one picture. Too bad most of it is WRONG. I'm not even going to waste time rebutting you, since odds are you won't believe me anyway since you apparently already think you know everything. (IMG:style_emoticons/default/mad.gif)
ME733
post Dec 13 2009, 04:15 PM
(IMG:style_emoticons/default/popcorn[1].gif) ...so YOU...must have built this engine...any Idea how the "flat cam" occured?, who were the manufacturer,s... It sure spit out some metal into the crankcase, and into the cylinders. (IMG:style_emoticons/default/popcorn[1].gif)
McMark
post Dec 13 2009, 07:17 PM
914 Freak!
*sigh*
The missing oil control rings were removed before the picture was taken. (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/rolleyes.gif)
Flat cam has nothing to do with the angle of taper, it has to do with this:
(IMG:http://www.originalcustoms.com/invoice/images/large_images/38_036371800%201182323543.jpg)
Mark Henry
post Dec 14 2009, 07:05 AM
that's what I do!
Good thing you didn't buy it, sounds like hydraulic cam and solid lifters. Nice combo....not. (IMG:style_emoticons/default/dry.gif)
But it could also be a european motorworks H grind, basiclly a Scat C-25 copy. If it is, it's a mild carb cam, on carbs it give's you no more power than a good D-jet.
ME733 There are several very experienced peeps on this board who make their living building engines and restoring 914's, McMark is one of them.
His shop is in Napa, CA where`s yours?
ME733
post Dec 14 2009, 08:04 AM
(IMG:style_emoticons/default/popcorn[1].gif) ..mark henry..my shop is at my home. but it,s MY SHOP and I rarely do any work for any one, except myself any more. sinse about 1970, starting with 356, then 911,s and 914,s. my business , BLACK FOREST ENGINEERING focused on scca, and then vintage racing porsches. I had the 1st registered 356, in vintage racing..(in the world?) In the united states..log book #18....could have been (9) but I liked 18 better..( I think that was 1978).. chief of technical inspection WMC and SVRA...about the first...12-or so years. runnoffs tech inspector /RD atlanta runnoffs, IMSA tech inspector daytona. I could go on but the long and short of it is I am RETIRED I am my own best customer...no more race date deadlines. (IMG:style_emoticons/default/popcorn[1].gif)
Mark Henry
post Dec 14 2009, 09:29 AM
that's what I do!
QUOTE(ME733 @ Dec 14 2009, 09:04 AM) *
Cool...but I bet there's at least a hundred members here that have a very similar story.
My point is you made a comment that wasn't even anywhere close to being right.
tat2dphreak
post Dec 14 2009, 09:38 AM
stoya, stoya, stoya
ignoring the usual BS,
you can think about this very logically... an unknown cam from a no-name box with nothing known about duration or lift, for $50, or your choice of a known cam in new condition to your choice of durations and lift for about $150... to me, even though its more $ on paper, it's a no-brainer. you also need the RIGHT lifters to go with the cam, they need to match hardness to be right...
guys like Jake, McMark, Mark Henry, etc can help you figure out what cam choice is right for your application and that advise from well-experienced individuals will cost you nothing. you can probably even find it in a search.
ME733
post Dec 14 2009, 09:49 AM
QUOTE(Mark Henry @ Dec 14 2009, 10:29 AM) *
Based upon the imperical evidance, observation , of the photograph furnished it was. However the oil control rings were partially disassembled prior to the photograph. I have a discussion going on now with mcmark. a broken camshaft, which was not shown certainly contributed to the total mess....and he didn't manufacture the cam, obviously. and the possibility of a severly overreved engine cannot be excluded.
Eric_Shea
post Dec 14 2009, 10:02 AM
PMB Performance
What? No popcorn emoticon?
J P Stein
post Dec 14 2009, 10:14 AM
Irrelevant old fart
Since when is a wrong answer here a felony...particularly when the evidence is misleading. If I had a buck for every shakey answer here, I could retire.
BTW, at best those Deves style oil rings are shit.
Here's another pic of them POSs.
aircooledtechguy
post Dec 14 2009, 11:30 AM
The Aircooledtech Guy
Gentlemen,. . . FOCUS. . . I thought p3n!s measuring belonged in the sandbox??
This is what I tell my clients when one of them asks the same question about buying a cam/lifter set. . .
You can't "un-bolt" a cam. There's no easy way to try one out w/o tearing the whole motor down. So unless you enjoy building your motor over again, think long and hard on the cam selection and/or consult those who have more experience successfully building engines for guidance. Proper cam selection is critical to getting a motor to behave the way you want and expect. Simply put; It's the conductor of the orchestra. The rest of the motor depends on its input and it affects every phase of the motor. If you let price be your guide to cam selection, you will be disappointed in your motor when finished; guaranteed.
Just my .02. . .
SLITS
post Dec 14 2009, 11:45 AM
"This Utah shit is HARSH!"
I love the hostility of this place.
(IMG:style_emoticons/default/yellowsleep[1].gif)
jasons
post Dec 14 2009, 01:40 PM
Jackstand Extraordinaire
QUOTE(Mark Henry @ Dec 14 2009, 06:05 AM) *
In my parts stash, I have a cam from EMW that is in a box just like that one. So I will say this, that box looks like a box I got from EMW like 10 years ago. FWIW, the cam I have came with Johnson lifters.
Mark Henry
post Dec 14 2009, 02:41 PM
that's what I do!
QUOTE(jasons @ Dec 14 2009, 02:40 PM) *
Yup...I saw the box and remembered EMW had cams they just called A, B, C, etc
In fact who ever got it might have done OK, it could be pre-issues camshaft.
- Lo-Fi Version Time is now: 31st July 2025 - 10:00 AM
